Node Id of the blocking device (Parameter Number 6, Parameter Size 1)
Id of the device which commands would be interpreted not as Open/Close, but as block/unblock. Usefull with door opening detector: if the door is open, block the blind not to break shades while they move.
Value Description
0 Disabled (Default)
1 — 232 Node Id
On which command from blocking node to enable the protection (Parameter Number 7, Parameter Size 1)
Defines which command from blocking device to interpret as closed door and hence, unprotected.
Value Description
0 on On (Default)
1 on Off
It is also possible to disconnect the COM connection using an additional relay but how did other people fixed this?
