Manuals/tutorials
Posted: Wed Sep 07, 2016 9:50 pm
by marcelr
This thread used to be a single post with all manuals/tutorials we gathered over time.
Recently, we hit the 60,000 character limit in that post, so from now on, the thread will be split into separate (locked) posts on one subject each.
To keep things tidy, it will remain a read-only thread. When you have anything you would like to see added to this thread, just PM me and I'll see to it.
Just to give an overview what's possible with a rooted Toon: check out this list:
Rooting Toon
Posted: Thu Jun 01, 2017 5:54 pm
by marcelr
Please follow this quick reference guide how to root a Toon.
ROOT A TOON–QUICK REFERENCE GUIDE.pdf
(65.03 KiB) Downloaded 11097 times
After rooting you should use the update script (viewtopic.php?f=96&t=11996) to get necessary software for your toon and harden it (option -f of the script) and maybe to update your toon. Just log in to your Toon with your SSH client (for example putty) and run this:
curl -Nks https://raw.githubusercontent.com/ToonSoftwareCollective/update-rooted/master/update-rooted.sh -o /root/update-rooted.sh
sh /root/update-rooted.sh -f
If you still don't feel confident enough to root your toon yourself, forum member TerrorSource will be happy to do it for you, for a small fee. Just PM him and arrange whatever needs arranging.
If you want to follow the manual rooting method, let's get cracking (Users who prefer Dutch, a translated version is attached at the far end of the code block). Please remind this manual is a bit old. Don't follow the manual just line by line (if you did that, you could have better used the auto root script). Use the manual as a guide how a older Toon was rooted but insert your own intellegence and information you can find on the forum.
Rooting Eneco's toon
Manual for rooting a Toon thermostat, version 1.
changelog
20201018:
Removed old rooting techniques as they are not working anymore.
Added new auto rooting option after you booted into rescue mode
20180825:
Added remark about the Dutch version (the second half of this manual).
Added remark about toon version.
This manual is about rooting Toon 1 ONLY.
Changed time server in chrony settings (Thanks, Gleno0hh).
Changed ping redirect to /etc/hosts instead of /etc/hosts.template
(Thanks, mogwai).
20180429:
Added a simplified version to override busybox in newer firmwares
(thanks, TheHogNL).
20171113:
Added rooting workaround for busybox 1.27.2, without getty implementation.
Added link to detailed description of JTAG procedure with raspberry pi.
(thanks, rboers).
20170604:
Added remark about the appearance of the login prompt, after setting the
tty in /etc/inittab. Changed operations for initial reboot, after setting
the tty in inittab.
20170514:
Added remark about the (harmless) tty error message when starting the
initial shell through U-Boot.
20170427:
Fixed error in path to iptables.conf, in the Dutch version. More explanation
about editing/creating /etc/hosts.template (thanks, TechApprentice).
20170225:
Added JTAG wiring and reset instructions for raspberry pi JTAG hardware
(thanks, klaphekje).
20170215:
Added instructions for rooting newer toons (with hashed password).
20170205:
Dutch version added (at the far end of this document).
Nederlandse versie toegevoegd (achter de Engelstalige versie).
20170201:
Added u-boot version number which is not (yet) rootable.
cosmetic changes.
20160320:
Added u-boot version numbers associated with bootloader passwords.
changed text to reflect bootloader versions with certain features,
rather than serial numbers.
cosmetic changes.
20160319:
Added warning about u-boot not echoing the boot password.
Added steps to suppress servicecenter warnings (thanks, al_n).
20160318:
Added u-boot access through the bootloader password.
Added newer ports for iptables.conf
Added newer version number for dropbear
Simplified ping rerouting (thanks, RDNZL).
Cosmetic changes.
20151203:
First release
Before you begin
This manual consist of an English text and a Dutch one. The English text is
kept up-to-date as much as possible, the Dutch text follows the English text.
This may lead to small differences in the steps to take for rooting.
When in doubt, the English text most likely gives the best description.
Make sure toon is not connected to any network that's in contact with
the internet. Eneco (quby) can see every toon connected to its service
center. Big Brother is watching YOU! ;-)
So: disconnect toon from any wireless network (invalidate the
passphrase, remove the SSID from toon, or remove the wifi chipset ;-) ).
In the second step of the rooting process you will need to install an
ssh client/server. I have done this through a small (wired) router,
with no WAN connection, and a private webserver.
Requirements:
1: 3.3V serial-to-USB cable, with separate header connectors for TxD,
   RxD and GND (or a ttl-to-serial-adapter when you are using a native serial
   port).
2: A computer with serial terminal software like putty and a
   free USB port (or a free serial port).
3: A small (metal) screwdriver.
4: Eneco (quby) Toon, version 1 (rectangular appearance, grey backing,
   ethernet port).
5: Proficiency in using vi (the basic text editor, available in all
   UNIX-flavours).
##### Opening the case and connection of the serial interface: #####
Open the casing of toon to access its 14-pin I/O header connector by
carefully dislodging the PCB from the backing shell. Be careful not to
break the flat cables connecting the display.
The white frame is clicked into the grey backing and can be removed by
just lifting it and gently retracting it from the backing. Use your
nails, not tools! The touchscreen/display part can then be lifted and
put (a wee bit) aside. Be careful with the antennas. In newer toons
they are glued to the grey casing, and easily torn.
The PCB holding all the components is kept in place by a
few plastic studs and can be dislodged easily. When done, the back of
the PCB presents two connectors: one 2-pin connector for a 24V power
supply (accessible from the outside), and a 2x7 connector holding a
JTAG interface and a serial port. Logic high being 3.3V.
Connect a 3.3V signal level serial-to-USB adapter to the serial port
of toon and open a serial console (e.g., hyperterminal or putty on
Windows, minicom on Linux, but there are many other options).
Port settings: 115200 baud, 8N1.
(See also domoticaforum.eu for wiring:
http://www.domoticaforum.eu/viewtopic.php?f=17&t=8743)
This is the pinout (not necessarily completely correct, but works for me.
Numbering (left column: toon, right column: standard 20-pin ARM JTAG adapter):
JTAG:
pin 1:  RTCK    brown    11
pin 2:  TRST    red      3
pin 3:  GND     orange   4
pin 4:  TCK     yellow   9
pin 5:  GND     green    6
pin 6:  TMS     blue     7
pin 7:  SRST    purple   15
pin 8:  TDI     grey     5
pin 9:  Vt      white    1
pin 10: TDO     black    13
Left column: JTAG toon, right column GPIO raspi:
JTAG connector Toon     -->   Rapberry Pi GPIO (signal name)
                1     -->    NC (RTCK)
      2     -->    24 (TRST)
      3     -->    20 (GND)
      4     -->    23 (TCK)
      5     -->    6 or 25  (GND)
      6     -->    22 (TMS)
      7     -->    18 (SRST)
      8     -->    19 (TDI)
      9     -->    NC (Vt)
      10     -->    21 (TDO)
serial port (3.3V logic levels, ttymxc0, 115200 baud, 8N1):
pin 11: RxD
pin 12: ??
pin 13: TxD
pin 14: GND
Make sure the component side of the PCB is accessible. Connect toon
to a power supply (boiler module + power adapter) and power it up.
##### Entering (and editing) the boot loader: #####
## By using the password ##
The bootloader is accessed by entering the bootloader password when
the boot loader is starting, and presents the prompt:
Enter password - autoboot in 2 sec.
Two boot loader passwords have been retrieved so far, and they depend
on the bootloader version of your toon. The bootloader version is
displayed in the serial console immediately after toon (re)boots:
U-Boot 2010.09-R6 (Mar 14 2012 - 11:15:10)
CPU:   Freescale i.MX27 at 400.168 MHz
... etc.
These are the passwords that go with the u-boot versions:
Bootloader version     password
U-Boot 2010.09-R6     f4E9J
U-Boot 2010.09-R8     3BHf2
The password is case-sensitive, so, e.g., f is different from F.
Enter the password (terminated with a <return>-character) by
copy/pasting it into the serial console. U-boot will stop and present
its prompt:
U-Boot>
Note that the password is not shown when you enter it. The (very
basic) serial console of U-Boot only echoes what you enter _after_ the
password has been entered and command has been redirected to the
serial interface.
