I am trying HS3 with the Plugwise plugin but the value's from the stretch are instead of 19 watt 1.9 watt?
The log states DEBUG3: Stretch information retreivement -- Stretch appliance current usage = 1775
So for unknown reason i have the decimal set wrong.
Any way to change this? In HS2 u could add some things to make the value correct but i can't find it in HS3.
HS3 with Plugwise plugin - Wrong value's from Stretch
Re: HS3 with Plugwise plugin - Wrong value's from Stretch
You can post in Dutch here
According to you name you seems to be Dutch, but here's my answer in English, to be sure you understand this.
If found the issue
If you sent me a PM with your email address, I will sent you a fixed file !!!
/Rien
If found the issue
/Rien
PM is verstuurd
Ik heb je ook al een mail gestuurd, gisteren ofzo....PietjeNL wrote:PM is verstuurd
Heb je die wel gehad ?
Nee niets gehad
