Oregon scientific WTGR 800
Post by Harry »
is deze compatible met de RFXCOM reciever
http://www.oregonscientific.be/nl_prod_ ... prodid=456#
kan ik met deze sensor de windgegevens in de homeseer charts loggen ?
b_weijenberg
Post by b_weijenberg »
Yes, the WTGR800 can be received and can be displayed on the RFXWeather chart.
For the complete list of supported Oregon Scientific sensor see: http://www.rfxcom.com/hsrfxcom.htm
Snelvuur
Post by Snelvuur »
didn't know that one yet, it looks more robust then other single devices.
Bastiaan
Post by Bastiaan »
Best place to buy this one in NL?
Snelvuur
Post by Snelvuur »
You can get that one with a weather station normally i think..
I also saw this one at http://www.hetweerinbleiswijk.nl/apparatuur which they used a small linux device to collect the data and such, pretty nice setup.
anyway a quick look on google http://www.klokkenfabriek.nl/index2.php ... =produkten , but this is a total set i think.
Bastiaan
Post by Bastiaan »
Checked with Futurumshop.nl if they were able to get it for me but they couldn't.
Mailed Oregon for local resellers but no answer....
Wima
Post by Wima »
http://www.vitalitools.nl/nl/oregon_sci ... .php?btw=1
Even the genious ask questions.
Bastiaan
Post by Bastiaan »
Did you ask info from them? If so can you post their reply?
Bastiaan
Bastiaan
Post by Bastiaan »
Ok I got the last one from vitalitools but they will have more in the coming days.
Very nice contact/service!
Bastiaan
Post by Bastiaan »
Got my unit on the roof but my wind speed reading is not working. Everything else works fine.
I have placed the wind 'rotor' on top of the unit but is seems very loose. Can anybody with the WTGR800 confirm that this is normal? I don't need to push it down on a lock or so? It all seems pretty fragile.
Thanks, Bastiaan
Wima
Post by Wima »
You just remove the silicon protection (for the rain) then losen the screw, put the wind rotor back on top and fasten the screw again, then place back the silicon protection. The rotor turns without friction, because the readings are transmit by 2 magnets. The screw protects the rotor from blown of of the meter. I think in your case the magnets are not close enough to the meter itself.
Wil
Bastiaan
Post by Bastiaan »
Thanks! Exactly what I needed to know :-) works fine now.
Post by Harry »
i don't get an signal from the divice,olso try'd the rfxmonitor. recieve nothing.do i need to do extra things.
b_weijenberg
batteries in the sensor ;-)
reset of the sensor does not help?
Enable All RF protocols in the receiver to be sure that the Oregon protocol is enabled.
Does your receiver version already support the Oregon 3.0 protocol?
RDNZL
Post by RDNZL »
The girls/guys from vitalitools also ship very fast, ordered a PCR800 rain sensor this week, next day at the door!