If, for whatever reason, you cannot enter the password properly, or
you have a toon with yet another (unknown) password, you can revert to
the U-Boot interruption method presented below, or dump the boot
loader image (contact me through PM). It's not hard to find the boot
loader password in the image, but it takes too many steps to describe
here. You will need JTAG hardware and software for this.
## By shorting the NAND chip ##
Enter the u-boot menu by briefly shorting the proper control pins on
the NAND chip early on during boot-up (Short the pins when "checking
crc" or similar is visible) A small metal screwdriver will do nicely
for this purpose.
This causes a flash memory checksum error and drops you to a u-boot
shell. For toon's NAND chip, the pins are 8 and 9 (!CE and !RE, NOT
Chip enable and NOT Read enable, search http://www.hackaday.com for
details). The NAND chip is the (only) samsung chip on the PCB.
##### Newer u-boot version(s) #####
Starting from early 2016, newly produced toons have a new version of the
bootloader. The bootloader version is presented as follows:
U-Boot 2010.09-R10 (Dec 14 2015 - 19:28:18)
This version will also ask for a password, but this is unknown, and
better protected than in earlier versions of the bootloader (SHA256
hash). Typically, toons with a serial number starting with 16 or
higher will have this "feature".  The sha256 hash is known and we are still
trying to brute force into the password (https://www.domoticaforum.eu/viewtopic.php?f=101&t=12482).
Furthermore, the screwdriver method will not work, instead, when you
successfully interrupt the boot loader, it will present the following
text:
Welcome to the bootloader, adventurous adventurer.
We congratulate you on your perseverance and inventivity!
Would you like an easier way in?
Please visit quby.com/open-system for more information.
Game on! :)
This link provides an option to allow quby to open your toon. Probably
your VPN keys are removed and the machine is set to be a standalone
thermostat. I have no experience with this.
If you don't want to go down that path, the only way to overcome this
situation is to use a different bootloader, and load it onto toon using
JTAG access.
##### What you need, besides the already mentioned tools ######
1: JTAG adapter. I used a clone Jlink, bought at ebay, for $15,-- or thereabouts
2: Wiring for toons JTAG interface. You will probably need to build your own,
   according to the pinout data given (way) above.
3: OpenOCD software, version 0.9.0 or later. Get it from
   https://sourceforge.net/projects/openocd/files/openocd/
   and learn how to use it.
4: A telnet client.
5: u-boot image and toon configuration file for OpenOCD
   Get it from the downloads thread at this forum.
##### What you need to do #####
1: Unpack the boot loader image and ed20.cfg file in a convenient spot.
2: Connect the JTAG adapter and the serial interface to toon and your computer.
3: Open a serial tty for the serial interface.
4: Power up toon.
5: Open a (root) shell for OpenOCD, and start it up:
   $ openocd -f <your_interface_config_file> -f ed20.cfg
6: open a telnet session to control openocd:
   telnet localhost 4444
7: Halt the system by issueing the soft_reset_halt command:
  > soft_reset_halt
  requesting target halt and executing a soft reset
  target halted in ARM state due to debug-request, current mode: Supervisor
  cpsr: 0x000000d3 pc: 0x00000000
  MMU: disabled, D-Cache: disabled, I-Cache: disabled
7a: For a raspberry pi, issue the command: reset halt
    This step halts the processor using raspi JTAG.
8: load the u-boot image into memory. The load address is 0xa1f00000:
  > load_image u-boot.bin 0xa1f00000
  166504 bytes written at address 0xa1f00000
  downloaded 166504 bytes in 2.548540s (63.802 KiB/s)
9: restart the processor at the u-boot load address:
  > resume 0xa1f00000
  This reboots toon, and presents you with a boot loader interruption option.
10: Copy/paste the password (toon + <enter>) into the terminal window. This
    interrupts the boot loader and presents the boot loader prompt:
   U-Boot>
Oh, by the way: Game Over ... (at least for now ;-) )
People who want to use a raspberry pi 2 or 3 for the JTAG procedure, a very
detailed description on how to proceed with that hardware is given here:
https://www.domoticaforum.eu/viewtopic.php?f=87&t=11230&start=210#p83745
Thanks, rboers, for sharing.
#### Editing the U-Boot environment #####
After getting the U-Boot prompt (either way), this is what you get
when asking for printenv (bootloader version U-Boot 2010.09-R8, R6 is
very similar):
U-Boot> printenv
bootdelay=2
baudrate=115200
loadaddr=0xA1000000
bootdelay=2
mtdids=nand0=mxc_nand
mtdparts=mtdparts=mxc_nand:1M(u-boot)ro,512K(u-boot-env)ro,1536K(splash-image),3M(kernel),3M(kernel-backup),119M(rootfs)
mtdparts_kernel=mtdparts=mxc_nand:512K@0x00100000(u-boot-env)ro,1536K(splash-image),3M(kernel),3M(kernel-backup),119M(rootfs)
mem=128M
autoload=no
backlight_brightness=50
baudrate=115200
console=ttymxc0
addtty=setenv bootargs ${bootargs} console=${console},${baudrate}
addmtd=setenv bootargs ${bootargs} ${mtdparts_kernel}
nandargs=setenv bootargs ubi.mtd=4 root=ubi0:rootfs rw rootfstype=ubifs
boot_nand=run nandargs addmtd addtty addmisc; nand read ${loadaddr} kernel; bootm ${loadaddr}
boot_nand_backup=run nandargs addmtd addtty addmisc; nand read ${loadaddr} kernel-backup; bootm ${loadaddr}
bootcmd=run boot_nand
splashimage=0x180000
ethact=FEC
sn=xx-xx-xxx-xxx
pn=6500-1400-1200
software_compatibility=0
manufacture_date=2014/04
ethaddr=aa:bb:cc:dd:ee:ff
addmisc=setenv bootargs ${bootargs} mem=${mem} lpj=999424
bootargs=ubi.mtd=4 root=ubi0:rootfs rw rootfstype=ubifs mtdparts=mxc_nand:512K@0x00100000(u-boot-env)ro,1536K(splash-image),3M(kernel),3M(kernel-backup),119M(rootfs) c4
partition=nand0,0
mtddevnum=0
mtddevname=u-boot
Environment size: 1280/131068 bytes
U-Boot>
Edit as follows (redefine addmisc, this is the last part of boot_nand,
by adding init (be sure to properly escape the $ and { }-signs with
backslashes!) ):
setenv addmisc setenv bootargs \$\{bootargs\} mem=\$\{mem\} lpj=999424 init=/bin/sh
Not sure what lpj=999424 means, but in my case it should be there,
otherwise toon won't boot again. In older firmwares, the phrase
lpj=999424 is not present, should be no problem.
Then resume the booting process of Toon by typing:
run boot_nand
and press <enter>.
At the end of the booting process, you will be dropped to a shell, and
you can start editing whatever needs editing. Never mind the warning
/bin/sh: can't access tty; job control turned off
it's harmless.
##### Auto rooting script: #####
Now copy paste the next two lines into the rescue shell which will do the rest for you.
You can follow the rooting process on the serial console while the Toon is booting. Make sure the Toon has a working internet connection so it can download necessary rooting files. For this you can configure the wifi on the toon or connect an UTP network cable on it.
echo "(echo \"+++Starting rooting your toon!+++\";while ! curl -Nks http://qutility.nl/root-toon1 ; do echo \"echo 'Waiting for internet'\" ; sleep 10 ; done |sh)&" > /etc/rc5.d/S99dropbear-install-and-root.sh
/etc/init.d/reboot
While the script is running you can follow the result also on http://toon-ip-address/rsrc/log (you might need to open 'lokaal toegang' for it on the toon because in the early stages of the script the firewall isn't opened yet to allow this).
When the script is finished you should be able to login to your toon over SSH with user root and password toon.
To change your root password you can use this line (change mypassword to your new password):
PASS='mypassword' ; CRYPTPASS=`/usr/bin/openssl passwd -crypt $PASS` ; sed -i "s#root:[^:]*#root:$CRYPTPASS#" /etc/passwd
Rooten van Eneco's toon thermostaat.
Nederlandse versie van het bovenstaande. De wijzigingentabel wordt alleen
in de engelstalige versie bijgehouden.
Een paar dingen vooraf
Zorg ervoor dat je toon niet in een netwerk hangt dat verbonden is met het
internet. Eneco (eigenlijk Quby) ziet en heeft contact met elke toon die
verbonden is met hun Service Center (SC). 1984 van Orwell is nog steeds
actueel ;-).
