Toon app: Afvalwijzer
hdok
Re: Toon app: Afvalwijzer
Post by hdok »
tsc-certificates - 1.0.2-r0
wget - 1.12-r8.3
Maybe you can share the contents of your /etc/ssl/certs ? (So I can replace mine with that)
Toon 2: wget - 1.16.1-r0
Toon 1: wget - 1.12-r8.3
seems fine on your end. My certs folder from toon 2:
certs.zip
(34.77 KiB) Downloaded 408 times
hdok
Post by hdok »
Unfortunately replacing my certs by the one in your zip file does not make any difference: stuff keeps working but afval kalender does still not work :-(
hdok
Post by hdok »
I forgot to put the paper boxes outside as the app no longer provides the information :-( So would like to get this working..
Anything else I could try? Look at?
If I understand correctly: it does work on another Toon1?
Even some pointers of where to look at are appreciated :-)
Smiggel
Post by Smiggel »
I have an issue with the app. I noticed that the app display plastic, etc as paper. I use mijnafvalwijzer.nl. Anyone else have the same issue?
hdok wrote:I forgot to put the paper boxes outside as the app no longer provides the information :-( So would like to get this working..
can you send me a PM with the contents of :/qmf/qml/apps/wastecollection-4.8/userSettings.json ?
Smiggel wrote:I have an issue with the app. I noticed that the app display plastic, etc as paper. I use mijnafvalwijzer.nl. Anyone else have the same issue?
Each city can have its own descriptions for waste categories, no standardisation in waste land unfortunately.
Can you send me a PM with a valid zipcode/housenr so I can have a check?
Smiggel
Post by Smiggel »
Done. :-) Thanks for looking into it.
Smiggel wrote:Done. :-) Thanks for looking into it.
Right, your local waste guy maybe made a typo, I don't know.
If you change the following line in WastecollectionApp.qml in the function wasteTypeMijnafvalwijzer(shortName) from
                        case "pbd": return 2;
into
                       case "pbd": return 1;
You should be fine. This is however conflicting with another city's data setting.
Will see if I can make the app more resilient against this.
For now you should be fine I think.
Smiggel
Post by Smiggel »
into
Yep! Updated it and now it works fine. :-) Thanks!
atlantica
Post by atlantica »
Hi Toonz,
I've updateds th wastecalendar version with a TrayIcon.
Is it posible to add this to the toon store?
The .zip file contains only the changed or added files....
WastecollectionWithTrayIcon.zip
(11.02 KiB) Downloaded 393 times
Regards
David
atlantica wrote:Is it posible to add this to the toon store?
Yes, I will include this in the next release which is then also fw 5 compatible.
Systray icons are treated differently in fw 4 and 5.
And all custom icons used by apps will need to be included in the resource files due to heavy changes in the firmware upgrade.
And I will make the display of the icon configurable in the settings as well to avoid overcrowded systrays ;-)
Thanks for the contribution by the way, much appreciated.
Kind regards,
hubble
Post by hubble »
I also have issue with some of the providers (http://www.venlo.nl and http://www.drimmelen.nl). (Like issue mentioned by hdok)
eneco-XXXXXX:/var/volatile/tmp# wget https://www.venlo.nl
--2018-12-18 17:32:56--  https://www.venlo.nl/
Resolving www.venlo.nl... 83.217.76.213, 2a00:1c98:10:25::213
Connecting to www.venlo.nl|83.217.76.213|:443... connected.
Unable to establish SSL connection.
I think those sites only support TLSv1.2 Seems that the current version of wget I'm running, is not supporting this.
opkg list wget
wget - 1.12-r8.2
HTTPS (SSL/TLS) options:
       --secure-protocol=PR     choose secure protocol, one of auto, SSLv2, SSLv3, and TLSv1.
Changelog (http://savannah.gnu.org/forum/forum.php?forum_id=8159)
Add --secure-protocol=TLSv1_1|TLSv1_2
openssl:
 -tls1_2       - just use TLSv1.2
 -tls1_1       - just use TLSv1.1
 -tls1         - just use TLSv1
openssl s_client -connect www.venlo.nl:443 -tls1_2			<== works fine
openssl s_client -connect www.venlo.nl:443 -tls1_1
eneco-XXXXXX:wget https://www.venlo.nl --secure-protocol=TLSv1.1
wget: --secure-protocol: Invalid value `TLSv1.1'.
Can somebody please upload a new wget version (at least 1.16.1) for Toon ?
Update: Currently running on 4.9.23 (will update asap to check if a new version of wget is introduced...)
hubble wrote:Hi,
aha, the TLS version can be the culprit indeed. Need to look into this (is not my direct area of expertise).
Post by TheHogNL »
curl -Nks https://www.venlo.nl
works fine...
also openssl itself, so the libssl's are ok.
No need to update wget for this, you can use curl if you want.
From the GUI, if it is not working we can't do anything about it because the GUI http request are compiled into the binary.
However from 5.0 there is new QT included so probably also support for TLS1.2
