Page 35 of 86
Re: Toon app: Afvalwijzer
Posted: Thu Nov 15, 2018 5:47 pm
by hdok
Don't know exactly when this started happening but I just get an empty list when retrieving information for Venlo. This worked fine before. Is there a log or anything that I can look into to see what happens?
Posted: Thu Nov 15, 2018 7:16 pm
by Toonz
Not really, probably means the website of your provider isn't working or they changed it.
Which waste collector are you using?
Posted: Thu Nov 15, 2018 7:22 pm
by hdok
Toonz wrote:Which waste collector are you using?
27 venlo.nl
Link to current site: https://www.venlo.nl/trash-removal-calendar/ical/PPPP/N
Posted: Fri Nov 16, 2018 10:06 pm
by Rudolf
Thermostat Mod now optional, nice! Thnx. :D
Posted: Sun Nov 18, 2018 1:34 pm
by Toonz
27 venlo.nl
seems to work fine, at least today.....(I tested with 5914LW, housenr 338)
Posted: Mon Nov 19, 2018 12:32 am
by hdok
That same address does not work for me :-(
Could it be that the venlo.nl started forcing HTTPS and that that does not work for my toon but it does for yours?
wget http://www.venlo.nl/trash-removal-calendar/ical/5914LW/338
--2018-11-18 22:10:33--  http://www.venlo.nl/trash-removal-calendar/ical/5914LW/338
Resolving www.venlo.nl... 83.217.76.213, 2a00:1c98:10:25::213
Connecting to www.venlo.nl|83.217.76.213|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://www.venlo.nl/trash-removal-calendar/ical/5914LW/338 [following]
--2018-11-18 22:10:34--  https://www.venlo.nl/trash-removal-calendar/ical/5914LW/338
Connecting to www.venlo.nl|83.217.76.213|:443... connected.
Unable to establish SSL connection.
Using the app store I can install other stuff just fine. I can reach other site from toon:
ping www.google.com
PING www.google.com (172.217.17.100): 56 data bytes
64 bytes from 172.217.17.100: seq=0 ttl=56 time=13.482 ms
64 bytes from 172.217.17.100: seq=1 ttl=56 time=24.430 ms
64 bytes from 172.217.17.100: seq=2 ttl=56 time=20.735 ms
I have removed and reinstalled WasteCollection (from the Toon store), apparently without errors:
>> Welcome to the ToonStore updater,
>> brought to you by the Toonroot Software Collective (TSC)
>> 2018-11-18 23:22:52 +0100 (pid 8433) _opkg.qb2-uni-9.9.99.script.sh qb2 uni 9.9.99 prepare
>> 2018-11-18 23:22:52 +0100 (pid 8433), status = preparing
>> Firmware version: 4.22.7, build 1273, rev 0.
>> System load     : 1.28
>> Free RAM        : 5168K
>> Flushing file system buffers and cache ...
>> Free RAM now    : 10844K
>> Hotfix for writing System Time to RTC
Hardware Clock before: Sun Nov 18 22:22:54 2018  0.000000 seconds
Hardware Clock after : Sun Nov 18 22:22:54 2018  0.000000 seconds
rm: can't remove '/var/lib/opkg/tsc*': No such file or directory
>> Installing wastecollection-4.8
>> Extracting packages from the following repo('s):
src/gz tsc1 http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-4.8
/mnt/data/update/_opkg.qb2-uni-9.9.99.script.sh: line 568: echo>> dependencies found: wget-1.12 cron-3.0 tsc-certificates-1.0.1: not found
src/gz tsc2 http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/wget-1.12
src/gz tsc3 http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/cron-3.0
src/gz tsc4 http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/tsc-certificates-1.0.1
>> configured opkg feeds:
>> opkg update
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-4.8/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-4.8/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc1.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-4.8/Packages.sig.
Signature check passed.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/wget-1.12/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/wget-1.12/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc2.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/wget-1.12/Packages.sig.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/cron-3.0/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/cron-3.0/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc3.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/cron-3.0/Packages.sig.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/tsc-certificates-1.0.1/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/tsc-certificates-1.0.1/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc4.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/tsc-certificates-1.0.1/Packages.sig.
>> Package cache: /mnt/data/update
>> opkg --cache /mnt/data/update install --download-only wastecollection
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-4.8/wastecollection_4.8-r0_qb2.ipk.
>> opkg --cache /mnt/data/update install --download-only wget
Package wget (1.12-r8.3) installed in root is up to date.
>> opkg --cache /mnt/data/update install --download-only cron
Package cron (3.0pl1-r8) installed in root is up to date.
>> opkg --cache /mnt/data/update install --download-only tsc-certificates
Package tsc-certificates (1.0.1-r0) installed in root is up to date.