Dus: ontkoppel je toon van je WiFi netwerk (stel een fout WiFi password in,
verwijder je SSID uit toon's wifi tabel, of demonteer de wifi chipset in
z'n geheel (het laatste is een beetje over-the-top, maar werkt uitstekend)).
In de tweede stap van het rooten wordt ssh (secure shell) server software
geinstalleerd. Ik heb dat gedaan met een ouderwetse bekabelde router, zonder
de WAN aansluiting aangesloten, en een webserver op mijn laptop. Opmerkingen
op het Enecoforum dat de netwerkpoort niet zou werken, zijn schromelijk
overdreven ;-). (De USB poort doet 't overigens ook prima).
Als dat om een of andere reden lastig is, kun je ook je toon wel aan het
internet hangen, en de ssh software van het domoticafoum downloaden.
Toon rooten
Benodigdheden:
1: een 3,3 V serieel-USB interface, met losse, zgn. header, connectoren voor
   de signalen TxD, RxD en GND. Als je computer een echte seriele poort
   heeft, kun je ook een TTL-naar-serieel adapter gebruiken.
   (alleen in industriele of vrij oude PC's vind je nog een echte seriele
   poort, dus waarschijnlijk is de laatste niet nodig).
   Ik gebruik deze:
   https://www.antratek.nl/ftdi-usb-naar-serieel-ttl-kabel-3-3v-ttl
   Niet de goedkoopste, maar wel een goed stuk gereedschap.
   (en nee, ik heb geen aandeel in Antratek of FTDI).
2: Een computer met een vrije USB poort en seriele terminal software,
   bijvoorbeeld putty:
   http://www.putty.org/
   of minicom (op linux systemen).
3: Een kleine (metalen) schroevendraaier.
4: Uiteraard een toon van Eneco, anders valt er weinig te rooten.
5: Enige handigheid in het gebruik van een command line interface (zeg maar
   de oude DOS-prompt in windows) en een ASCII editor. Toon heeft zowel vi als
   nano aan boord.
##### Toon openmaken en de seriele kabel aansluiten #####
Het witte frame rond het scherm van toon is gemakkelijk los te wippen uit
zijn bevestiging. Werk (met je nagels) aan de buitenkant rond het display om
stukje bij beetje het frame van de grijze achterkant te scheiden. Aan de
onderkant zit een (1) clipje dat iets lastiger gaat.
Je kunt nu het display uit toon tillen en een (klein beetje) terzijde leggen.
Ga voorzichtig te werk. Vooral de flatcables van het display en de
antennedraadjes van wifi en z-wave (zeker in latere toons) zijn vrij teer en
makkelijk te beschadigen.
De printplaat met alle componenten zit met vier plastic clipjes vast aan de
grijze achterkant van toon. Duw deze clipjes een beetje opzij en til de
printplaat uit toon.
De achterkant van de printplaat heeft twee sets connectoren: een tweepolige
voor de 24V aansluiting met de ketelmodule (toegankelijk van buitenaf), en
een 14-polige voor JTAG en seriele interface. Het signaalniveau voor de
14-polige connector is 3,3 V.
Dit zijn de pinnummers van de 14-polige connector:
NB: pin 1 staat aangegeven op de printplaat,
nummering is als volgt:
1-2
3-4
5-6
7-8 etc.
JTAG (let niet op de kleuren en cijfers erachter, die zijn specifiek voor
mijn JTAG interface):
Links: JTAG connector Toon, rechts: Standaard 20 pin ARM JTAG interface.
pin 1:  RTCK   bruin   11
pin 2:  TRST   rood    3
pin 3:  GND    oranje  4
pin 4:  TCK    geel    9
pin 5:  GND    groen   6
pin 6:  TMS    blauw   7
pin 7:  SRST   paars   15
pin 8:  TDI    grijs   5
pin 9:  Vt     wit     1
pin 10: TDO    zwart   13
Linker kolom: JTAG toon, rechter kolom GPIO connector raspi:
JTAG connector Toon     -->   Rapberry Pi GPIO (signaal naam)
                  1     -->    NC (RTCK)
      2     -->    24 (TRST)
      3     -->    20 (GND)
      4     -->    23 (TCK)
      5     -->    6 of 25 (GND)
      6     -->    22 (TMS)
      7     -->    18 (SRST)
      8     -->    19 (TDI)
      9     -->    NC (Vt)
      10     -->    21 (TDO)
seriele poort (3,3V signaalniveau, ttymxc0, 115200 baud, 8 databits, No parity,
1 stopbit):
pin 11: RxD
pin 12: ??
pin 13: TxD
pin 14: GND
Zorg dat de componentenzijde van de printplaat goed toegankelijk is.
Koppel de seriele adapter aan toon. (pin 11-13-14). Let op dat RxD en TxD
omgewisseld worden (TxD toon aan RxD adapter, en andersom). Stel je seriele
poort in zoals hierboven aangegeven, en start putty (of minicom). Voor details,
zie de putty manuals.
Verbind toon met een voeding (ketelmodule + adapter) en zet 'm aan.
##### Toegang tot en wijziging van de bootloaderinstellingen #####
## methode 1: via het wachtwoord ##
Je kunt jezelf toegang verschaffen tot de bootloader door het bootloader
wachtwoord in te geven (via Ctrl+C, Ctrl+V, gewoon typen gaat te traag).
Zodra toon opstart zie je in het putty scherm de output van het bootproces.
Op enig moment volgt dan:
Tot nu toe zijn twee bootloaderwachtwoorden gevonden, behorend bij twee versies
van de bootloader. Deze versie wordt weergegeven bij het opstarten van toon:
... etc.
De wachtwoorden zijn:
Bootloader versie     wachtwoord
Het wachtwoord is hoofdlettergevoelig, dus bijvoorbeeld f is niet hetzelfde
als F.
Copy/paste het wachtwoord  (met <enter> erachter) in de putty console zodra
erom gevraagd wordt. Dit stopt de bootloader en presenteert de U-Boot prompt:
U-Boot>
Let op dat het wachtwoord niet zichtbaar is als je het ingeeft. Je ziet pas
wat je intikt als U-Boot een seriele console voor je geopend heeft.
Als, om wat voor reden dan ook, je niet in staat bent om het wachtwoord in
te geven, of je hebt een toon met een tot nu toe onbekend wachtwoord, dan
kun je de bootloader onderbreken door de NAND chip kort te sluiten, of
de bootloader software van toon dumpen (met behulp van JTAG hardware en
-software). Zeker het laatste is nogal gedoe, ga ik hier niet op in.
## methode 2: NAND chip tijdelijk kortsluiten ##
Je kunt in het boot-menu terecht komen door op het goede moment tijdens
opstarten een paar verbindingen van de NAND chip kort te sluiten, met een
klein metalen schroevendraaiertje.
Op het moment dat "Checking crc" of woorden van die strekking in je putty
console verschijnen, sluit je pin 8 en 9  (!CE en !RE, NOT chip enable en
NOT read enable) kort. Dit geeft een zgn. crc error in de bootloader, die
reageert met een interactieve prompt (om e.e.a. te kunnen verhelpen).
Handig.
NB: De NAND chip is de enige Samsung chip op de printplaat.
##### Dichtgespijkerde versies van U-Boot #####
Vanaf begin 2016 wordt er een nieuwere versie van de bootloader op toon
geinstalleerd. Deze geeft de volgende versieregel bij het opstarten:
Deze versie vraagt ook om een wachtwoord, maar dat is onbekend en nogal wat
beter versleuteld dan in vorige versies (SHA256 encryptie). Toons met een
serienummer beginnend met 16  (en hoger waarschijnlijk) hebben deze versie.
Uit eerdere discussies met Quby volgde dat elke toon nu z'n eigen wachtwoord
heeft (dus dikke kans  dat het te maken heeft met de naam van je toon
(eneco-001-xxxxxx), de MAC adressen, serienummers of andere individuele
kenmerken van je toon). Leuke info, maar daar heben we dus niks aan.
De schroevendraaiermethode werkt bij deze toons ook niet, als je de
bootloader onderbreekt krijg je het volgende:
Game on! :)
De link geeft je de mogelijkheid om Quby toon voor je te laten rooten,
(waarschijnlijk gooien ze de VPN keys weg, en zetten ze de software in
standalone mode). Heb ik geen ervaring mee. Als je dit niet wilt, rest als
enige mogelijkheid om een ander bootloader te nemen, en die met JTAG
hardware naar je toon te uploaden.
