Toon firmware - update script
Post by TheHogNL »
michel30 wrote:Hello,
Thanks again for the nice update script.
I just update my toon 1 to software version 4.22.7 with the TSC update script all okay now problem at all.
I have only one small question I also searching in this forum but could not find it.
In the passed, one year ago I added the new energie price in Globals.qml /qmf/qml/qb/base/Globals.qml but now I see only Globals.qml.back properly I did that before I edit that file.
Now my question where can I enter the new price for next year? So Toon will show this?
Editing the prices in Globals.qml was not always the right way. There is also another place where you need to edit the prices. I will add this to the TSC menu somewhere in the future. Globals.qml is now hidden in the resource file so you can't edit it anymore.
Post by TheHogNL »
Rudolf wrote:
TheHogNL wrote:
Rudolf wrote:Just ran the script from the shell to update from 4.19.10 to 4.20.7 (I'm not ready for the latest greatest...)
Please remind that 4.20.7 is never official launched by Eneco. Only some fieldtester had this firmware. Better go for 4.22.7
Thanks; just upgraded to 4.22.7 using the TSC Menu in the GUI. It's too easy. :D
One minor thing: After a reboot it shows a notificatin saying there's a firmware update available; when I click on it, it takes me to the 'Meetmodules' screen.
(The Meteradapter is not yet operational, it has been paired, but the sensors are still connected to another adapter from Toon1)
The same happens when I click the 'Download new firmware' button in the notification bar. :o
This is the meteradapter firmware I think. Part of the original Toon software so I can't say anything about this :) you probably need to update that firmware on the meetadapter.
lievenco wrote:Is it possible to update my Boxx (Toon) with software version 1.0.9.
I tried the update script but, I ran in to some errors...
Could you post the errors (and a screen dump)? There's a strong possibility that your boxx is still running flash-based firmware. This can be updated, but it will probably require some manual tweaking.
TerrorSource
Post by TerrorSource »
Are you sure that your unit is a Boxx one? I’ve updated an Eneco Toon from 1.0.9 to the latest but it was hard. Upgrade script does not work fully. It tries to install some packages which aren’t available in the repo anymore, so you need to install newer versions or revisions of that package manually.
Post by TheHogNL »
If you want just let me help you remote (teamviewer). Send me some contact details in a private message (for example skype or whatsapp)
1.0.9 Boxx looks like to have the same base as a dutch Toon around firmware 3.0.0
I just added 1.0.9 to be on the allowed list of firmwares so the script won't stop at that. You can try again yourself if you want.
EDIT: it will fail because there is no 2.9.26 intermediate firmware for the Boxx (not necessary also as it seems). Just try to update directly to 4.22.7 with "sh update-rooted.sh -v 4.22.7"
lievenco
Post by lievenco »
Here is a screencapture...
qba-001-0266:~# sh update-rooted.sh -v 4.22.7
: not founded.sh: line 2:
Welcome to the rooted Toon upgrade script. This script will try to upgrade your To on using your original connection with Eneco. It will start the VPN if necessary.
Version: 3.36 - TheHogNL & TerrorSource & yjb - 17-11-2018
: not founded.sh: line 11:
update-rooted.sh [OPTION]
This script will try to upgrade your Toon using your original
!!Running this script is at your own risk!!
Options:
-v <version> Upgrade to a specific version
-d Skip starting VPN
-s <url> provide custom repo url
-f Only fix files without a version update
-u unattended mode (always answer with yes)
-h Display this help text
: not founded.sh: line 29: }
: not founded.sh: line 30:
: not founded.sh: line 31:
update-rooted.sh: line 38: syntax error: unexpected word (expecting "then")
qba-001-0266:~#
Post by TheHogNL »
I helped you already. Updating a Boxx is not really working correctly yet with the script. Also your VPN didn't start up as your firmware was too old
timkoers
Post by timkoers »
I think Eneco updated their update scripts again, I am updating from 4.19.10 to 4.22.7 and it is telling me that the script from the source server has changed.
Post by TheHogNL »
Yes correct. I verified it and changed the MD5 in my script again. Thanks.
hayman
Post by hayman »
hello,
after updating my script file and try to upgrade my 4.11 rooted to 4.22 i get this
(((Starting the upgrade prepare option which downloads all necessary files. No upgrade is done yet.
Progress: 97% .
Prepare failed. Please check the logs at /mnt/data/update/upgrade-qb2.sh.log
Quitting the upgrade. It was a nice try tho...)))
when i look at the LOG i found this
Collected errors:
* opkg_download_pkg: Package easyenergy is not available from any configured src.
* opkg_install_pkg: Failed to download easyenergy. Perhaps you need to run 'opkg update'?
> Exit code: 255
>> 2018-11-24 18:47:46 +0000 (pid 3080) prepare-error-opkg-download-download 'opkg failed to download'
any help please i'm not that expret :$
Post by TheHogNL »
Somehow your toon thinks that the easyenergy-toonstore-app for rooted toons is part of the original software. Please try and remove easyenergy app using the toonstore before trying the update again.
Though this is weird....
hayman
Post by hayman »
befor i've alot of apps after that ive notis the toon is slow so i remove moest of the thinks i dont use one of them is easyE. and i restart the toon is much fater ,i run the update again still the same :(
Post by TheHogNL »
Please paste the complete log
gielie
Post by gielie »
I have a question?
Im still on 4.13.7 (TOON 1) and i want to update to the latest version.
Is there something i have to do/know before i update?
Can i simply download the latest "update-rooted.sh" and execute this by doing;
sh update-rooted.sh
and choose the firmware i like to have (latest 4.22.7?)
many thanks for this project.
Post by TheHogNL »
gielie wrote:I have a question?
sh update-rooted.sh
Correct. The script will do the rest and report if there are problems. For a few old toon's for example the VPN will not start anymore.
However, there is not really need to update from 4.13.7. No big changes for which you need to update.
Return to “Toon Firmware”