>> downloaded:
80.0K   total
>> dropboxMessage wastecollection-4.8BRBRBekijk de berichten voor deze software voor informatie over eventuele configuratie.
>> no packages to be removed
>> 2018-11-18 23:23:03 +0100 (pid 8433), status = prepared
>> 2018-11-18 23:23:05 +0100 (pid 8608), status = execute
>> 2018-11-18 23:23:05 +0100 (pid 8608), status = executing
>> opkg --cache /mnt/data/update install wget
>> opkg --cache /mnt/data/update install cron
>> opkg --cache /mnt/data/update install tsc-certificates
>> opkg --cache /mnt/data/update install wastecollection
Installing wastecollection (4.8-r0) to root...
Copying /mnt/data/update/wastecollection_4.8-r0_qb2.ipk.
Running preinstall for wastecollection-4.8
Older installation detected.
Backing up previous settings ...
Running postinstall on /HCBv2/qml/qb/base/Globals.qml
grep: /HCBv2/qml/qb/base/Globals.qml: No such file or directory
Adding wastecollection to Globals.qml
sed: /HCBv2/qml/qb/base/Globals.qml: No such file or directory
running firmware version 4 - 22 - 7
Creating symbolic link /HCBv2/qml/apps/wastecollection to /HCBv2/qml/apps/wastecollection-4.8
Posting message
Configuring wastecollection.
>> deleting /tmp/dependencies_to_install.txt
>> deleting /tmp/packages_to_install.txt
>> reinstating cache handling (default 0)
>> deleting /tmp/install_status
>> deleting all in /mnt/data/update
>> (this may give some errors, no problem here ...)
>> 2018-11-18 23:23:13 +0100 (pid 8608), status = executed
>> Restarting qt-gui and hcb_config ...
Anything else I could check?
Posted: Mon Nov 19, 2018 9:07 pm
by Toonz
hdok wrote:That same address does not work for me :-(
hmm, I tested on a Toon 2 only, could be that that one has newer ssl root certificates than Toon 1.
Will have a look later this week (first Germany - Holland :-) )
I probably need to update the tsc-certificates package with updated root certificates.
to be continued......
Posted: Mon Nov 19, 2018 9:21 pm
by Toonz
How does your folder /etc/ssl/certs look like?
Posted: Mon Nov 19, 2018 9:59 pm
by hdok
/etc/ssl/certs# ls
Comodo_RSA_CA-01-2038-Quby_Countly-hcb_bxtproxy.pem
DigiCert_GlobalRoot_CA-11-2031-Buienradar-qt-gui.pem
DigiCert_Global_Root_CA-meethue-hdrv_hue.pem
DigiCert_Global_Root_CA.pem
GeoTrust_Global_CA-05-2022-Myfox_API-hdrv_hue.pem
GlobalSign_Root_CA.pem
GovernmentoftheNetherlands_G3.pem
Starfield_Services_CA-G2-12-2037-dpc_qutility-hcb_bxtproxy.pem
VeriSign_Class_3_Public_Primary_Certification_Authority_-_G5.pem
ca-certificates.crt
ca-certificates.crt.tsc_backup
comodo-rsa-domain-validation-sha-2-w-root.ca-bundle.pem
eneco.pem
Posted: Thu Nov 22, 2018 3:10 pm
by hdok
hdok wrote:
/etc/ssl/certs# ls
This is actually the CA that venlo.nl is using so , I assume the problem lies elsewhere...
Posted: Thu Nov 22, 2018 8:56 pm
by Toonz
can you check if the GovernmentoftheNetherlands certificate is included in the file ca-certificates.crt?
Posted: Sat Nov 24, 2018 12:19 pm
by hdok
:/etc/ssl/certs# grep MIIFdDCCA1ygAwIBAgIEAJiiOTANBgkqhkiG9w0BAQsFADBaMQswCQYDVQQGEwJO ca-certificates.crt
I think that is a yes
Posted: Sat Nov 24, 2018 4:28 pm
by Toonz
Is other https functionality working, like wget https://xml.buienradar.nl?
Posted: Sat Nov 24, 2018 4:45 pm
by hdok
--2018-11-24 14:39:26--  https://xml.buienradar.nl/
Resolving xml.buienradar.nl... 95.101.2.90, 95.101.2.78, 2a02:26f0:7b:389::5ddd, ...
Connecting to xml.buienradar.nl|95.101.2.90|:443... connected.
OpenSSL: error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol
That does not work, yet the buienradar app does work.
and I have installed the tsc package
Posted: Sat Nov 24, 2018 6:58 pm
by Toonz
slowly running out of options. Which version of wget do you have installed?
Check via 'opkg list-installed'
