Cuberox on Kickstarter
On this Forum we can discuss interesting Kickstarter like smartthings and gadgets
I backed this kickstarter
the Cuberox has Nodejs and can also run MQTT
https://www.kickstarter.com/projects/14 ... t/comments
Cuberox is a computer, that has six 16x16 pixel displays. When turned off it looks like just a simple cube, but it actually hides a full-fledged computer inside.
Cuberox is powered by Linux operating system that allows users to run different applications on each side of the cube, and developers to write their own applications with almost unlimited possibilities, thanks to API written on JavaScript.
This cube is not afraid of water, because its body has not a single hole and it even is wirelessly charged.
You can control what you see on a screen by changing cube's position - for example, you might be looking at the weather in Los Angeles on one of the screens, but should you rotate the cube in a certain direction you will see the weather in New York.
Cuberox also boasts a wireless station that extends the functionality that cuberox could be missing. The station has embedded speakers and a multi-color smart back light, which also is used by applications to notify users of upcoming events.
vincenttor
Re: Cuberox on Kickstarter
Post by vincenttor »
That is a cool gadget, first thing i thought is this would look nice on the table.
It is 199 USD , probably cheap for what you get.
Pity that i have some other things to buy and pay first :roll:
Thanks for the share !
the cuberox will get voicecontrol also
check this online...funny
http://www.cuberox.com/online/
Return to “Kickstarter, Indiegogo and other crowdfunding related smartthings”
