HS3 MQTT Plugin
Moderator: Willem4ever
- Starting Member
Re: HS3 MQTT Plugin
Geert-Jan
That was quick! I had the wrong plug-in installed. I'll fix that and see how it goes.
Thanks
Tom
Thanks
Tom
- Starting Member
Re: HS3 MQTT Plugin
Hi
Thanks that worked. I should have read the forum more closely. That suggestion moved me forward a lot. Now I need to install a broker somewhere on my network.
Would it be asking too much of the little Pi to have the broker also running on it beside HS3?
Tom
Tom
Re: HS3 MQTT Plugin
Hereby an updated version, but not thoroughly tested yet.
Changelog:
- Added filter on the 'Publish' page, which will make selecting a device more easy and reduces page loading time.
Note that per default ALL check marks are off, meaning that NO devices will be displayed until you select the Room and Type (aka location and location2).
Geert-Jan
Changelog:
Geert-Jan
- HSPI_MQTT_v0.6.2.zip
- (37.42 KiB) Downloaded 494 times
Re: HS3 MQTT Plugin
I have installed http://dev.mysql.com/downloads/connector/net/ but the script is not yet workinggeert-jan wrote:Hi,
the MQTT plugin writes the MQTT data in a Homeseer device, the device values are available in events and scripts.
I use 'location2' as device type; Electra, Water, Gas.
The script below is called from a Homeseer event every hour, and writes the actual device values for each device where the type is 'Electra', 'Gas' or 'Water' to a MySQL database. The types can easily be extended, with Temperature, Humidity, etc.
Adapt the fields between'<>' in conn.ConnectionString = "server=<ip address>; user id=<user id>; password=<password>; database=<database>" to your configuration.Code: Select all
Imports MySql.Data.MySqlClient Sub main(Optional ByVal pParms As String = "") Dim en Dim dv en = hs.GetDeviceEnumerator if IsReference(en) Then do while not en.Finished dv = en.GetNext if not dv is nothing then select case dv.location2(hs) case "Electra" writeDB("electra", dv, 1000) case "Gas" writeDB("gas", dv, 1000) case "Water" writeDB("water", dv, 1) end select end if loop end if End Sub Sub writeDB(ByVal dbTable as String, ByVal dvRef as Object, devFactor as Integer) Dim conn As MySqlConnection Dim myCommand As New MySqlCommand Dim timestamp As String Dim devValue As Integer timestamp = Datepart("yyyy",Now()) & "-" & Right("0" & DatePart("m",Now()),2) & "-" & Right("0" & DatePart("d",Now()),2) & " " & Right("0" & DatePart("h",Now()),2) & ":" & "00:00" if NOT dbTable = Nothing conn = New MySqlConnection() conn.ConnectionString = "server=<ip address>; user id=<user id>; password=<password>; database=<database>" devValue = Convert.Toint64(dvRef.devValue(hs) * devFactor) Try conn.Open() myCommand.CommandText = "INSERT INTO " _ & dbTable _ & " (deviceName, timestamp, deviceValue, deviceType, deviceId)" _ & " VALUES ('" _ & dvRef.Name(hs) & "','" _ & timestamp & "','" _ & devValue & "','" _ & dvRef.location2(hs) & "','" _ & dvRef.Code(hs) & "')" myCommand.Connection = conn myCommand.ExecuteNonQuery() conn.Close() Catch myerror As MySqlException hs.writelog ("datalog", "Error Connecting to Database: " & myerror.Message) End Try end If End Sub Sub updateCounter(Optional ByVal pParms As String = "") dim electraTotal as double dim dev1 as integer dim dev2 as integer dim dev3 as integer Dim arrParm() As String ' Extract parameters arrParm = pParms .ToString.Split(";") dev1= arrParm(0) dev2= arrParm(1) dev3= arrParm(2) electraTotal = hs.devicevalueex(dev1) + hs.devicevalueex(dev2) hs.setdevicevaluebyref(dev3, electraTotal, true) hs.setdevicestring(dev3, electraTotal & " KWh", true) end sub
Geert-Jan
Compiling script C:\Program Files\HomeSeer HS3\scripts\LogDataToMysql.vb: Type 'MySqlException' is not defined.
Compiling script C:\Program Files\HomeSeer HS3\scripts\LogDataToMysql.vb: Type 'MySqlConnection' is not defined.
Re: HS3 MQTT Plugin
Great, thanks very much. Trying it right now.
Cheers
Al
Cheers
Al
Reason: please stop quoting while not needed...thanks
Re: HS3 MQTT Plugin
@raymonvdm:
I got VB and MySql working by downloading the MySql connector from Microsoft:
- http://dev.mysql.com/downloads/connector/net/1.0.html
- Select platform '.Net and Mono'
- Download the zip file
- Extract the .dll files to your Homeseer folder
Geert-Jan
Geert-Jan
Re: HS3 MQTT Plugin
Which version did you select? I tried 1.0.10 and 6.8.7 but stil no go
Note: My HS3 is running on Windows 7
Error Compiling script C:\Program Files\HomeSeer HS3\scripts\LogDataToMysql.vb: Type 'MySqlException' is not defined.
Error Compiling script C:\Program Files\HomeSeer HS3\scripts\LogDataToMysql.vb: Type 'MySqlConnection' is not defined.
Error Compiling script C:\Program Files\HomeSeer HS3\scripts\LogDataToMysql.vb: Type 'MySqlCommand' is not defined.
Error Compiling script C:\Program Files\HomeSeer HS3\scripts\LogDataToMysql.vb: Namespace or type specified in the Imports 'MySql.Data.MySqlClient' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
Error Compiling script C:\Program Files\HomeSeer HS3\scripts\LogDataToMysql.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
Re: HS3 MQTT Plugin
I am using MySql connector version 6.7.4, date 19-06-2013, on a Windows XP system (running in a VirtualBox).
Geert-Jan
Geert-Jan
Re: HS3 MQTT Plugin
Is it also possible to add the Reference ID to the list of devices visable under MQTT -> Publish ?
I have found a way to export the MQTT data to file to create my cacti graphs but i need to manually lookup the reference id for each device which is quite time consuming
Re: HS3 MQTT Plugin
Adding the reference ID is no issue. I will add it to the overview.
Geert-Jan
Geert-Jan
Re: HS3 MQTT Plugin
I did some extra testing and it looks like some value updates are not MQTTed out. I have an OpenThermGateway script and the HomeSeer device status seems to be updated but the values are never send out by MQTT
Re: HS3 MQTT Plugin
Hereby an updated version.
Changelog v0.6.4:
- Added device Id to 'Publish' page
- Publish value on value change (/homeseer/ + <dvRef> + /value)
- Publish string on string change (/homeseer/ + <dvRef> + /string)
This may lead to 2 publish messages per value update, since mostly also the string value is updated.
Geert-Jan
Changelog v0.6.4:
Geert-Jan
- HSPI_MQTT_v0.6.4.zip
- HS3 MQTT v0.6.4
- (37.5 KiB) Downloaded 441 times
Re: HS3 MQTT Plugin
Is it possible to select the value or sting to publish to prevent dual MQTT messages. Usually the value is sufficient but sometimes you indeed need a string instead of a value
Re: HS3 MQTT Plugin
I will add a feature to select if you want to publish the value on value change, or publish the string on string change.
Geert-Jan
Geert-Jan
Re: HS3 MQTT Plugin
Or both perhapsgeert-jan wrote:Hi,
Geert-Jan
