Please add output of PS=1 to otmonitor webpage
ThinkPad
Post by ThinkPad »
Would it be possible to let the 'command' page display output of the PS=1 command?
Now it doesn't work when i call http://localhost:8080/command?PS=1
It shows the output of PS=1 in the otmonitor log, but unfortunately not in the webpage output, it only shows PS=1 again....
When showing the output from PS=1 also on the webpage output, i could scrape the contents much easier with something like a PHP-script and store it in my own application stuff. For now the only option seems to be to open a socket to the OTGW directly, which is much more work and quite difficult, especially when the OTGW is connected to a different physical machine.
Please add this option if possible :D
timoline
Re: Please add output of PS=1 to otmonitor webpage
Post by timoline »
I'm not sure it shows the info you want....but maybe you can use the json output?
http://<ip>:<port>/json
ThinkPad
Post by ThinkPad »
timoline wrote:I'm not sure it shows the info you want....but maybe you can use the json output?
That's perfect, thank you very much!
Too bad that such things are not documented at all @ the official website... would have saved quite some time if i found this out earlier.
Agreed, the documentation at the web site is horrible and incomplete. I might just as well shut it down.
timoline
Post by timoline »
yes please shut it down...it's rubbish...
Ok,now serious....you did/do an amazing job by making this all possible, great great great respect :!:
