Buienradar monitor HS3 plugin
Moderator: labium
Re: Buienradar monitor HS3 plugin
Found the right version, I have installed this version.
Within the setup I can enable the plugin, but don’t see the setup page under plugins.
There are no errors in the log.
Disconnected
Buiten BuienRadarGps BuienRadarGpsDevice BuienRadarGps_IO_0 IO panel Today 9:39:17 PM
Any idea
Ed
Disconnected
Any idea
Ed
Labium,
hereby a feature request is it possible to create devices which value will be set high once rain is expected( 5 or 10min) just like the neerslagmonitor scripts in hs2.
Regards
Bart
Regards
Bart
(ON ESXI )on NUC
(ON ESXI )on NUC
the setup page is to be reached via the manage plugins page then press the blue name of Buienradargps
new version with i hope good working connect and disconnect status of io device. if you downloaded 1.0.0.5 you only have to replace the hspi file
- buienradar1.0.0.6.zip
- (85.82 KiB) Downloaded 709 times
labium,
Thanks, the connection state works now.
one other question. Is the device vaue of the location used? Should it have a value of 100 when rain is expected? Because I always see a value of 0.
Happy holidays!
Bart
Happy holidays!
Bart
(ON ESXI )on NUC
(ON ESXI )on NUC
the device value is used for which graph is presented, big or small, not for the rain parameters, i am thinking how to have both in the device value or in the device.
Labium,
Maybe an idea to store the graph settings to a config file? Or create additional devices with user defined offset times with a high value when rain is expected in 1, 5 or 10 min for example?
Regards
Bart
Regards
Bart
(ON ESXI )on NUC
(ON ESXI )on NUC
The new version works great, only I can’t see graphics with Google chrome
With explorer its works fine.
But most off the time I use chrome so any idea
Thanks Ed
Thanks Ed
Same here with iphone or ipad. Maybe an idea to create the graphs with javascript.
However still a great plugin!!
(ON ESXI )on NUC
(ON ESXI )on NUC
the first version makes graphs with javascript
Labium
I use these graphs alot. Are compatible with most browsers. More info at board.homeseer.com/showthread.php?t=164 ... to=newpost
Regards
Regards
(ON ESXI )on NUC
(ON ESXI )on NUC
dont worry in the next version chrome will work, i forgot a ")" in the code, ie has no problem with that chrome was more precise. if i wasnt changing the devicevalues it was published already.
- chrome.PNG (49.78 KiB) Viewed 16709 times
Is it possible to disable logging?
The updates are uhmmm, quite large
i will implement the logging choices in the next version