##### Benodigdheden, naast de eerder genoemde spullen #####
1: JTAG interface. Ik gebruik een kloon JLink, gekocht op ebay voor $15,-- of
   daaromtrent.
2: Bekabeling voor de JTAG interface van toon. Zul je waarschijnlijk zelf
   moeten  maken, zie hierboven voor pinbezetting.
3: OpenOCD software, versie 0.9.0 of later. Hier op te halen:
   (en leer ermee werken!)
4: Een telnet client.
5: U-boot image en een toon configuratiefile, voor openocd.
   Te vinden in de downloads thread van dit forum.
##### Te verrichten handelingen #####
1: Pak de bootloader en ed20.cfg file uit op een handige plek, bij elkaar.
2: Koppel de JTAG interface en de seriele interface aan toon en je PC.
3: Open een terminal programma voor je seriele interface, en eentje voor je
   telnet client.
4: Start toon op.
5: Open een root shell voor OpenOCD en start openocd:
   $ openocd -f <jouw_interface_config_file> -f ed20.cfg
6: Open een telnet sessie om openocd aan te sturen:
7: Halt de processor, via het openocd commando soft_reset_halt:
  > soft_reset_halt
7a: Als je een raspberry pi als JTAG interface gebruikt, voer dan ook nog uit:
  > reset halt
  Dit stopt de processor bij deze JTAG hardware.
8: Upload het u-boot image naar toon's geheugen. Het upload adres is 0xa1f00000:
9: Herstart de processor op het u-boot upload adres:
  > resume 0xa1f00000
  Dit resulteert in een reboot, en geeft de mogelijkheid om de bootloader te
  onderbreken.
10: Knip/plak het wachtwoord (toon + <enter>) in de seriele terminal. Dit stopt
    de bootloader en geeft de u-boot prompt:
    U-Boot>
Ik zou het bijna vergeten: Game over ... (voorlopig, dan toch ;-) )
Voor Mensen die een raspberry pi 2 of 3 willen gebruiken voor de JTAG procedure
heeft rboers een zeer gedetailleerde beschrijving gemaakt.
Die is hier te vinden:
Dank je, rboers, voor deze uitgebreide beschrijving.
##### U-Boot environment aanpassen #####
Zodra je in het U-Boot menu bent aangekomen, kun je een aantal commando's
uitvoeren:
De eerste is printenv, en geeft het volgende (bootloader versie
U-Boot 2010.09-R8, R6 lijkt er veel op):
U-Boot> printenv
bootdelay=2
baudrate=115200
loadaddr=0xA1000000
bootdelay=2
mem=128M
autoload=no
baudrate=115200
console=ttymxc0
ethact=FEC
sn=xx-xx-xxx-xxx
pn=6500-1400-1200
partition=nand0,0
mtddevnum=0
mtddevname=u-boot
U-Boot>
Het bootloader environment bevat een aantal commando's die bij opstarten
uitgevoerd worden. We passen de laatste aan (addmisc, dat is het laatste
stukje commando van boot_nand, de standaard opstartregel):
Edit addmisc als volgt (letterlijk deze tekst, een tikfout is dodelijk):
Overigens heb ik geen idee wat lpj=999424 betekent, in mijn toon zit het er.
In oudere bootloaderversies zit het niet, zou niks mogen uitmaken, zolang je
maar exact de oorspronkelijke addmisc regel kopieert (en let op de backslashes,
voor de $ en { en } tekens).
Vervolg daarna het bootproces door het volgende in te tikken:
run boot_nand
en druk op <enter>.
Aan het einde van het bootproces opent U-Boot een command shell of cli, of
console, of hoe je 't ook noemen wilt, in putty. Je kunt nu de opstartfiles
van toon gaan editen. Let niet op de foutmelding
die heeft geen effect.
##### Automatisch root script #####
Voor vanaf hier in de rescue shell de volgende twee regels in (copy paste) en het script zal de rest voor je doen.
Je kan op de seriele console aansluiting tijdens het booten het root script volgen. Zorg er voor dat de toon een internet verbinding heeft zodat het script de nodige root bestanden van het internet kan halen. Hiervoor kan je wifi instellen op de toon of een UTP netwerk kabel aansluiten.
/etc/init.d/reboot
Gedurende het script actief is kan je op http://toon-ip-adres/src/log het script volgen. Het kan nodig zijn om op je toon 'lokaal toegang' aan te zetten omdat in de eerste fase van het script de firewall nog niet open is gezet om dit toe te staan.
Als het script klaar is kan je met een SSH client inloggen op de toon met gebruikersnaam root en wachtwoord toon.
Om je wachtwoord te wijzigen kan je volgende regel gebruiken (verander mypassword door jouw nieuwe wachtwoord).
Remote control of your Toon through VNC
Posted: Thu Jun 01, 2017 5:57 pm
by marcelr
Without monthly subscription, your toon can be made accessible through VNC, which allows you to control it from any VNC-compatible device (PC, Mac, iOS phone, Android phone, Windows phone, iPad, etc.) This is how it's done:
Toon on a remote desktop and/or phone
20180204, marcelr, added new release version number.
20170822, marcelr, added warning on possible race condition in inittab code.
20170514, marcelr, added /etc/inittab entry.
20160601, marcelr, added some credits, removed sleep item from todo list
20160501, marcelr, first release.
Some time ago, cygnusx raised the question on remote control of toon, at the
domoticaforum. Sounded interesting/nifty. Ierlandfan came up with the idea to
use VNC. Sounded good.
After some googling, x11vnc came out as the best option to run a remote desktop
service: It runs on linux, supports framebuffer devices, touchscreens, and is
open source, therefore possible to implement on toon.
To cut a long story short: I made a stripped-down version of x11vnc for toon,
and a script to start it up.
What you need
1: A rooted toon
2: x11vnc installation package for toon: x11vnc_0.9.13-r0_qb2.ipk or
   x11vnc_0.9.13-r3_qb2.ipk
   Newer fw versions (with openssl 1.0.2h) will need r3, older ones use r0.
3: A VNC client for your remote device (PC, phone, iPad, whatever), supporting
   VeNCrypt over SSL. I use TigerVNC on my desktop (linux or windows), and bVNC
   on my android phone.
What you need to do
1: Download the two parts of the zipped x11vnc package from the downloads
thread, rename part two to x11vnc.z01, unpack, and upload x11vnc_0.9.13-r0_qb2.ipk
to toon via scp:
$ scp x11vnc_0.9.13-r0_qb2.ipk root@toon:/root/
2: Install the package:
toon:~# opkg install x11vnc_0.9.13-r0_qb2.ipk
Installing x11vnc (0.9.13-r0) to root...
Configuring x11vnc.
3: Check if the script exists (the binary is called x11vnc-bin):
toon:~# which x11vnc
/usr/bin/x11vnc
4: Run x11vnc. The first time, it will ask for a password, to be used with your
VNC client. Make sure to choose a STRONG password. Check out this list if you
want to know what NOT to choose:
http://www.passwordrandom.com/most-popular-passwords
After entering the same password twice, x11vnc will ask you to save the
password. Choose y.
Then, it will create the server and CA certificates for the TLS protocol.
A typical first-time run session looks like this:
toon:~# x11vnc
Enter VNC password:
Verify password:
Write password to /root/.vnc/passwd?  [y]/n y
Password written to: /root/.vnc/passwd
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            bd:32:02:0b:
what follows are several pages of text on the generated certificates.
-----END CERTIFICATE-----
The SSL VNC desktop is:  toon:0
PORT=5900
SSLPORT=5900
toon:~#
5: x11vnc serves on tcp port 5900. This has to be opened on your toon's
firewall.
Add the following line to /etc/default/iptables.conf:
-A HCB-INPUT -p tcp -m tcp --dport 5900 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
(I like to keep these directives more or less tidy, so in my iptables.conf
this line is in between similar directives for ports 22 and 10080).
Restart the firewall:
$ /etc/init.d/iptables restart
Accessing toon through VNC
Install a VNC client (as said already: TigerVNC and bVNC are known to work).
Choose "Secure VNC over SSL tunnel" or something along these lines as
connection type, enter your toon's access data (name, IP, port (default 5900) )
and the password set earlier in the first run of x11vnc.
