Updated RFXmngr and firmware
b_weijenberg
Post by b_weijenberg »
the latest RFXmngr supports now firmware versions 81, 181 and 234
Firmware changes: FW release 433_81/181/234 02-01-2015
Chamberlain CS4330CN added
SelectPlus200689101 White Chime added (Action NL)
smartwares improved
Meiantech and Oregon3.0 received if both enabled
Conrad RSL receive improved
Rubicson stektermometer (2nd version) high temp corrected
Eurodomest moved to Type2 firmware (ARC can be used instead)
Philips SBC moved to Type2 firmware
Media Mount moved to Type2 firmware
Ninja removed from Type1 firmware
b_weijenberg
Re: Updated RFXmngr and firmware
RFXmngr chime type corrected
Firmware changes: FW release 433_182/235 06-01-2015
Prepared for SelectPlus200689103 Black Chime (Action NL)
SelectPlus200689101 RF corrected
b_weijenberg
the latest RFXmngr supports now firmware versions 81, 182 and 235
SelectPlus200689103 Black Chime added (Action NL)
Siewert308SW
Post by Siewert308SW »
Already spoke to you about my Byron B series Chime by mail last week.
Unfortunately i broke it and needed a new chime.
I saw rfx now supports the Action Black chime and while i was at the Action Store i bought me one, cheap and supported ;-)
Once i got home i tried with the latest rfxmngr to see if it got any signal.
Unfortunately the RFX doesn't get any incoming signal with firmware 235 on my RFXtrx433E.
To be sure i got the correct hardware setting i enabled them all at first.
Them revered by unchecking them one by one until i only got undec left.
Am i missing something.
Hardware:
RasPi B2 - RFXtrx433E
1x Youless ls110
2x Opus XT300 - Temp/Hum
4x Cresta TX320 - Temp/Hum
25x KaKu switches
1x KaKu Dusk Sensor
10x KaKu Contacts
4x KaKu AWST-6000 PIR
1x Selectplus Chime
4x KD101 smoke detectors
DIY Garden Irrigation
b_weijenberg
Try with only the ByronSX protocol enabled in RFXmngr.
Please contact support if nothing received.
b_weijenberg
Siewert, is the this type indicated on the black chime 200689103 ?
Please contact RFXCOM support.
A new RFXmngr is available at http://rfxcom.com/Documents/RFXmngr.zip
Siewert308SW
b_weijenberg wrote:Siewert, is the this type indicated on the black chime 200689103 ?
Sorry for my late reply, although checked i didn't get any notification of a new reply.
But yes, it's indicated as black chime 200689103
Will try the new mngr when i get home this evening.
Also will contact him by mail, i first thought this forum was for rfx suport also as i saw him posting here ;-)
Thx for your reply...
Hardware:
1x Youless ls110
25x KaKu switches
1x KaKu Dusk Sensor
10x KaKu Contacts
1x Selectplus Chime
Siewert308SW
Just wanted to let you know i got it working.
Bought a second Black 200689103 as i suspected the old one is slightly of frequency.
Guess what? The new is detected right away.
Fun part is, no i control two chimes with one button ;-)
Hardware:
1x Youless ls110
25x KaKu switches
1x KaKu Dusk Sensor
10x KaKu Contacts
1x Selectplus Chime
b_weijenberg
Updated RFXmngr 12.0.0.24 (Imaginetronix enable added)
FW release 433_83/183/236 14-01-2015
CM180 instant power reported
Viking sensors corrected
Imagintronix enable added
Receive of ARC and Lighting4 with LaCrosse enabled improved
esschenk
Post by esschenk »
Witch device must i select to add this chime.
I select the Byron but there is only room for a 2 digit device code.
The remote has 4 digits.
I have read the manual 2 times but cannot find the answer.
Thanks in advanced.
Packettype= Chime
subtype= SelectPlus200689103
Sequence nbr = 6
ID = 1537
Signal level = 5
Ed
b_weijenberg
Use the latest RFXmngr version 15.0.0.0
esschenk
Post by esschenk »
Thanks for the answer
Maybe i dont understand it
How can i put this device in to Homeeer !
I have the latest Firmware and Rfxmngr
Ed
b_weijenberg
The SelectPlus will be supported in the next version of the HS3 plugin.
Mai Pensato
Post by Mai Pensato »
I'm also interested in the SelectPlus chime from Action. How is het sound volume ? Is it loud enough, do you hear it when you are in another room in the house ? And what about the reach/distance, is it comparable with Coco (KlikAanKlikUit) ?
Many thanks in advance for sharing your experiences.
emvee
Post by emvee »
How is the sound volume ? Is it loud enough, do you hear it when you are in another room in the house ?
The volume has three levels and for all three levels I can hear it in the other side of the house.
Not sure about Coco but for me it can pass 10 meter with one concrete and one gypsum block wall.
