Till now i just didn't notice the 2 in CO2
Thanx for pointing this out to me.
Hi Ed,esschenk wrote:Hello,
Ok, only my program skills are not so good.
So I look in to another way to put the sensor output in to Homeseer.
Thanks for repley
Ed
Nonetheless, I would welcome a similar CO sensor as well. Or a combined CO/CO2 sensor?AshaiRey wrote:Aaahhhaa!![]()
htpp://ipadresss:port/JSON?request=controldevicebyvalue&ref=3570&value=%s (3570 is the device id of your virtual device)
192.168.110.35:8080/JSON?request=controldevicebyvalue&ref=762&value=0
192.168.110.35:8080/JSON?request=controldevicebyvalue&ref=762&value=100
mhn wrote:I use Device string for custom values. I can't remember why. But your problem could be the reason.
This is all correct, but you need to configure the Status Text portion of the Status Graphics tab similar to what I have shown in the thread on the HS board.raymonvdm wrote:- Create a virtual device in HomeSeer (http://ip:port/deviceutility and press the green + in the rightside upper corner)
- Remember the Reference ID (for example 1036)
- Use this link in your webbrowser to test (htpp://ipadresss:port/JSON?request=controldevicebyvalue&ref=1036&value=15252
- Check the device value in HomeSeer (it should be 15252)
- If it is working use this link in your CO2 device (htpp://ipadresss:port/JSON?request=controldevicebyvalue&ref=1036&value=%s
Note: I did not get it working yet
Is switching between on and off but i cannot enter en custom value (yet)Code: Select all
192.168.110.35:8080/JSON?request=controldevicebyvalue&ref=762&value=0 192.168.110.35:8080/JSON?request=controldevicebyvalue&ref=762&value=100
Yes, unfortunately JSON does not work with status only device, but it's possible to create a simple ASP page instead of using JSON and then pass the value that way.raymonvdm wrote:Aha found it, and it is working. To bad that you cannot make it a status only device (prevent control using app or webinterface)
http://board.homeseer.com/showpost.php? ... ostcount=2