Connect to toon.
You should now have a working VNC connection, with toon's interactive display
on your remote device.
For connections outside your own subnet, forward some unused high-number port
(typically: 10000 < portnumber < 65535) to toon's port 5900 on your router.
Read your router's manual for more info on port forwarding.
Make x11vnc persistent over reboots
BIG FAT WARNING: the following code does not work on all toons, for some reason.
Try it, and if it works, you're lucky. If not, start x11vnc manually.
As of yet, it's unclear why this code does not always work.
Some x11vnc users want x11vnc to start automatically at each reboot. To achieve
this, do the following:
1: Install x11vnc, run it, and set the password as described above.
2: Edit /etc/inittab. Add the following line to /etc/inittab, after the getty
   line (the getty line is there just for reference, in this example):
   # added tty for direct serial access
   gett:235:respawn:/sbin/getty -L 115200 ttymxc0 vt102
   # automatic (re)start of x11vnc:
   x11v:5:respawn:/usr/bin/x11vnc
3: Reboot. During reboot, /etc/inittab is partly rewritten, for an unknown
   reason. x11vnc will not be accessible yet.
4: Reboot again. Everything should now work.
To do
Lots of testing :-)
Maybe enhance security with dedicated server/client/root certificates.
Fix 403-Forbidden error
Posted: Thu Jun 01, 2017 5:59 pm
by marcelr
Some Toons, when you try to reach them through a web browser, throw error 403. This is easily fixed:
403-error fix
20200107, modified finally for newer toons (thehognl)
20161203, first draft.
In some firmware versions of toon, http access is not set properly, so remote
access to your data through http (e.g., for Domoticz) is impossible.
Typically, when you try to access your toon through its http server, you will
get the error:
403-Forbidden
Forum member fkruis posted a cure for this problem.
What you need
1: A rooted toon with network connection.
2: Some proficiency in editing with vi.
3: A computer with network connection and an internet browser and an ssh-client.
What you need to do
Log in to your toon, open /qmf/etc/qmf_release.xml in vi and locate the
tag <hcb_web>:
        <hcb_web>
                <defaultEntry>/hdrv_zwave/</defaultEntry>
                <enforceWhitelist>1</enforceWhitelist>
                <whitelist>
                        <item>hdrv_zwave</item>
                        <item>happ_zware</item>
                        <item>rsrc</item>
                        <item>export.zip</item>
                </whitelist>
        </hcb_web>
Change <enforceWhitelist> into 0 :
        <hcb_web>
                <enforceWhitelist>0</enforceWhitelist>
                <whitelist>
                        <item>rsrc</item>
                </whitelist>
        </hcb_web>
That's all, reboot and you should have access to your toon's data:
Try
http://<ip-of-your-toon>/happ_thermstat?action=getThermostatInfo
in the address bar of your internet browser, and if all has gone well you
should see something like this:
{"result":"ok", "currentTemp":"1896", "currentSetpoint":"1400", "currentInternalBoilerSetpoint":"6", "programState":"0", "activeState":"2", "nextProgram":"-1", "nextState":"-1", "nextTime":"0","nextSetpoint":"0","randomConfigId":"1804289383","errorFound":"255","connection":"0","burnerInfo":"0","otCommError":"0","currentModulationLevel":"0"}
Installation of custom apps
Posted: Mon Jun 05, 2017 10:38 pm
by marcelr
First of all, all TSC released custom apps are installable using Toonstore. And Toonstore is probably already installed on your rooted toon. If not, follow this guide to install toonstore or any other custom app.
# Installation of the toonstore app for toon, developed by Toonz.
# 20200107 TheHogNL, update to reflect github location and install toonstore
# 20190310 ThehogNL, update to reflect resource files from firmware 4.16 and further
# 20170203 Toonz, update to v6
# 20170108 Toonz, marcelr, first draft
This manual describes the installation process of the buienradar app, as made
by forum member Toonz. It has been tested on fw 3.1.22 and 3.5.4.
# What you need:
1: Rooted toon with internet access
2: Basic knowledge of file editing
3: latest release of toonstore from https://github.com/ToonSoftwareCollective/toonstore/releases
# What you need to do:
1: Unpack the contents of the toonstore package and transfer the directory
./toonstore/
and all of its contents to
/HCBv2/qml/app/
on your toon, such that everything ends up in /HCBv2/qml/apps/toonstore/
2: On firmware from 4.16 and on:
Since firmware 4.16 there is no way to edit the globals.qml file anymore. Custom apps are now automatically started/loaded using the modded resources files if:
- there are stored in /qmf/qml/apps/app-name-dir
- the dirname start with a lowercase letter (like: /qmf/qml/apps/customApp)
- in the dir the app primary qml file is written like this 'CustomApp.qml', so it starts with a capital and it reflects the dir-name (but now with capital)
You can get the resource files from http://qutility.nl/resourcefiles or just let the update-script.sh get it for your with the -f option.
3: Restart toon's user interface by issueing:
killall qt-gui
Toon's user interface will restart, and now you can pick the tile "toonstore"
and install it as a new tile.
4: All done.
Guidelines for submitting apps for the ToonStore
Posted: Sun Aug 27, 2017 12:03 pm
by marcelr
Recently, we launched the ToonStore app, and now more forum members are designing apps and asked to have them published via the ToonStore. This is a very welcome development. However, to avoid disappointments on the developer side and the ToonStore maintenance side, some guidelines need to be followed for successful and fast publication of your apps.
So, if you intend to submit apps to the ToonStore, please stick to the following (Dutch version in the second half of the text):
# Toon apps, requirements for having them published via the ToonStore
# (Toon apps, richtlijnen voor publicatie via de ToonStore)
20170831: marcelr, added section on testing.
20170827: Toonz,marcelr, First draft.
Dutch text below (Nederlandse versie onderaan)
Requirements for applications to be distributed via de ToonStore
1: Makes sure the app is functional, so: test, test and test
2: Make sure the application can be fully operated from the GUI.
   All configurable parameters must be set via the application.
   Required manual edits of code by the user are not acceptable.
3: Make your code readable: use the right indentation, us meaningful names for
   variables and functions.
4: Make abundant use of comments. When you stop developing your app, others
   should be able to continue.
5: Naming conventions: The packaging environment (openembedded for toon) puts
   strict requirements on names of files and folders.
   In the end an installed application will be placed in the toon software tree
   like this:
   /qmf/qml/apps +
                 /myapp-x.y.z +
                              /drawables
                              /lang
                              Changelog.txt
                              version.txt
                              MyappApp.qml
                              MyappScreen.qml
                              MyappTile.qml
                              qmldir
   and
   /qmf/qml/apps/myapp -> /qmf/qml/apps/myapp-x.y.x
   the last one is a symbolic link to the directory with all code (myapp-x.y.z).
   The packaging environment cannot handle packages when the package name of a
   package differs from the folder name where it is stored.
   The qt-gui is looking for apps named as the link/folder (in this case myapp).
   The installation method is chosen such that Globals.qml needs to be edited only once per app.
   Later versions of the app can therefore be easily installed.
   These are the characters which are allowed in the app names:
   0 1 2 3 4 5 6 7 8 9
   a b c d e f g h i j k l m n o p q r s t u v w x y z
   In other words: numerals, lower case characters, dot, plus and minus
   character.
   Example: myapp+384.2 is ok, Myapp_3.4.5 is not.
6: Folder structure for submission to ToonStore
   /myapp +
          /drawables
          /lang
          /screenshots
          /description
          Changelog.txt
          version.txt
          MyappApp.qml
          MyappScreen.qml
          MyappTile.qml
          qmldir
   These files must be packed in a zip file, named after the application with
   version number, in this case:
   myapp-x.y.z.zip
   Myapp must be supplied in a folder myapp/
   Compulsory in each application:
   - Changelog.txt (containing information about changes in this and previous
     releases.
   Look for samples in other apps in the ToonStore.
   - version.txt.  This file only contains the version number of your app.
   (x.y.z in this case, no trailing line feed).
   - /description This directory should contain a plain text file, briefly
   explaining  the steps to be taken after the app has been installed. This
   text appears in the message box of Toon after installation.
7: Packages which do not comply to the rules above will not be accepted.
   Corrective changes must be made by the author before resubmission, we are
   not going to do this for you.
