Toon app: Afvalwijzer
Xavier
Re: Toon app: Afvalwijzer
Post by Xavier »
Toonz wrote:Hi all,
I propose the following solution for the provider rd4info.nl on a Toon 1 which is broken due to unsupported SSL functionality on a Toon 1.
On a Toon 2 the current functionality is working fine (rd4info.nl as wastecollector 17).
I created a second wastecollector id for rd4info (28) for use on a Toon 1 only.
As the data cannot be retrieved via QML you will need to download the rd4info calendar via wget with the option --no-check-certificates.
This can be done via a cron job and a simple script (explained in detail in the manuals section on the forum).
Steps to take:
1. login via SSH and create a folder 'waste' under root
2. install cron and wget if not already present using the manuals
3. the script to be scheduled running every week or so should contain (of course change the zipcode/housenr to yours):
wget --no-check-certificate "https://www.rd4info.nl/NSI/Burger/Aspx/afvalkalender_public_text.aspx?pc=6441kw&nr=141&t=" -O /root/waste/rd4info.txt
4. run the script at least once
5. install the new 4.17 app from ToonStore and switch to wastecollector 28
I will release version 4.17 shortly.
Kind regardz,
Going to try this, thanks!
bananenman wrote:Since it is always a good idea to implement your own way of sharing data (sarcasm mode) the people of https://www.acv-groep.nl/ decided to stop with submitting their data to afvalwijzer.nl and implement their own application.
They are now using http://www.acv-afvalkalender.nl/ which produces a lot of Json garbage.
Hi, it might be doable but it is a completely different approach from any other waste company (breaks the flow of the app a bit).
I will have a look when I have(make) time.... (no promises on any timelines though)
Kind regardz,
bananenman
Post by bananenman »
Toonz wrote: Hi, it might be doable but it is a completely different approach from any other waste company (breaks the flow of the app a bit).
Kind regardz,
Many thanks!
I've manually edited the JSON to match the structure used with the local file within the app. So I'm good for now, unless some dates change, I won't be able to pick up those.
Dewandelaar
Post by Dewandelaar »
Toonz wrote:Hi all,
version 4.14 is available in ToonStore with fixes for this year for meerlanden.nl and cure-afvalbeheer.nl
No other changes.
Kind regardz,
Tank you very much,
It works as before.
Kind regards,
Dewandelaar
bananenman
For all who use ACV Kalender...
Here is a VERY VERY dirty script to compile a file for local use in the wastecalendar app.
No comments on the scripting, I know it's dirty, max 1 hr spent on it..
Run in linux, (not on toon itself...) and if you find any other codes for the pickupType, please feel free to post them here.
Prerequisites:
install jq
install curl
#!/bin/bash
# waste.sh postcode number
# ./waste.sh 1200XX 55
# 0 = Restafval
# 1 = Plastic, metaal en drakpakken
# 2 = Papier
# 3 = Groente, fruit en tuinafval
# 4 = Snoeiafval
# 5 = Textiel
# 6 = Puin
# 7 = Klein Chemisch afval
# 8 = Grofvuil
# 9 = Kunststoffel
[ -e waste ] && rm waste
requestidstring=$( bash <<EOF
curl -s 'https://wasteapi.2go-mobile.com/api/FetchAdress' -H 'User-Agent: Mozilla/5.0 (X11; Linux x86_64; rv:64.0) Gecko/20100101 Firefox/64.0' -H 'Accept: application/json, text/plain, */*' -H 'Accept-Language: nl,en-US;q=0.7,en;q=0.3' --compressed -H 'Referer: https://wasteapi.2go-mobile.com' -H 'Content-Type: application/json;charset=utf-8' -H 'Origin: https://afvalportaal.2go-mobile.com' -H 'Connection: keep-alive' -H 'TE: Trailers' --data '{"postCode":"$1","houseNumber":"$2","companyCode":"f8e2844a-095e-48f9-9f98-71fceb51d2c3"}'
EOF
requestid=`echo $requestidstring | jq -r ".dataList[].UniqueId?"`
if [ "$requestid" == "" ]
then
	echo "Address not found, ACV does not service you region?"
