both would be helpfulArieKanarie wrote:The current one, or the one I am trying to make?
Toon app: Kalender
Re: Toon app: Kalender
- Starting Member
It is the default file, with only one line, the dutch holidays.
which file are you editing exactly (full path)?ArieKanarie wrote:It is the default file, with only one line, the dutch holidays.
- Starting Member
/qmf/qml/apps/calendar-1.1.4/userSettings.json
weird, the file is only created during first installation from the ToonStore.
After a reboot it should stay untouched.
Almost feels like your changes are not saved properly on the Toon.
I can help you via TeamViewer if you want somewhere next week to see what is going on.....
Just send me a PM with your phone number where I can reach you.
- Starting Member
hmmm, did another try: edited the file again, saved it.
Closed the connection and reconnected to check if the file was really saved (which it was) , rebooted, and now the Toon hangs with 'retrieving calendars' which usually was a good sign.
looking good so far....
-edit-
It is amazing mike! Now the calendar is loaded without problems. Shoot me but leak
-edit-
- Starting Member
And now the reboots are back
Going to change the file back, to make sure it is the calendar.
a small maintenance release 1.1.5 is available in the ToonStore.
Changelog:
- settings are now stored in the /mnt/tsc/data folder
- firmware 5 compatible only, support for lower firmwares has been dropped
Kind regards,
Changelog:
Kind regards,
- Starting Member
/mnt/data/tscToonz wrote:/mnt/tsc/data folder
installed 1.1.5, but no userSettings.json file to be found anywhere.
It seems one needs be added as /mnt/data/tsc/calendar.userSettings.json
(note the addition of 'calendar.' in front of userSettings.json)
you're right that the file is not created automatically if you never had the app before and install thelatest version for the first time.Strijker wrote:installed 1.1.5, but no userSettings.json file to be found anywhere.
Maybe I will change that.
Anyway , you can create the file yourself with this content:
{"ShowNotifications":"Yes", "Calendar_URL":[ "https://<calendarurl_to_basic.ics>" , "https://calendar.google.com/calendar/ical/nl.dutch%23holiday%40group.v.calendar.google.com/public/basic.ics" ]}
Sinds gisteren de Toon geroot, dus ben nog zoekende. Maar via Filezilla een verbinding opgesteld, maar ik krijg dit bestand of andere niet gevonden hoor.
Dus om mijn eigen Agenda toe te voegen.
Wat me ook opgevallen is dat ik 2 mappen met calenders heb. Zie afbeelding
- Starting Member
je kijkt niet op de juist plek: /mnt/data/tsc moet het tekstbestand staan
- Starting Member
Ik heb een geroote Toon gekocht en zou graag mijn kalender toegevoegd hebben, heb echter helaas geen kennis van domotica, wie kan mij helpen
- Administrator
Lees deze topic eens doorDmeuwissen wrote:Ik heb een geroote Toon gekocht en zou graag mijn kalender toegevoegd hebben, heb echter helaas geen kennis van domotica, wie kan mij helpen