8: If you want to supply screenshots as well for display in ToonStore note the
   following:
   supply images in the .png format, maximum size 800x600 (800x480 preferred)
   filenames: <appname>_screenshot_x.png  where x is a sequence number
   starting with 1
   Example: toonstore_screenshot_1
   Store these screenshots inside the /screenshots subdir of your app.
9: After submitting your app, it will be packaged and returned to you (if the
   packaging procedure is completed successfully). You will then be asked to
   verify that the packaged app installs and works as it should, and that
   subsequent installations cause no errors, and removal indeed removes
   everything related to your app.
   After successful completion of ths step, the package is signed and submitted
   to the ToonStore.
10: Good luck with developing apps, and have fun !!!!!!
Dutch version below.
Nederlandse versie:
Richtlijnen voor het aanleveren van apps voor de ToonStore
1: Zorg ervoor dat de app werkt. Dus: testen, testen, testen.
2: Zorg ervoor dat de app vanuit de GUI volledig te bedienen is.
   Benodigde edits van code door de eindgebruiker, na installatie, worden niet
   geaccepteerd.
3: Zorg voor code die leesbaar is. Indentatie zoals het hoort, kies zinvolle
   naamgeving van routines en subroutines.
4: Voorzie je code ruim van commentaar, zodat ook nadat je er zelf geen zin
   meer in hebt, iemand anders kan begrijpen wat je code doet of beoogt te
   doen, en er eventueel mee verder kan.
5: Naamgeving: De packaging omgeving (openembedded voor toon) stelt vrij strikte
   eisen aan de naamgeving van files en directories.
   Uiteindelijk komt een geinstalleerde app als volgt in de software-boom van
   Toon terecht:
   /qmf/qml/apps +
                 /myapp-x.y.z +
                              /drawables
                              /lang
                              Changelog.txt
                              version.txt
                              MyappApp.qml
                              MyappScreen.qml
                              MyappTile.qml
                              qmldir
   en
   waarbij de laatste een symbolic link is naar de directory waarin alle code
   staat (myapp-x.y.z).
   De packaging omgeving kan niet omgaan met packages waarvan de naam van het
   package anders is dan de directorynaam waar dat package in staat.
   De qt-gui zoekt in de apps naar de naam van de link (myapp in dit geval).
   De installatiemethode is
   zo gekozen dat Globals.qml maar een keer ge-edit hoeft te worden per app.
   Latere versies van dezelfde app kunnen dan zonder meer geinstalleerd worden.
   Dit zijn de karakters die in de naam mogen voorkomen:
   0 1 2 3 4 5 6 7 8 9
   Oftewel: cijfers, kleine letters, en punt, plusteken en minteken.
   Bijvoorbeeld: myapp+384.2 mag formeel, Myapp_3.4.5 is verboden.
6: Structurering van files voor aanlevering
   Wat je aanlevert moet deze structuur hebben:
   /myapp +
          /drawables
          /lang
          Changelog.txt
          version.txt
          MyappApp.qml
          MyappScreen.qml
          MyappTile.qml
          qmldir
   Dit alles ingepakt in een zip file, met de naam+versie van de app, in dit
   geval:
   myapp-x.y.z.zip
   Dus myapp moet aangeleverd worden in een directory myapp/. Het versienummer
   voor de uiteindelijke installatie wordt er door de packager aangeplakt.
   VERPLICHT in elke app zijn:
   Changelog.txt (met informatie over wat er veranderd is per versie). Kijk
   voor voorbeelden in de apps die tot nu toe gepubliceerd zijn.
   version.txt.  Deze file bevat ALLEEN het versienummer van de app.
   (x.y.z in dit geval). Zie gepubliceerde apps voor voorbeelden.
   /description Deze directory bevat een korte tekst die beschrijft wat je
   moet doen na installatie, om je app aan de praat te krijgen. Deze tekst
   verschijnt in het bericht dat je krijgt na installatie.
7: Aangezien filenamen en identifiers in qml-code gedeeltelijk overeenkomen, is
   het ondoenlijk om afwijkingen van deze eisen "effe snel" te wijzigen.
   Dat gaat dus ook niet gebeuren.
   Packages die aangeleverd worden en niet aan de eisen voldoen, worden niet in
   behandeling genomen.
8: Als je screenshots wilt meeleveren dan moeten het .png images zijn met de
   maximale afmetingen: 800 x 600 pixels, voorkeur 800x480.
   De filena(a)m(en) moet(en) zijn:
   <appnaam>_screenshot_x.png  waarbij x een volgnummer is, nummerend vanaf 1
   Voorbeeld: toonstore_screenshot_1
   Lever deze screenshots aan in de subdirectory /screenshots in je app.
9: Nadat je de app hebt ingediend als zipfile, wordt-ie ingepakt voor de
   software installer van Toon. Als deze procedure goed verloopt, krijg je je
   app terug en word je vriendelijk verzocht om de ingepakte app als nieuw te
   installeren op Toon, om te zien of alles werkt zoals je verwacht. Daarna
   moet je dat  nog een keer te herhalen, over een bestaande installatie, en
   tenslotte verwijder je je app, om te zien of inderdaad alles wat ermee te
   maken heeft goed verwijderd wordt.
   Als deze stappen allemaal goed verlopen, wordt je app gesigneerd en in de
   ToonStore geplaatst.
10: Succes met het ontwikkelen van mooie, zinvolle apps. En geniet ervan.
... and keep those apps coming, happy coding to you all!
Useful files explained
Posted: Thu Sep 07, 2017 2:44 pm
by TerrorSource
This is a post to inform about some important files you might want to edit after rooting.
Please reply if you think that more info or files should be added to this topic or if you have any questions about the files.
Folder: /HCBv2/config or /mnt/data/qmf/config
File: config_happ_scsync.xml
<internalAddress>agreementDetail</internalAddress>
<visibility>0</visibility>
"0" or "1",
<StartDate>1234567890</StartDate>
Linux timestamp, timestamp of initial activation.
<EndDate>-1</EndDate>
Linux timestamp (seconds since the epoch; jan 1, 1970, UTC), an expired timestamp will disable the "full menu" options. value "-1" can be set for "unlimited" time.
<ProductVariant>Toon</ProductVariant>
"Standalone" or "Toon", value "Standalone" will disable the "full menu" options. Value "Toon" + valid EndDate activates "full menu" options.
<activated>1</activated>
"0" or "1", activation of the Toon
<wizardDone>1</wizardDone>
"0" or "1", value "0" will activate the "initial setup" screens after a reboot. recommended to use when Toon is sold.
<SortwareUpdates>1</SortwareUpdates>
"0" or "1", value "1" will activate firmware updates.
<BoilerManagement activated="0">0</BoilerManagement>
"0" or "1",
<ElectricityDisplay>1</ElectricityDisplay>
"0" or "1", displays electricity usage, graphs and options.
<GasDisplay>1</GasDisplay>
"0" or "1", displays gas usage, graphs and options.
<HeatDisplay>0</HeatDisplay>
"0" or "1",
<SolarDisplay>1</SolarDisplay>
"0" or "1", value "1" enables the ZonOpToon widgets.
<SolarActivated>1</SolarActivated>
"0" or "1", value "1" enables the ZonOpToon options.
<OtherProviderElec>0</OtherProviderElec>
"0" or "1",
<OtherProviderGas>0</OtherProviderGas>
"0" or "1",
<SME>0</SME>
"0" or "1",
<HeatWinner>0</HeatWinner>
"0" or "1",
<ContentApps>1</ContentApps>
"0" or "1",
<TelmiEnabled>0</TelmiEnabled>
"0" or "1",
<mobileAccess>0</mobileAccess>
"0" or "1", value "1" enables the "Toon op Afstand" app, can only be used when there's a Toon subscription.
<supportEnabled>0</supportEnabled>
"0" or "1", value "1" enables the possibility to have remote support from the Eneco/Toon helpdesk. Recommended value is "0".
<supportEnabledStart>0</supportEnabledStart>
<researchEnabled>0</researchEnabled>
"0" or "1",
<doSolarWhatsnew>0</doSolarWhatsnew>
"0" or "1", value "1" enables "Wat is Zon op Toon" welcome screens.
<latestWhatsnewVersion>qt-gui - 1.6755-ene-release-ene-3.7</latestWhatsnewVersion>
Firmware version when the "WizardDone" was finished.
