Toon app: Afvalwijzer
Re: Toon app: Afvalwijzer
Post by TheHogNL »
Just tested on a 5.0 firmware toon1 and that works with venlo.nl waste calendar.
So just wait a few days/week for us to finish working on fixing the other issue's with 5.0 and for Eneco to release the 5.0 firmware officialy.
version 4.10 is available on ToonStore.
Changelog:
- installer is now firmware 5 compatible, it will patch the app on the fly when installed on firmware 5.
- added an option to show a waste icon in de systray (default option is 'off')
P.S. @Smiggel, you will need to apply your patch again, main focus was on firmware 5 compatibility in this release.
Kind regardz,
michel30
Post by michel30 »
Toonz wrote:
michel30 wrote:Hopefully you could also read out RD4
https://www.rd4info.nl/NSI/Burger/Aspx/ ... &nr=141&t=
I now the last time I had to save the web page but that did not work for chrome, firefox, safari only with internet explorer.
Unfortunately this is also not working with internet Explorer, The lay-out looks the same now as for chrome, firefox , safari etc.
Is on the to do list already :)
Hello Toon,
I don't now if it will go automatic in 2019 but if you click on the link you will see 2018 but on the top there is a button and you can move to 2017, 2018, 2019 and when you click on 2019 you will see Afvalkalender 2019
Hopefully RD4 will move the link to 2019....
last year it went automatically, can't remember having to do anything for that ;-)
ams123
Post by ams123 »
Toonz wrote:Hi all,
Changelog:
Kind regardz,
after update icoon stays on home schreen dim state and not go away anymore uninstall ans reinstall again not solf the problem
Toon solarpannels
glsf91
Post by glsf91 »
@Toonz
First, happy new year to you.
I see that provider 15 is not working anymore. The url is still the same, example: https://www.afvalalert.nl/kalender/8501ZJ/33.
I don't know if something has changed in the JSON but there is no output anymore on Toon.
I also don't see anything coming in /var/volatile/tmp/wasteDates.txt.
I use the latest version of the app and rebooted Toon already.
Can you take a look ?
Thanks
michel30
Post by michel30 »
Toonz wrote:last year it went automatically, can't remember having to do anything for that ;-)
Yes, today after refresh the app everything for 2019 is in.
Happy new year for 2019
glsf91 wrote:@Toonz
Thanks
I will have a look tomorrow but I guess your provider has switched off TLS 1.0 and 1.1.TLS 1.2 will be supported by Toon from version 5 onwards..
glsf91 wrote:@Toonz
They renewed their website certificate I guess. Need to find out which root CA's to copy to toon, stay tuned....
Kind regardz,
Toonz wrote:
glsf91 wrote:I see that provider 15 is not working anymore. The url is still the same, example: https://www.afvalalert.nl/kalender/8501ZJ/33.
If you extract the file from the attached zip file and copy the file DSTRootCaX3.pem to your toon in the /etc/ssl/certs folder (might need a reboot to become effective, not sure) it should be fine again.
I will include this certificate in future releases as well.
Kind regardz,
DSTRootCaX3.zip
(1.06 KiB) Downloaded 391 times
glsf91
Post by glsf91 »
Kind regardz,
Thanks. After restart GUI it is working again.
Fietspomp
Post by Fietspomp »
Hey, trying your app but it fails here.
I'm using "Mijn Afvalwijzer", but the tile stays empty.
Now I did some digging and when I enter the json url in my browser, it get a web page with "NOK"...
It works with other zipcode/number combinations.
Already emailed the Addcomm people but I got an angry repsonse, saying the JSON is for paying customers only! (Uhuh)...
Anybody else got this problem?
I can send the URL's in a private message for testing if you like.
Using the normal website it works by the way, so my Gemeente is supported.
Fietspomp wrote:Hey, trying your app but it fails here.
I can have a look if you can PM' me your URL (n.b. I am also using mijnafvalwijzer without issues).
It could be that their data is not yet properly populated (can differ city by city).
Happens often around year-end.
newwolf
Post by newwolf »
Toonz wrote:they probably changed the contents of the calendar file a bit.
Will check later this week (is fixable for sure)
Toonz,
Sorry I was to quick with my question so I deleted it again.
But you where quicker in reading it.
Area-afval.nl has to to downloaded by hand.
Greetz,
Jos
Arcidodo
Post by Arcidodo »
@toonz i edit the your app to add "oud papier" support for Omrin can you add it to the production version?
//read oudpapier entries
                i = aNode.indexOf("Oud Papier en Karton");
                m = aNode.indexOf("dates", i);
                for (k = 1; k < 13; k++) {
                    monthStr = ("00" + k).slice(-2);
                    i = aNode.indexOf('"' + k + '"', m);
                    n = aNode.indexOf("[", i);
                    m = aNode.indexOf("]", i);
                    var monthDates = aNode.substring(n + 1, m).split(',');  //get array for the month
                    for (l = 0; l < monthDates.length; l++) {
                        omrinAfvalbeheerDates.push(omrinYear + "-" + monthStr + "-" + monthDates[l].replace(/['"]+/g, '') + ",2");    //oudpapier
