Toon app: Afvalwijzer
They changed their website, new link in the format of https://afvalkalender.dar.nl/ical/0268200000067332
Go to the Dar website, enter your zipcode/housenr.
Go to 'Naar jaar-en maandkalender'
Go to 'zet inzameldata in uw agenda'
Copy the link under 'Synchroniseren'
However, at the moment you don't seem to be able to download the calendar, probably because they are changing to the 2018 calendars. Who knows.
Try again in a few days/weeks I would advise.
This time the calendar is downloaded and I placed it at /root/waste/wast_calendar.ics. I also edited the .qml like it asks (7 for dar). But the tile stays empty. Even after a reboot.Toonz wrote:They changed their website, new link in the format of https://afvalkalender.dar.nl/ical/0268200000067332
The .ics contains values, so that is not the problem. But what is?
I still cannot download the calendar for some postal codes I test with (6651ZH housenr 2).jeltel wrote:This time the calendar is downloaded and I placed it at /root/waste/wast_calendar.ics. I also edited the .qml like it asks (7 for dar). But the tile stays empty. Even after a reboot.Toonz wrote:They changed their website, new link in the format of https://afvalkalender.dar.nl/ical/0268200000067332
By the way, you should select the right provider via the config screen (accessed via clicking on the tile).
If you have a previously saved configuration it will override whatever you put in the QML file.
Can you try this first? If still not working can you post the downloaded calendar file here (zipped)?
Toonz,
Can you add https://dfm.afvalalert.nl/ ?
Zipcode 8502 AW 47
It is using https://www.afvalalert.nl/kalender/8502aw/47. Output is JSON.
There is also an ics file I can download. But I don't know how to make this vissible on Toon in your app.
Thanks.
Zipcode 8502 AW 47
Thanks.
Can do now I know how to handle https data. Will add to the to-do list.
After closing the https issues with buienradar, the afvalwijzer is my next item on the to-do list.
Watch this space (will be next year though)
Kind regardz,
Hopefully you could also read out RD4
https://www.rd4info.nl/NSI/Burger/Aspx/ ... &nr=141&t=
I now the last time I had to save the web page but that did not work for chrome, firefox, safari only with internet explorer.
Unfortunately this is also not working with internet Explorer, The lay-out looks the same now as for chrome, firefox , safari etc.
Is on the to do list alreadymichel30 wrote:Hopefully you could also read out RD4
- Starting Member
For all members depending on wast collector 15,
for them how depend on waste collector Recyclemanager.nl (= waste collector 15), as off 01-01-2018 recyclemanager.nl stops support update waste collecting data.
Don't now why, only info from there site recyclemanger.nl is ( Recyclemanager eindigt haar dienstverlening per 1 januari 2018.
Maakt jouw gemeente gebruik van de Recyclemanager?
Kijk dan op de website van je gemeente hoe de afvalkalender
vanaf 1 januari te raadplegen is).
So this will for waste collector (15) in the tail stop providing waist collecting data from recyclemanager.nl
and will from 01-01-2018 the tail be blanc.
As i get info from the tail on Toon from recyclemanager.nl in postcode area 4587 this will stop after the Last date 29-12-2017,
As there is at the moment no app ore site who will give the data for the new and modified collecting schema, one of them who depended was Gemeente Hulst and they aspect the new app will be ready medio Februari who will support the data for collecting data is for the moment unknown.
Tanks Toonz, for making it happened that recyclenanager.nl was integrated, pity it only was for a short period, perhaps as from February there is probably a new to support!
Greetz Globegrabber
Greetz Globegrabber
Thanks for letting me know, I will remove the option in next release.globegrabber wrote:So this will for waste collector (15) in the tail stop providing waist collecting data from recyclemanager.nl
Let me know next year when you know more...
Regardz,
- Starting Member
Your welcome Asp. as i now more will let you now.
grz.
grz.
Now working fully automated via https, need to enter zipcode/housenr in the config screen. No need for manual downloads anymore. Will be in next release....michel30 wrote:Hopefully you could also read out RD4
They made some small changes to the HTML code and I also understand now the differences between the browsers, anyway, not relevant anymore
Done, in next release. Need to retrieve the JSON via WGET for now. Still struggling with the Comodo SSL certificates
kind regardz,
That is great.Toonz wrote: Done, in next release. Need to retrieve the JSON via WGET for now. Still struggling with the Comodo SSL certificates
kind regardz,
I don't know the problem you have with commodo but maybe you also need the intermediate cert.
You are probably right, thanks for the hint. Will give it a try.glsf91 wrote:
That is great.
EDIT: Spot on, that did the trick
Could it be that mijnafvalwijzer.nl (waste collector 1) changed their format? It gives no info at the tile.
(Note: our gemeente (Castricum) changed to this provider per 1/1/2018, the website of mijnafvalwijzer.nl shows already the correct information)
