New Energy Saving Z-Wave Thermostat from Danfoss
Re: New Energy Saving Z-Wave Thermostat from Danfoss
The new Danfoss radiator thermostats are available.
Wall thermostaat from Danfoss is stil not available..I hope in may.
The Horstmann version is available.
geert-jan
Post by geert-jan »
Interesting News,
I am waiting a long time for these radiator thermostats, and the availability now gives me a complete summer to experiment with these devices.
Some questions from my side:
1) is the M30x1.5 version compatible with Heimeier. According to my information the heimeier has a 30mm nut, can I assume that the Danfoss fits?
2) and most important: Are these radiator thermostats supported by Homeseer?
Geert-Jan
menno26
Post by menno26 »
I'm wondering if the EM6500 can control these thermostat's,...
M30 is not the Danfoss standard.
Danfoss use the RA system (Klik)
f0r 99% sure they will fit.
At the moment I'm using the previews version of the Danfoss thermostat. This is working wel in Homeseer.
With the new one you will get a extra device for setting the temperature in Homeseer.
Availability is delayed to end april...
I'm a bit surprised about the size.
It's almost the same size as the normal Danfoss version.
In the next days I will test this device and post a review online.
some pictures.
Edwin2008
Post by Edwin2008 »
older people would prefer the old ones because of better grip when manual operated.
** edwin **
Bastiaan
Post by Bastiaan »
Edwin, I thought that the idea was to do things remote and not touch it anymore :-)
Enver, good News and for sure I will get some when I am back in Holland. Not sure I have the RA version everywhere.
Bad News:
Devices are not working well in Homeseer.
http://board.homeseer.com/showthread.ph ... ht=danfoss
Good News:
When it will work you will have good control.
Since the modules are detected by the Homeseer Thermostat plugin.
erwindr
Post by erwindr »
TANE wrote: It's almost the same size as the normal Danfoss version.
This is great to see, I anticipated a much bulkier module.
Not so great News about the Homeseer integration though. Let's hope that's fixed soon!
Erwin
HS3 Pro 3.0.0.298, W10 on Atom x5-Z8300
SqueezeBox, UltraM1G3, UltraMon3, Z-Wave
HS2 Pro 2.5.0.80, W2k3 on AMD X2
X10 CM11A/CM12U, SqueezeB, UltraMon, tenHsPower, UltraM1G, SqueezeBox
nico_gh2
Post by nico_gh2 »
Shame it doesn't work out of the box as this would be a great addition to my setup.
Hopefully you/they will get it to work.
Where did you het one?
nico_gh2 wrote:Shame it doesn't work out of the box as this would be a great addition to my setup.
I'm sure it will work soon...since this a Homeseer probleem and not Danfoss
I hope we will not need any thermostaat in the next months. :D
"Where did you het one?" Shop?
Return to “Z-Wave Forum”