<statusUsageFirstUse>0</statusUsageFirstUse>
"0" or "1",
<scStatusFlags>0</scStatusFlags>
"0" or "1",
<commissionState>0</commissionState>
"0" or "1",
Updating your toon without losing ssh access
Posted: Sat Nov 18, 2017 11:12 am
by marcelr
Updating your toon is now provided by ThehogNL update script, see https://github.com/ToonSoftwareCollective/update-rooted and viewtopic.php?f=96&t=11996
Repairing a toon with a corrupted rootfs or missing busybox.
Posted: Sun Mar 04, 2018 1:07 pm
by marcelr
Recently, some forum members have tried to upgrade their toon's busybox, and failed for various reasons, leading to an essentially bricked toon. This manual adresses one way to solve issues like this.
EDIT: you can just use https://github.com/ToonSoftwareCollective/ToonRecovery for this, but read on if you want to know how we did this before this tool was available
20190203 thehognl
	major revision - added manual IP details and better nfs boot
20180304 marcelr
    added info for repairing a non-corrupt rootfs
20160402 marcelr
    added ubifs construction info for newer toons
20160313 marcelr
    first release
# 0: How to use this manual
Initially, this manual was written to elucidate the inner workings of
the UBI filesystem which makes up the root filesystem of toon. With
the revision of busybox, late 2017, which blocked serial access, some
people have tried to upgrade their busybox, and failed, leading to an
essentially bricked toon. To show how to repair a toon which was
bricked in this way, a few lines have been added to the manual.
The manual covers four major topics:
1: Setting up an NFS server with all images in place (sections 1-3)
   and booting toon over NFS (sections 4 and 7).
2: Setting up a linux kernel and rootfs for use with NFS (sections 5
   and 6)
3: Repairing a corrupted rootfs on toon (sections 8 and 9).
4: Repairing stuff on a non-corrupted rootfs, on a bricked toon
   (section 10).
# 1: Repairing a corrupted root filesystem on toon.
Some time ago I woke up in a cold house. The boiler that should have
started up at 6.00 in the morning wasn't running. I checked the
thermostat (toon) and it turned out to be dead.
It was a friday morning and I had to go to work, so I replaced it with
another toon that I had lying around (flash version, not the fancy qt
gui). Problem solved, at least for the moment.
That evening I opened up the dead toon, hooked it up to a
serial-to-USB adapter and booted up. The boot loader got stuck at
loading the kernel, and posted a warning that the splash screen could
not be loaded. The flash partitions holding the splash image and the
kernel (and probably the others too) were most likely
corrupted. Badly. I had no backup of these partitions. Stupid me.
I dumped the kernel partition of my still working toon and the dead
one to look for differences. There was no resemblance between the two,
from the corrupted kernel it was clear that it was bad. Normally, the
kernel version is stated in human-readable text in the first few bytes
of the kernel image, in this case it was only gibberish. This toon was
dead as brown bread.
What to do? Years ago I built my own router from an old headless and
diskless 486 with a network adapter with boot ROM. The thing booted
over the network, getting all its information, kernel, initrd, ramdisk
image etc., from another machine. Toon's boot loader, U-Boot,
supports network booting as well. That could be my way out. The plan
was simple: build a kernel capable of mounting a root filesystem over
NFS, load this kernel into toon through TFTP, boot, repair the flash
partitions and flash everything onto toon.
Problem solved. Easy-peasy. Yeah, right ...
# 2: Prerequisites
To repair a corrupted toon, with a working bootloader, this is what
you need:
A computer running a DHCP server, an NFS server, a TFTP server, and a
serial client. Typically, you will find all of these services in a
linux box. You will need root access to this machine. Furthermore, you
will need to have the mtd-utils package installed and working.
A serial-to-USB converter with 3.3V signal level. If you need to buy
one, go for a version with separate female header connectors at the
serial side. These are the easiest for connecting with toon.
A wired (ethernet) router to connect toon to your computer.
The quby openembedded tree for toon. Not just the tarball, but a
working installation of it. You will need to be able to build a
working, modified linux kernel for your toon.
A copy of a (recent) root filesystem for toon. Dump your own rootfs
while you still can. You may need it later. See the script
'dump_rootfs.sh' on domoticaforum.eu
Working knowledge of:
1: linux kernel configuration.
2: dhcp, nfs, tftp configuration, including firewalls to pass the
   services through.
3: entering commands through a CLI.
4: toon rooting. If you have no clue how to open toon and attach a
   serial interface to it, stop here, go and do something else.
# 3: Configuration of services
The following description is not carved in stone, there are many ways
to properly configure a DHCP, NFS and TFTP server. This is just how I
did it. My linux host is a CentOS 6 machine, with the old school
SysVinit startup system. Newer machines may have systemd. Can't help
you there, if yours is one like that. The location of scripts may vary
from one distro to another. Nevertheless, everything will be located
somewhere in /etc or its subdirectories.
##  TFTP  ##
TFTP (trivial file transfer protocol) is a simple protocol to
automatically upload files from one computer to another, typically at
boot time. In this case we need it to load a kernel image directly
into toon's memory.
On my linux box, the TFTP server requires a simple configuration
script, and a running xinetd. This is the configuration script for my
TFTP server, it resides in /etc/xinet.d/tftp:
# default: off
# description: The tftp server serves files using the trivial file transfer \
#       protocol.  The tftp protocol is often used to boot diskless \
#       workstations, download configuration files to network-aware printers, \
#       and to start the installation process for some operating systems.
service tftp
        disable = no
        socket_type             = dgram
        protocol                = udp
        wait                    = yes
        user                    = root
        server                  = /usr/sbin/in.tftpd
        server_args             = -p -svv /tftpboot
        per_source              = 11
        cps                     = 100 2
        flags                   = IPv4
Important are the disable flag (no) and the server args. /tftpboot is
the directory from which clients can download their stuff.
The tftp server is started by running xinetd:
service xinetd start
or similar.
## DHCP ##
DHCP (dynamic host configuration protocol) configures computers on a
network, based on their MAC address alone. U-Boot supports host
configuration via DHCP, so a DHCP server is needed to assign an IP
address to toon. Simultaneously, a DHCP server can be configured to
enable automatic uploading of stuff to a remote host. In cheap routers
for residential use, this option is generally not available. So we
need to set up our own. Since for home use, computers hardly run DHCP
servers. That's normally handled by your router. Because of the
network boot of toon, you will need your own DHCP service. I
configured my (separate) router to hand out one IP address only (for
my CentOS box) and let the linux machine do all the rest.
You can also set the IP details in the Toon U-boot manually or use
your router as a DHCP server and then set the TFTP server manually in
the U-boot interface. For this, see in the 4th section.
This is the config script I used for dhcpd:
# dhcpd.conf
# global parameters...
option domain-name "toontest.org";
ddns-update-style none;
not authoritative;
default-lease-time 600;
max-lease-time 7200;
option broadcast-address 10.1.0.255;
option routers 10.1.0.100;
subnet 10.1.0.0 netmask 255.255.255.0 {
#  subnet-specific parameters...
  range 10.1.0.202 10.1.0.210;
host toon {
  hardware ethernet 00:11:22:33:44:55;
  fixed-address 10.1.0.201;
  next-server 10.1.0.10;
  filename "/tftpboot/toon/uImage-nfs";
# end of dhcpd.conf
This way, toon gets a static IP, and has an idea where to find its kernel.
Start the service (as root) as follows:
dhcpd -cf dhcpd.conf
## NFS ##
NFS (network file system) is a protocol to share block devices over a
network. Typically, an NFS server can give other hosts access to
(parts of) its disk space. NFS clients can mount NFS exports from a
server, and then use these disks as if they were part of the native
disk space of the client. When configured properly, a diskless host
can mount ALL of its disk space via NFS.
To be able to mount an NFS volume, it needs to be exported to your
client by the server. This is taken care of in the exports file:
/etc/exports: (two lines)
/tftpboot/toon/rootfs    10.1.0.201(rw,sync,no_root_squash,no_subtree_check)
/tftpboot/toon           10.1.0.201(rw,sync,no_root_squash,no_subtree_check)
Edit this file according to your needs, and (re)start the nfs server:
service nfsd restart
This command starts a host of services (rpcbind, mountd, nfsd and some
others), which need to be able to penetrate the firewall of your
server.
