I don't know if it is the good forum to post support for RFXTrx433, but I bought this Led controller
http://eud.dx.com/product/432w-wireless ... L9l2iuG8Ro
I cannot see the signal even with Type 1 and 2 firmaware, and Lightwave/AC or Lighting 4 protocl enabled.
There is an id written on the device and I try to send signal with Rfx manager, but I'm not sure that I put the right ID.
My ID is like 12345 (5 digit), so I put it like this in Rfx Manager : 01 23 45
Is it right?
Is there another way to catch signal or test emmiting?
Thank you very much
Finding ID with Lightwave AC / Lighting 5 devices
- b_weijenberg
Re: Finding ID with Lightwave AC / Lighting 5 devices
This device is not supported by the RFXtrx433(E)
See chapter 2.2.2 in the RFXtrx User Guide for the list of supported devices!
Supported are:
RGB LED strip driver dx.com
- http://www.dx.com/ order nbr: 130913, 67412
receiving of the 2 battery remote is only supported in Type2 firmware and is used to get the RGB remote ID.
Supported are:
Ok.
My fault : I'd see the same remote, so I supposed it's compatible.
Is there a future possibility that it will be compatible? (In future FW upgrade?) or not?
Thank you
Thank you
