CO2 Sensors
raymonvdm
CO2 Sensors
Post by raymonvdm »
I would like to add an CO2 sensor to my automation setup to measure the air quality in my house but i haven`t found the best unit yet. I have seen there are more people with this question so i decided to create a topic
Carbon Monoxide
Will kill you if it attaches to the oxygen in your blood. There are security sensors to save life, just like smoke sensors
Visonic MCT-442
Carbon Dioxide
Duco Handleiding
Siegenia Sensoair
Akatar
Re: CO2 Sensors
Post by Akatar »
rovinge
Re: CO2 Sensors
Post by rovinge »
freakstar
Re: CO2 Sensors
Post by freakstar »
I own this one, http://www.weetwatumeet.nl/product/1433 ... meter.aspx, with some scripting I was able to get the values in HS3. :)
The disadvantage of this one is that it has to be connected trough USB, so now there is an cable visible trough my livingroom to the hallway... Saw someone who was able to read this meter with a rPi, that would be an nice option to make it wireless.
I really can notice better air quality now I'm beter aware of it!
Here is an interesting topic also: http://gathering.tweakers.net/forum/lis ... es/1609383.
Re: CO2 Sensors
freakstar wrote:I own this one, http://www.weetwatumeet.nl/product/1433 ... meter.aspx, with some scripting I was able to get the values in HS3. :)
Nice!
so you read the C02 directly via usb frm the sensor, did you need to give a command to get the readings?
do you have a link of the RPI solution as well?
Thanks Pieter
freakstar
Re: CO2 Sensors
Post by freakstar »
Nice!
Thanks Pieter
No, there is some software needed, ZG View, got it here: http://www.zyaura.com/support/support_software.htm. It generates an CSV file per day with al the readings in it.
Script I use to get the value in HS3:
Sub Main(ByVal parm as Object)
	Dim Debug=0
	if Debug>0 then
		hs.writelog ("CO2", "Co2 logging activated")
	end if
	Dim currentDate As DateTime = DateTime.Now
	Dim devIdCO As String = "522"
	Dim devAddrCO As String = "F9"
	if Debug>0 then
		hs.writelog ("CO2", "Current: " & currentDate)
		hs.writelog ("CO2", "Month: " & currentDate.ToString("MM"))
		hs.writelog ("CO2", "Day: " & currentDate.ToString("dd"))
	end if
	Dim fileName = "C:\Users\freakstar\Desktop\ZyAura_USB_HUB_PC_software\" & currentDate.Year & "\" & currentDate.ToString("MM") & "\" & currentDate.ToString("dd") & ".CSV"
	'Dim fileName = "C:\Users\freakstar\Desktop\ZyAura_USB_HUB_PC_software\2015\12\19.CSV"
	if Debug>0 then
		hs.writelog ("CO2", "Filename: " & fileName)
	end if
	If My.Computer.FileSystem.FileExists(fileName) Then
		Dim line As String = System.IO.File.ReadLines(fileName).Last()
		if Debug>0 then
			hs.writelog ("CO2", "Read: "& line)
		end if
		Dim fields() As String = line.Split(",".ToCharArray())
		Dim fileTime = fields(0)
		Dim fileCO = fields(1)
		Dim fileTemp = fields(2)
		Dim fileHum = fields(3)
		if Debug>0 then
			hs.writelog ("CO2", "Time: "& fileTime)
			hs.writelog ("CO2", "CO: "& fileCO)
			hs.writelog ("CO2", "Temp: "& fileTemp)
			hs.writelog ("CO2", "Humidity: "& fileHum)
		end if
		'Set values
		hs.SetDeviceString(devIdCO, fileCO & " PPM, " & fileTemp & "C, " & fileHum & "% (" & fileTime & ")", True)
		hs.SetDeviceValue(devAddrCO, fileCO)
	Else
		hs.writelog ("CO2", "File not found.")
	End If
End Sub
Solution for the rPi: http://gathering.tweakers.net/forum/lis ... 9#45211989
Re: CO2 Sensors
thanks for the info!
vincenttor
Re: CO2 Sensors
Post by vincenttor »
not sure how the arduino sensors are , but they probably work with the hs3 arduino plugin and are not so expensive
simjoc
Re: CO2 Sensors
Post by simjoc »
I'm using the Netatmo CO2 sensors. Works perfectly with this plugin.
automatedhomeonline.com/HomeSeer3/hspi_ ... tatmo3.htm
ThinkPad
Re: CO2 Sensors
Post by ThinkPad »
Someone at Tweakers.net did an interesting project with a Itho CO2 sensor: https://gathering.tweakers.net/forum/li ... 6#45505066
(It seems to have a header that carries a serial signal, which he reads with a ESP8266).
The topic by itself is also interesting btw.
Re: CO2 Sensors
Hi guys
i got in contact with Vladimir :)
check this C02 sensor (update: also with MQTT now)
http://vair.anker-bg.com
http://vair-monitor.com
http://www.ebay.co.uk/itm/281890179126
there is also a version with a small lcd screen
it has got wifi and can upload to a site.
I got in contact with him and he made the upload url flexible so you can upload every x seconds (adjustable)
to for example 192.168.1.10:8080
also you can ask for a nice price and shipping is only around 3 euro.
He made this during a funded Kickstarter, check it out
Im getting 2 pieces soon and will be able to test it
co2 sensor.jpg (44.77 KiB) Viewed 35113 times
raymonvdm
Re: CO2 Sensors
Post by raymonvdm »
I also would like to test a unit :-) Did you order the version without display? And is vladimir also a forum member?
Re: CO2 Sensors
With display and wifi, no he is not a member yet, but mail him and mention me, then he knows which version firmware etc.
vlast3k
Re: CO2 Sensors
Post by vlast3k »
I am the producer of the "v.Air - CO2 Monitor". (@Pieter, thank you for posting about my device!)
If you would like to order devices - just send me a PM. On the page above you can find some more details and prices of the devices. Also you can have a look on the kickstarter campaign for the motivation of building the device.
If you have any questions (or even better - feature requests) - I will be happy to answer
Regards, Vladimir
stefxx
Re: CO2 Sensors
Post by stefxx »
Hi Vladimir!
Great project, nice CO2 meters. I might order one soon. One question: how accurate are your sensors (how are they calibrated)?
Thanks!
