Toon app: Traffic information
Re: Toon app: Traffic information
ok, will wait on the new app
just checked the anwb json feed but the actual speed radar info is not included (although the JSON file suggests it would).
Anyway, the app is working fine again on a Toon 2, need to polish it a bit and do tests on a toon 1 for performance and layout.
This new release will become available in the ToonStore in the near future.
still not able to install.
Keeps telling:
"Deze applicatie Verkeersinformatie is niet geschikt voor de software versie 5.13.12 van uw Toon"......
Keeps telling:
I am quick but not that quick.Xavier wrote:still not able to install.
Keeps telling:
Again: you get this message because I blocked installation of the old app via the ToonStore on all firmwares because it absolutely doesn't make sense to install it as it will not receive any traffic data.
The new version of the app is currently being developed, as you can read in my post above yours: "When the new app is completed it will be available through the ToonStore again"
Please forget about version 1.0.9, it is obsolete.
I will post it here when the new app is available, as usual it will get a higher version number.
Kind regardz,
ahhhhhhhhhhhhhhhhhh I misunderstood you.
Sorry about that!
Sorry about that!
the brand new version 2.0.0 is available in the ToonStore.
It uses the new json feed from anwb.nl.
Only available for firmware version 5.x.x
Changelog 2.0.0:
- changed the source from xml.fileindex.nl to the anwb.nl json feed
- user settings (road filter) are now stored in the persistent /mnt/data/tsc folder
- this update will only be available on firmware 5 Toons
Kind regardz,
Changelog 2.0.0:
Kind regardz,
Thanks, great Job.
Already installed it
Hi Toonz,
great that the trafic info app is working again, I only have a small question, in the early version I had in the road filter only A13 and A20 and when there was no traffic jam the tile was empty, now I see all the other roads also, even with filter on or off.
Is there something I can do about this ?
Many thanks for the new 2.0.0 version
No, it's a bug, will fix it in the next releaseaabre wrote:Hi Toonz,
version 2.0.1 is available in the ToonStore.
Changelog:
- the road filter is now also correctly applied to the tile
Kind regardz,
Changelog:
Kind regardz,
Great job !!
Many thank's Toonz it's working like a charm
Verkeersinformatie
Geen verkeersinformatie meer.
melding:Verkeersinformatie ophalen mislukt.geen internet verbinding.
Wel internet verbinding. Andere apps werken voor 100%
software 5.25.8
software 5.25.8
I have the toon with Version: 2.0 - ThehogNL - 24-3-2018 upgrade from version 2.9.26 upgrade to 4.10.6. Update failled / Bus error
OPKG Do Not Work / Bus error / orange screen with 2 points.
What can I do
What can I do
- Administrator
Re: Verkeersinformatie
I've moved your post to the corresponding "Verkeersinformatie" topic.jumperone wrote:Geen verkeersinformatie meer.
software 5.25.8
the error message is a bit misleading maybe. Point is that the app could not retrieve the latest traffic data. It can be because of a local WiFi/internet issue or an issue with at the data provider. Anyway, should resolve automatically when the underlying issues has been resolved.
De link van ANWB: https://www.anwb.nl/feeds/gethf
volgens ANWB bestaat niet meer.
Dus weet ik het ook niet meer
What can I do
What can I do
