After my good old PC died, I managed to re-install HS2 Pro on a new PC without problems, including my database.
But how to re-install the Z-wave stick? I can't find any driver information and HS2 Pro is not recognizing it. This is driving my nuts. My knowledge from 4 years ago (initial installation) has left me..
Any tips much appreciated! Thank you in advance
Olof
HS Log entry:
..Warning .. In Z-wave init(A), no response getting initialization information
Details:
Stick: Aeon Z-stick S2. Model DSA02203-ZWEU
HS: HSPRO version 2.50.52
How to re-install the Aeon Z-stick??
Re: How to re-install the Aeon Z-stick??
Hi.
The newest driver in my folder is this one http://up-it.dk/dl/5v2/
But I don't remember if there is a right and a not so right driver.
Regards
Morten
Regards
Morten
Hi Morton,mhn wrote:Hi.
Regards
Morten
Thanks for your quick reaction and for providing the right driver!
I checked your driver with the Aeon website corner which was just provided on homeseer forum and your driver version matched! So it must be the correct driver.
Driver installation went fine. I verified it by trying to install the same driver twice and got a confirmation message the 2nd time that the driver is already present on my PC.
But....
What I tried inside Homeseer:
1. Tools/Z-wave network audit -> ofcourse it couldn't find anyting
2. Setup/Interfaces/Status/Manage/Advanced functions/Restart Interface --> " Restart is complete. Getting controller information. Done" -- > Log still giving me the same message...
3. Setup/Interfaces I then tried to change the Com port numbers. I have 3 usb ports so I tried all three numbers 1,2,3. and each time step 2 again. Still no solution.
Arrrghh
Morten & others, if you have any thoughts please let me know.
Thanks in advance
Olof
Found it!!
It had to do with the Com port number in Setup/Interfaces. Even though I only have 3 USB ports, the Z-stick apparently sits on Com 4 on my new PC. (on the old PC it was Com port 3).
What a relief. Now I can focus on the other re-install issues (Plugwise, IPPower). I hope I do not have to go through another HS re-install for a very loooong time.