	exit
fi
echo -n "Street found: "
echo $requestidstring | jq -r ".dataList[].Street"
echo -n "Number: "
echo $requestidstring | jq -r ".dataList[].HouseNumber"
echo -n "Number: "
echo $requestidstring | jq -r ".dataList[].City"
requestwastelist=$( bash <<EOF
curl -s 'https://wasteapi.2go-mobile.com/api/GetCalendar' -H 'User-Agent: Mozilla/5.0 (X11; Linux x86_64; rv:64.0) Gecko/20100101 Firefox/64.0' -H 'Accept: application/json, text/plain, */*' -H 'Accept-Language: nl,en-US;q=0.7,en;q=0.3' --compressed -H 'Referer: https://wasteapi.2go-mobile.com' -H 'Content-Type: application/json;charset=utf-8' -H 'Origin: https://afvalportaal.2go-mobile.com' -H 'Connection: keep-alive' -H 'TE: Trailers' --data '{"companyCode":"f8e2844a-095e-48f9-9f98-71fceb51d2c3","startDate":"2018-12-21","endDate":"2022-01-09","uniqueAddressID":"$requestid"}'
EOF
requestwastelist=${requestwastelist//T00:00:00/}
#echo $requestwastelist | jq -r ".dataList[5].pickupType"
loopcounter=0
pickupType=`echo $requestwastelist | jq -r ".dataList[$loopcounter].pickupType"`
while [ "$pickupType" != "null" ]
do
case $pickupType in
1) #GREEN from ACV
  echo "Processing GFT dates"
  pickupTypeToon=3
2) #PAPER from ACV
  echo "Processing PAPER dates"
  pickupTypeToon=2
10) #PMT from ACV
  echo "Processing PMT dates"
  pickupTypeToon=1
0) #REST from ACV
  echo "Processing REST dates"
  pickupTypeToon=0
4) #TEXTIEL from ACV
  echo "Processing TEXTILE dates"
  pickupTypeToon=5
esac
pickupDates=`echo $requestwastelist | jq -r ".dataList[$loopcounter].pickupDates[]"`
IFS=$'\n'
for Date in $pickupDates
do
	echo $Date,$pickupTypeToon >> waste
done
loopcounter=$((loopcounter+1))
done
cat waste | sort | uniq > waste-dates
mv waste-dates waste
Version 4.17 is available in ToonStore with fixes for rmn.nl as well as an alternative solution for rd4info.nl (see a few posts above).
Changelog:
- created a second waste provider for rd4info.nl (28) on a Toon 1 due to issues with their new website certificate.
retrieve the calendar manually as described on the forum via wget and a cron job.
On a Toon 2 this is not needed and you can continue using waste provider 17 for rd4info.nl
- made a change for a group of waste collectors which retrieves ICS files automatically.
It doesn't matter anymore in which format the provider sends the DATE field.
As this is a generic change for all waste collector below, I might potentially have created an issue elsewhere.
Compared to the previous release rmn.nl should work again now.
Impacted waste collectors:
12: "rmn.nl"
11: "denhaag.nl"
Kind regardz,
sanderjohan
Post by sanderjohan »
I am using version 4.17 on my Toon1 and have my own waste.txt file for all dates. I am having now problems with the presented information in the tile. It shows now"
Afvalkalender
't error_month
E error_month
- error_month
When I open the tile I see
<!--Don't - -
<!DOCTYPE - -
</body>
etc
Format of the waste.txt file is:
2019-01-02,1
2019-01-09,1
2019-01-09,3
2019-01-16,1
2019-01-16,0
2019-01-23,1
2019-01-23,3
Any idea what the problem can be?
Can you maybe add Veldhoven as a waste provider in the list?
Thanks in advance,
Sander
have you manually editied the waste.txt file? If so, then you need to select waste provider '0'.
Anyway, I will add veldhoven.nl. They use a known ICS format but just with their own unique waste descriptions.
Will be in a next release (not this week)
guustflater89
Post by guustflater89 »
Toonz wrote:Hi all,
12: "rmn.nl"
11: "denhaag.nl"
Kind regardz,
Works fine now for rmn.nl, thnx!
mariusbrouwe
Post by mariusbrouwe »
I tried to get the Afvalwijzer working with Rova by following the instructions provided: files.domoticaforum.eu/uploads/Toon/app ... ration.pdf.
The Afvalwijzer tile remains empty (white). My Toon is running version 5.0.4 and the Afvalkalender is 4.17.
mariusbrouwe wrote:I tried to get the Afvalwijzer working with Rova by following the instructions provided: files.domoticaforum.eu/uploads/Toon/app ... ration.pdf.
It still works over here, some notes:
- in the past I noticed that it makes a difference which browser you use. I have tested this with Internet Explorer on Windows 10
- In the menu choose 'File', 'Save As', save as type 'Webpage, Complete'
- I now see what has changed: the default name for the save file is now "Rova Inzamelkalender.htm" (was "Rova Afvalkalender.htm" in the past, use this filename therefore when saving the file)
- On Toon the file should be called: /root/waste/ROVA Afvalkalender.htm
mariusbrouwe
I didn't notice the fact that the webpage had a different name. It's working great now. Thanks!
hi all,
I just published 4.18 on ToonStore with an update for rd4info.nl users.
No need to update for other users.
Changelog:
- fix for rd4info.nl due to a change in handling of dates by javascript in the newer firmwares
Kind regardz,
Xavier
Post by Xavier »
Toonz wrote:hi all,
Changelog:
Kind regardz,
Thanks, this fix works!
sanderjohan wrote:Can you maybe add Veldhoven as a waste provider in the list?
Yes, it's done. One question: do you have a Toon 1 or a Toon 2?
On Toon 1 you will need to download the calendar via cron and wget as described earlier due to the server certificates which are not supported on Toon1.
Save the file in /root/waste/waste_calendar.ics and choose provider 29
On Toon 2 I can retrieve the file online (need to create a new waste provider for that but that's a 5 min job).
Next release will show up in ToonStore somewhere this weekend.
Kind regardz,
