Toon firmware - update script
Post by TheHogNL »
TheHogNL wrote:
>> upgrade OK: removing cached package files...
HCBv2 apps started via runlvls, preparing startables for next boot.
HCBv2 adding: comm eventmgr kpi pwrusage scsync smartplug thermstat usermsg weather bxtproxy config log rrd watchdog hue p1 zwave lighttpd.
HCBv2 startables unchanged, not writing /etc/inittab.
>> Done, scheduling reboot in 2 secs...
>> 2019-01-25 14:33:13 +0000 (pid 10064) executed
>> 2019-01-25 14:33:13 +0000 (pid 10064) exit-0 execute-ok-upgrade-qb2.sh 'qb2 uni 5.0.4 execute'
So at the end of the logs everything looks fine.
Not sure why the root update script stopped. Better check /etc/default/iptables.conf before rebooting to make sure port 22 is still open.
Found out what happened thanks to wickedmaster with same issue. Normally the script exists after 15 minutes of running. However the update only took about 8 minutes. Anyway the 15 minutes, or rather a 900 sec counter got to the end. This was because of the sleep command failing during busybox update and hitting the 900 counter limit to fast due to that.
jossie67
Post by jossie67 »
#-A HCB-INPUT -p tcp -m tcp --dport 22 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
Yes port 22 is still in so I will reboot
Uhmm, the line is commented out (#). Probably lost access now.....
jossie67
Post by jossie67 »
not yet, I didn't reboot, I was doubting :-)
I have to uncomment
This is my tables now
*nat
:PREROUTING ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
COMMIT
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
:HCB-INPUT - [0:0]
-A INPUT -j HCB-INPUT
-A FORWARD -j HCB-INPUT
-A HCB-INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
# These are all closed for Quby/Toon:
#-A HCB-INPUT -p tcp -m tcp --dport 80 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
#-A HCB-INPUT -p udp -m udp --sport 67:68 --dport 67:68 -j ACCEPT
#-A HCB-INPUT -p udp -m udp --dport 137:138 -j ACCEPT
-A HCB-INPUT -i lo -j ACCEPT
-A HCB-INPUT -i tap+ -j ACCEPT
-A HCB-INPUT -i tun+ -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --tcp-flags SYN,RST,ACK SYN -j DROP
-A HCB-INPUT -p udp -m udp -j DROP
COMMIT
Do I have to uncomment these ?
Absolutely yes !!!! Especially port 22.
jossie67
Post by jossie67 »
Yes,
I reboot, could connect to Toon with putty
and did
./upgrade_rooted.sh -v 5.0.4
Now the upgrade was succesfull!
TheHogNL wrote:BTW: could you share your apps?
I'm afraid my apps are not really fit for general use. They rely heavily on a local web server for producing the necessary data. Also they are not all that spectacular. Just things like showing the current solar power, but obtained from a serial port on my specific brand of inverter instead of the standard toon method.
Post by TheHogNL »
You know you could feed that info into the meteradapter as a self-made simulated pulse signal (imp/kwh)? Then you could use the original zonoptoon tiles. I'm doing something like that also.
Just use a Pi Zero, ESP32 or something to get the serial data from your inverter, translate the Watts to imp/kwh and let a digital output pulse at that frequency. Using the correct wiring you don't need a pulsing led. Just S0 interfacing.
TheHogNL wrote:You know you could feed that info into the meteradapter as a self-made simulated pulse signal (imp/kwh)?
I know you could do that, if you have a meter adapter compatible with zonoptoon. Unfortunately I have the older model.
Post by TheHogNL »
Currently the update script is not working on a Toon 1 due to a BUG in Eneco/Quby's own script.
This result in the message after downloading the update files: /mnt/data/update/upgrade-qb2.sh: line 855: syntax error: unterminated quoted string
They update this script today with this big.
So we now wait for quby to fix this.. shouldn't take long I guess for them to figure out :-)
Post by TheHogNL »
TheHogNL wrote: So we now wait for quby to fix this.. shouldn't take long I guess for them to figure out :-)
And why we wait if we can fix their bug... :-) newest root update script fixes their bug. So you can keep updating again.
Really? Is Quby deploying update scripts to production without even test it once? Really?
Unbelievable, better hire some students then for your product development.....
Funny enough, they probably don't notice because there is still update activity via your script... :lol:
brommetje
Post by brommetje »
When I try to update with the update script I got the following message.
eneco-001-132690:~# ./update-rooted.sh -v 5.0.4
Version: 3.53  - TheHogNL & TerrorSource & yjb - 25-1-2019
Forcing version: 5.0.4
Warning: upgrade script from source server is changed. Do you want to continue downloading the files (if not sure, type no and report in the forums)?
Is it save to continue?
Post by TheHogNL »
They change their code again (fixed the bug they had). New version 3.55 accepts this change, so go ahead and update.
brommetje
Post by brommetje »
Thanks @TheHogNL new version 3.55 is working fine I just upgraded my toon1 from 4.19.10 to 5.0.4.
Just another question I do not know if it has to do with the update to 5.0.4 but my brightness settings of the screen doesn't work any more.
Normally it set 50% (Helderheid 50%) dim after 1 min but is going to completely black.
In settings it is now set to Helderheid scherm actief 50% and dimstand 30% or 10% but is going always to completely black, It doesn't matter what I change/set.
Any suggestions?
Return to “Toon Firmware”
