Page 43 of 86
Re: Toon app: Afvalwijzer
Posted: Wed Feb 06, 2019 8:43 pm
by michel30
Toonz wrote:hi all,
I just published 4.18 on ToonStore with an update for rd4info.nl users.
No need to update for other users.
Changelog:
- fix for rd4info.nl due to a change in handling of dates by javascript in the newer firmwares
Thanks Toonz for this nice fix.
Posted: Thu Feb 07, 2019 2:40 am
by sanderjohan
Waste provider is set on provider '0' and it works ok untill I updated to 4.17. Also with version 4.18 still having the same issue.
Thanks for adding Veldhoven.nl
Toonz wrote:have you manually editied the waste.txt file? If so, then you need to select waste provider '0'.
Anyway, I will add veldhoven.nl. They use a known ICS format but just with their own unique waste descriptions.
Will be in a next release (not this week)
Posted: Thu Feb 07, 2019 2:43 am
by sanderjohan
Thanks for the effort.
At the moment I am still using the Toon 1, but somewhere next week I will get the Toon 2.
Toonz wrote:
sanderjohan wrote:Can you maybe add Veldhoven as a waste provider in the list?
Yes, it's done. One question: do you have a Toon 1 or a Toon 2?
On Toon 1 you will need to download the calendar via cron and wget as described earlier due to the server certificates which are not supported on Toon1.
Save the file in /root/waste/waste_calendar.ics and choose provider 29
On Toon 2 I can retrieve the file online (need to create a new waste provider for that but that's a 5 min job).
Next release will show up in ToonStore somewhere this weekend.
Posted: Sat Feb 09, 2019 12:05 pm
by b1r0n3r
Hi Toonz, getting back to viewtopic.php?p=82702#p82702 :-)
Here in Meppel, we can get a calendar download for a years worth of data as you allready indicated. I put that data into /root/waste/waste_calendar.ics (example attached
waste_calendar.zip
example file of waste_calendar.ics
(934 Bytes) Downloaded 387 times
), but sadly this is not being processed.
I did put in "Afvalverwerker: 0" but even after reboot of toon, "Komende afval ophaaldagen" remains empty.
What can I do to get this data loaded?
Posted: Sat Feb 09, 2019 2:30 pm
by Toonz
b1r0n3r wrote:Hi Toonz, getting back to viewtopic.php?p=82702#p82702 :-)
waste_calendar.zip
I am down with a sort of flue so try to limit my 'computertime' this weekend.
For now you can choose afvalverwerker 25, this will show your dates correctly, all categories are shown ok, except waste category 'VET-goed' isn't recognised.
What type of waste is that by the way? I might not yet have an icon for that.
I will include Meppel properly in the next release but it will not be in the coming days ….
Posted: Sat Feb 09, 2019 3:25 pm
by b1r0n3r
:-) indeed I got it to work with ID 25. - Thanks!
In WastecollectionApp.qml, under "function wasteTypeMeerlanden(shortName)", I added [case "VET": return 7;] as it basically resembles KCA waste plus old/broken electrical appliances.
Thanks again and get well soon ;-)
Posted: Tue Feb 19, 2019 12:19 am
by Toonz
hi all,
version 4.19 is published on ToonStore.
Changelog:
- added provider veldhoven.nl (provider 29). Manually download the calendarfile
- added provider meppel.nl (provider 30). Manually download the calendarfile
for both providers save it on toon as /root/waste/waste_calendar.ics and enter your provider id in the config screen
Posted: Wed Feb 20, 2019 7:02 pm
by MyZ
Hi Toonz,
Since I'm running on the latest firmware I have a problem with the status icon. When, for example, I put it "aan straat", the next morning the status has been reset. Any idea?
Posted: Wed Feb 20, 2019 7:21 pm
by Toonz
Don't worry, it is not a bug, it is just a not yet implemented function :-).
Around midnight the status is being reset indeed, but I am pretty sure this was also the case with previous firmwares.
Could it be that you were running a very old version of the afvalwijzer app? When upgrading to 5.0.4 all installed apps have been refreshed to the latest version automatically to ensure compatibility with firmware 5.
I will see if I can fix it in the next release.
Posted: Wed Feb 20, 2019 8:10 pm
by MyZ
Running on 4.18 of the Afvalwijzer. Didn't had it in previous releases. Anyways, thnx! Would be nice to have this "fixed" :)
Posted: Wed Feb 20, 2019 11:46 pm
by sanderjohan
Toonz wrote:hi all,
Changelog:
Hi Toonz,
Thanks for the effort. Just installed the update and it works great.
Posted: Wed Mar 06, 2019 11:46 pm
by PowerAce
Good evening Toonz,
I'm experiencing some problems using the wastecollection app. I'm not sure whether it is related to the new 5.0.4. FW or not but i hope you can help me out. After updating my Toon (v1) to the latest FW i noticed the waste collection app wasn't updating anymore. So for this reason i uninstalled it by use of Toon Store. After deinstalling i tried to install the Waste Collection app 4.19 again. Toon shows me the download icon in the upper status bar but there after nothing happens unfortunately. The status in Toon Store is still "available" and hasn't changed to "installed".
Now i tried to install the ipk file manually but that results in a few errors see log below:
# opkg install wastecollection_4.19-r0_qb2.ipk
Installing wastecollection (4.19-r0) to root...
Running preinstall for wastecollection-4.19
Older installation detected.
Backing up previous settings ...
Cleaning garbage....
Done with preinstall sript
Configuring wastecollection.
Running postinstall on /HCBv2/qml/qb/base/Globals.qml
Adding wastecollection to Globals.qml
sed: /HCBv2/qml/qb/base/Globals.qml: No such file or directory
Creating symbolic link /HCBv2/qml/apps/wastecollection to /HCBv2/qml/apps/wastecollection-4.19
Firmware version 5 or greater detected, changing app for firmware compatibility...
Posting message
Indeed it seems that my Globals.qml file is gone. Do you have an idea what went wrong and how to get this nice app up and running again?
Thanks a lot
Posted: Sat Mar 09, 2019 11:22 am
by Toonz
because of the removal of the old wget 1.12 from this forum (which is superseded by a much better native wget in firmware 5.0.4) the installation of the waste collection app failed.
You will see the download icon appears but not else happens.
This is because it had a dependency on the old wget version which it couldn't download anymore.
I have now removed this dependency and version 4.19 can be installed again via ToonStore without isssues.
So, go to ToonStore and try installing/upgrading the app again.
Let me know if you still encounter issues...
Posted: Sat Mar 09, 2019 11:59 am
by yjb
Confirmed, this is now working again and I was able to upgrade to 4.19. Thanks for fixing it.
Posted: Sat Mar 09, 2019 8:57 pm
by glsf91
I just updated to 4.19.
Now the panel with text is blinking each few seconds. Looks like it is writing the text lines repeatedly to the screen.
The same happens after Opslaan when changing instellingen.
Restart GUI makes no difference.
After Herstart Toon, de box stays empty. Also after Opslaan instellingen. No text into the box, also no header that is getting data.
Toon is on 4.19.10. I use provider 15 and a local file which is also not shown.
