WDT Reset! OTGW 4.2.5
sincze
Post by sincze »
I've been reading through the forum about this message "WDT Reset!".
domoticaforum.eu/viewtopic.php?f=75&amp ... wdt#p71966
The PIC used in the gateway has 4 types of reset: Power on reset, External reset, Brown-out reset, and Watchdog timer (WDT) reset. In case a WDT reset happens (due to a firmware bug), the gateway will report "WDT reset!". I didn't put in the code that would be needed to differentiate between the other reset types.
domoticaforum.eu/viewtopic.php?f=75&amp ... set#p60738
My Gateway stopped working at 02:58:38 this morning.
This forum tells me it is a watchdog error regarding a firmware issue.
Anything I should monitor to see if we can help the developer solve the issue?
I had some problems with my OTGW before, however after changing the wiring it does run as it should :D
WDT Reset
WDT Reset
sincze
Re: WDT Reset! OTGW 4.2.5
Post by sincze »
Hi Moderator.
Can this post be moved to the appropriate sub-Forum (Opentherm Gateway):
http://www.domoticaforum.eu/viewforum.php?f=75
Sorry for inconvenience. :oops:
