Ledcontroller H801 upgraded MQTT from Aliexpress
Moderator: Mversluis
vlast3k
Post by vlast3k »
This post is about an upgrade to the popular H801 LED Strip Controller available for <10 eur from Aliexpress:
http://www.aliexpress.com/item/RGBWW-St ... ace2498d25
Together with Pieter (bwired) we did some modifications to the device and created a new firmware with the following features:
What has been added is:
1. Pre-Soldered USB-2-Serial adapter, to allow connection to the vThings Chrome Configuration App, to allow setting up Wifi, HTTP or MQTT connection
2. Ability to open an HTTP Web Server and allow controlling via HTTP Request
3. Ability to connect to an MQTT Server receive commands for LED Colors, and publish status updates
4. Ability for Over-The-Air update in case of new features or bugs
What has been removed:
- the original firmware that allows connection from an Android phone, opening a Wifi Hotspot and having some effects
If you are interested, in using this functionality you can:
- upgrade the module yourself: the firmware is open source and available freely here: https://github.com/vlast3k/vThingCO2 (i will put there some additional details on building ansd flashing later)
- send your device to me to upgrade it for you: price for the service is 10 eur and then 4-5 eur for shipping back
- or you can buy the device from me instead of aliexpress - in this case it costs 20 eur, and you get it within a week :) (but i have only 3-4 left and waiting for the new ones to arrive)
Re: Upgraded H801 Led Strip Controller from Aliexpress
This works perfectly at the moment.
With this controller you can connect 5 ledstrips or 1 rgb and 2 white.
Via http or mqtt you can control every ledstrip channel indipendly.
What is also a very nice feature is that you have a full status report via MQTT,
for example if you set the values via http or mqtt, after the values are set the status is broadcast back to the MQTT server.
So a cheap led controller with status is great! :)
Also asking for status can be done and it will broadcast the status every 2 mins.
We are still making small changes but it looks like this:
Ask for status of controller 1: client.publish('command/led/1', 'status');
status:
{"red":20,"green":1,"blue":2,"w1":30,"w2":10,"ver":"v1.11.1"}
set the desired values:
client.publish('command/led/4/Color', '20;1;2'); // set rgb (0 to 100%)
client.publish('command/led/4/W1', '30');
client.publish('command/led/4/W2', '10');
http command to set values:
http://10.0.0.123/?color=10;0;5&sw2=0&sw1=0
raymonvdm
Re: Ledcontroller H801 upgraded from Aliexpress
Post by raymonvdm »
I think i just need to test one of these :-)
Re: Ledcontroller H801 upgraded MQTT from Aliexpress
Ordered 2 also to see what this is all about.
If it is what i think it will do then i will be happy. :)
raymonvdm
Post by raymonvdm »
In the past i purchased an ESPLight. Is it also possible to attach it to my MQTT broker ?
http://esplight.fridgefire.nl/doku.php
I`m currently controlling it using netcat
echo "?pin=5678&effect=0&brightness=99&var0=216&var1=247&var2=255" | nc -u -4 -q1 192.168.110.62 1337
Can you explain what to do to update the firmware yourself.?
I've added terminals for the jumper and the serial cable already but what next?
I probaly need a serial-to-usb converter. Any advice on that one?
Is there any thing to consider when setting up the Arduino IDE for programming?
I want to run this to be controlled via HTTP not via MTTQ
In the INO i see some settings to be filled in
Would these settings be the correct one
PubSubClient *h801_mqttClient = server;
IPAddress IPAddress(0,0,0,0); // my ip address to use instead of 0,0,0,0
boolean h801led = false;
r_255
Post by r_255 »
You could use espeasy and a ftdi serial converter ( just make sure you use a 3.3v version )
I still had one laying from the jeenode workshop ( al these 3.3v sensors and stuff work fine on the esp with out level conversion )
http://www.esp8266.nu/forum/viewtopic.php?t=626
i got that one running on my desk...
Flashing is quite simple....
http://www.esp8266.nu/index.php/ESPEasy#Get_started
Like you mention you did add the pinheaders and jumper pins. Add the jumper only when you are flashing...
I guess you did setup the arduino ide and did install the esp8266 files thru the boardmanager ?
well then you should be set to compile.
Download espeasy
https://github.com/ESP8266nu
open the espeasy and make sure you got it stuffed in the right folder
Open up easpeasy.ino and add your own wifi credentials and endpoint ( ha server )
compile & flash it...
Open up the terminal window in arduino ide and type reset ...
( device should reset and reboot )
Now scan your network for a espresif device to get the ip..
Now login to the webserver on the esp by typing the ip in your browser and you are ready to go...
oh and you dont have to set much or set a device
Gpio if i am right are :
redPIN 15
greenPIN 13
bluePIN 12
w1PIN 14
w2PIN 4
Controlling goes like this :
PWM control
To set a certain PWM level:
http://<ESP IP address>/control?cmd=PWM,<pin>,<level>
Our you could try to use the milight emulation... the only thing you need to do to get that working is donwload the rgbw plugin and add that to the folder before you compile
_P105_RGBW.ino is the plugin name and can be found here... ( look in the plugin playground )
Why espeasy ? Because its very tweakable..... one guy over there uses the 5th white pwm channel as ir out !
or swap out the serial pins for a lux sensor or what is your need... as firmware updates ota work fine here.
Have fun! :D
vlast3k
Post by vlast3k »
AshaiRey wrote:Can you explain what to do to update the firmware yourself.?
Apart what r_255 said, keep in mind that some batches (at least mine) had a problem that the RX and TX pins are wrongly named, so you should make sure to connect RX to RX and TX to TX
For usb2serial converter any one should be fine
If you are going to use my code - nothing specific is necessary. If you do not configure MQTT in the Chrome utility - only the web server will be started
just - before building it you need to modify
You can flash the latest working binary directly using:
C:\develop\arduino-1.6.7\hardware\esp8266com\esp8266/tools/esptool/esptool.exe -vv -cd nodemcu -cb 256000 -cp COM15 -ca 0x00000 -cf h801_binary.bin
And download the binary from here
http://anker-bg.com/vlast3k/h801/latest.bin
(you need to have installed the ESP8266 tools of course)
Building it from scrarch - i still haven't had time to write detailed instructions, but basically
edit :
https://github.com/vlast3k/vThingCO2/bl ... ingCO2.ino
and in the beginning include
#define VTHING_H801_LED
and remove
#define VTHING_STARTER
#define SAP_AUTH
I use the same FW on all devices and each uses different features.
Also whatever firmware you build for the H801 make sure to select the board Generic ESP8266 Board , and then Flash Size: 1M (128mb spiffs)
And all libraries i use are here:
https://github.com/vlast3k/Arduino-libraries
if you do not plan to configure it via the Chrome App and Usb2serial converter - then it is better to use the ESPEasy as r255 proposed as it is more versatile
Thx for the detailed answers.
Some of it are still abracadabra for me but when i see it will ring a bell for me i am sure.
I'll keep you updated.
raymonvdm
Post by raymonvdm »
I just found this one, and made some pics for reference
I just added the pin headers for the programming, but the most difficult part is to get the Arduino IDE running. I just installed it and added the following link for board managers
http://arduino.esp8266.com/stable/packa ... index.json
But i cannot figure out yet how to program the board. I think i have all the parts necessary but i still get the following errors
Arduino: 1.6.8 (Windows 7), Board: "Generic ESP8266 Module, 80 MHz, 40MHz, DIO, 115200, 1M (128K SPIFFS), ck, Disabled, All"
sketch\H801.ino.cpp.o: In function `printVersion()':
C:\Users\Raymon\Documents\Arduino\H801/H801.ino:240: undefined reference to `handleWifi()'
C:\Users\Raymon\Documents\Arduino\H801/H801.ino:240: undefined reference to `processUserInput()'
sketch\H801.ino.cpp.o: In function `activeWait()':
sketch\H801.ino.cpp.o: In function `operator<< <char const*>':
C:\Users\Raymon\Documents\Arduino\libraries\Streaming/Streaming.h:34: undefined reference to `processUserInput()'
sketch\H801.ino.cpp.o:(.text.setup+0x18): undefined reference to `h801_setup()'
sketch\H801.ino.cpp.o: In function `setup':
C:\Users\Raymon\Documents\Arduino\H801/H801.ino:251: undefined reference to `h801_setup()'
sketch\H801.ino.cpp.o: In function `operator<<':
C:\Users\Raymon\Documents\Arduino\libraries\Streaming/Streaming.h:103: undefined reference to `handleOTA()'
C:\Users\Raymon\Documents\Arduino\libraries\Streaming/Streaming.h:103: undefined reference to `h801_loop()'
sketch\H801.ino.cpp.o: In function `operator<< <const __FlashStringHelper*>':
C:\Users\Raymon\Documents\Arduino\libraries\Streaming/Streaming.h:34: undefined reference to `handleWifi()'
sketch\H801.ino.cpp.o: In function `loop':
C:\Users\Raymon\Documents\Arduino\H801/H801.ino:298: undefined reference to `processUserInput()'
C:\Users\Raymon\Documents\Arduino\H801/H801.ino:328: undefined reference to `h801_loop()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Generic ESP8266 Module.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Note: i just found out that my COIL (101) is broken off, i glued it back to gether as the wires are okay but it makes a little more noice :cry:
Note2: I just purchased on of these as they seem to be needed for the ESP8266 http://www.phonestore.nl/p303679/ftdi-f ... duino.html
As said i keep you updated.
Since i don't have a FTDI controller it tried to program the module with an Arduino. In my case i used a Freeduino board and i removed the MCU so the onboard FTDI controller would talk directly to the H801. Sadly i didn't succeed.
I also realized that i forgot to order a LED strip to control so i made a ne order at AliExpress for a LED strip and a FTDI controller
I based my order on the parts mentioned here eryk.io/2015/10/esp8266-based-wifi-rgb- ... ller-h801/
raymonvdm
Post by raymonvdm »
AshaiRey wrote:As said i keep you updated.
I have an ESPlight with an cable to program it, but the cable is not working on the H801 (It works on the ESPlight however) https://tkkrlab.nl/wiki/EspLight I also tried another cable i bought for my AXA REMOTE but also to no avail
r_255
Post by r_255 »
Well i am using the FTDI converter that came with the jeenode workshop years ago. ( not sure if you where contender )
Make sure it does 3.3v!
I had loads of fun with it already and flashed many alternative firmwares on many devices.
So its a good investment.
Just make sure you also place the jumper ( 2 pins next to the pinheader ) before you (power on) boot (in flash mode) , else the esp wont accept any firmware at all.
raymonvdm
Post by raymonvdm »
Using this interface i just got the example op eryk.io working. But i cannot build the vlast3k .ino yet
vlast3k
Post by vlast3k »
raymonvdm wrote:Using this interface i just got the example op eryk.io working. But i cannot build the vlast3k .ino yet
aahh sorry....
we have now easter and I will have finally time to add a description how to build :)
