Allright i followed this procedure:
1. Position the Z-Stick within 1 foot of the device you wish to add, and press the Z-Stick button once. A circular blue
light around the button will begin to blink slowly, indicating the Z-Stick is now in “add mode”.
2. With the Z-Stick in add mode, press the control button on the Z-Wave device you wish to add. (for fibaro module 3x S1 push). The blinking blue
light will turn solid blue when the device is successfully added.
3. After 2-3 seconds, the Z-Stick will go back into add mode again to allow the inclusion of more
Z-Wave devices. Press the Z-Stick button once to exit add mode.
and led turned solid blue.
When i try to import via:
1. To access all the features in your Z-Stick, your HomeSeer system will need to be running software version
2.3.0.121 or later. Updates are available on the download page of our main website (homeseer.com/downloads)
or in the beta releases forum of our message board (board.homeseer.com).
2. Start your HomeSeer system and from the web interface, click “Setup” button and then the “Interfaces” tab.
3. Under the heading Built-In Interfaces, select “Aeon Labs USB Stick” from the drop down menu and fill in the
correct COM port number as displayed in your Windows device manager (see step #2 under “Installing the USB
Interface” section above).
4. Click the green “Save” button at the bottom of the page; HomeSeer will then initialize the Z-Stick. Once the unit is
initialized, it is ready to be used.
5. Now click the green “Manage” button in the ‘built-in interfaces’ section on the interfaces page.
6. The “Controller Functions” page will now appear. Click the “Import Devices” button at the top of this page and wait
for all devices to import.
only one device is found and that was the duwi dimmer that has been added before.
Must be something simple, but just not seeing it.
Any help would be great.
how to add fibaro switch to aeon stck and homeseer 2
Re: how to add fibaro switch to aeon stck and homeseer 2
My guess 3x S1 push isn´t fast enough.
That was my problem before I "got it into the hand".
Regards
Morten
Regards
Morten
'fast' in the meaning like 3 clicks in far less then a second
That's fast. Wil try at the end of the week. Thanks
** edwin **
YES! It is working. You have to be really fast in pushing 3 times.
Further more, the fibaro module are not default mono-stable but bi-stable set (option 14 on 1) that does not really help in interpreting what is going on. Also the fact that you have to puch the B button also 3 times to include, manual suggests only 1x.
** edwin **
Edwin2008 wrote:YES! It is working. You have to be really fast in pushing 3 times
Your now ready for the toggle olympics..