## IPTABLES ##
On modern linux boxes, the firewall is called iptables, and is
switched on by default. This firewall has a configuration script,
/etc/sysconfig/iptables, and you need to edit this script to hold the
following lines (edit IP addresses according to your needs):
-A INPUT -s 10.1.0.0/24 -p udp -m state --state NEW -m multiport --dports 111,892,2049,32769 -j ACCEPT
-A INPUT -s 10.1.0.0/24 -p tcp -m state --state NEW -m multiport --dports 111,892,2049,32803 -j ACCEPT
This opens all ports required to export NFS mounts.
Similarly, for TFTP, port 69 needs to be opened:
-A INPUT -p udp -m state --state NEW -m udp --dport 69 -j ACCEPT
Edit again, and restart iptables. You may have to restart nfsd as
well.  A second option is to switch off your firewall, and don't
bother with the ports. It's up to you.
# 4: Booting toon over the network
When you are lucky enough that only the kernel image partition is
corrupted, you can now boot your toon over the network. (You even
don't need NFS support for that).
Put the kernel image you want to boot (the original kernel image made
in the open embedded tree will do) in /tftpboot/toon/, on your tftp
server.
If you haven't done so already, connect the serial I/O interface to
toon, and open a terminal. Serial port settings should be 115200 baud,
8N1.
Verify that your U-Boot hangs; it will present the U-Boot prompt: U-Boot>
This is what my toon says at start-up:
Prodrive B.V. ED2.0
DRAM:  128 MiB
NAND:  128 MiB
LCD: 800x480, pbb 4
LCD: Drawing the logo...
In:    serial
Out:   serial
Err:   serial
Error: no valid bmp image at a1d214a8 (signature 0xbe 0xda)
Net:   FEC
Address in SROM is         1f:56:1d:17:ee:22
Address in environment is  00:0f:11:01:9b:49
Enter password - autoboot in 2 sec...
AND read: device 0 offset 0x300000, size 0x300000
3145728 bytes read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
U-Boot>
Make sure to have your toon wired to an ethernet router, connected to
your dhcp server, supplying your toon with a static IP.
At the U-Boot prompt, sequentially type the following lines:
dhcp
This will request the IP details from your DHCP server. Next type:
printenv
This will show the received IP details in the end:
gatewayip=192.168.178.1
netmask=255.255.255.0
ipaddr=192.168.178.20
serverip=192.168.178.10
dnsip=192.168.178.1
Verify these details and correct them if needed. The command for this is:
set serverip 192.168.178.10
The server IP is for the TFTP server. You can also skip DHCP and set all
IP details using this command. Next type:
tftpboot 0xA1000000 toon/uImage-xxxx
bootm
with toon/uImage-xxxx the actual directory and name of your kernel image.
This connects toon to your server, with a static IP, loads the kernel
into toon's memory, and boots it. The default U-Boot environment
available on toon is used. If that partition is corrupted, you will
find out fairly quickly.
Essentially, three things can happen:
First option: After bootm, nothing seems to happen, the terminal no
longer responds. In this case, the U-Boot environment is probably
corrupted.  Check by typing: printenv at the U-Boot prompt. You should
bootdelay=2
loadaddr=0xA1000000
bootdelay=2
mem=128M
autoload=no
baudrate=115200
console=ttymxc0
ethact=FEC
baudrate=9600
sn=12-37-023-641
pn=6500-1102-0301
manufacture_date=2012/10
ethaddr=00:0F:11:01:9B:49
bootargs=ubi.mtd=4 root=ubi0:rootfs rw rootfstype=ubifs mtdparts=mxc_nand:512K@0x00100000(u-boot-env)ro,1536K(splash-image),3M(kernel),3M(kernel-backup),119M(rootfs) console=ttymxc0,115200 mem=128M init=/bin/sh
partition=nand0,0
mtddevnum=0
mtddevname=u-boot
name=u-boot
If you don't see such information, you will have to rebuild the U-Boot
environment with mkenvimage (or ask me for an image of it).
Second option: The kernel boots, and when it tries to mount the root
filesystem, the kernel panics:
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
lib80211: common routines for IEEE802.11 drivers
rtc-isl1208 1-006f: setting system clock to 2016-02-20 20:01:37 UTC (1455998497)
UBIFS error (pid 1): ubifs_get_sb: cannot open "ubi0:rootfs", error -19
VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0)
Please append a correct "root=" boot option; here are the available partitions:
1f00             512 mtdblock0 (driver?)
1f01            1536 mtdblock1 (driver?)
1f02            3072 mtdblock2 (driver?)
1f03            3072 mtdblock3 (driver?)
1f04          121856 mtdblock4 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[<c00293d0>] (unwind_backtrace+0x0/0xf0) from [<c0326da4>] (panic+0x60/0x190)
[<c0326da4>] (panic+0x60/0x190) from [<c0008ea0>] (mount_block_root+0x15c/0x20c)
[<c0008ea0>] (mount_block_root+0x15c/0x20c) from [<c00090d0>] (prepare_namespac)
[<c00090d0>] (prepare_namespace+0x8c/0x178) from [<c0008b50>] (kernel_init+0x10)
[<c0008b50>] (kernel_init+0x10c/0x14c) from [<c00258ec>] (kernel_thread_exit+0x)
This means that also the rootfs partition is corrupted. You will have
to mount another rootfs, over NFS. You will also need a kernel with
rootfs on NFS support.
Third option: the kernel boots, mounts the root filesystem, and you
end up with a login prompt. You're lucky, just the kernel partition is
corrupted.
# 5: Building a kernel with NFS support
To configure the kernel, I extracted the kernel source from the quby
openembedded tree and unpacked it in a separate directory, outside the
openembedded tree. The top-level kernel source directory is called
linux_r07/.
You can also use my compiled NFS kernel from:
   http://files.domoticaforum.eu/uploads/Toon/images/uImage-nfs.zip
In this directory, I put the following script:
#! /bin/sh
make CROSS_COMPILE=arm-linux-gnueabi- ARCH=arm menuconfig
This starts kernel configuration, using the correct compiler (I happen
to have arm-linux-gnueabi- around), for the right processor type
(arm). You can also use the cross-compiler from the openembedded tree,
just make sure it's in your search path.
Run the script, and edit the kernel configuration (the default .config
for toon is loaded by starting the script).
Under Filesystems, enter the submenu "Network file systems", tick the
boxes "root file system on NFS" and all NFS client options. Make sure
the tick boxes are marked with a * (built-in) and not an M
(module). Under "Enable loadable module support" untick the box
"Module versioning support".
Save the kernel configuration to a separate file (default is .config).
Copy the configuration file to the openembedded tree, in the subdirectory
~/oe/homeautomationeurope/recipes/linux/linux-quby2/
(~/ is the directory where you unpacked the openembedded tree)
Name it defconfig-2.6.36-R07-h11, this replaces the original
configuration file by quby. If you want to keep the old configuration,
back it up before you overwrite with the new kernel config file.
Now got to ~/oe/qb2, set the bitbake environment:
. ../bb_env.sh
and build the kernel:
bitbake linux-quby2
If you have built the linux kernel before, you may need to clean up first:
bitbake -c clean linux-quby2
The freshly built kernel ends up in
~/oe/qb2/tmp/deploy/images/uImage-qb2-hae-2.6.36-R07-h11-yyyymmddHHMMss.bin
with yyyymmddHHMMss the manufacturing timestamp.
Copy this image to /tftpboot/toon/uImage-nfs.
Your kernel is all set for booting toon over the network.
# 6: Preparing the root file system
If you have previously backed up your root filesystem (as a tarball),
now is a good time to unpack it.  Put the full contents of the rootfs
in /tftpboot/toon/rootfs.
If you have not made a back-up of your rootfs, you can use the
barebones rootfs that's made when the quby openembedded tree is built
according to the README file in that tree. This rootfs resides in
~/oe/qb2/tmp/rootfs/image-base-qb2. Copy the full contents of this
directory to /tftpboot/toon/rootfs, including links etc.
You can also use my copy of the barebone rootfs from:
   http://files.domoticaforum.eu/uploads/Toon/images/image-base-qb2.tar.gz
In the case that you need to flash the kernel, rootfs etc. onto toon
(typically images made with dd, or brand new ubifs images), place them
somewhere in the root filesystem where you can find them. /root is not
a bad place.
# 7: Booting toon over the network, with NFS root file system
At the U-Boot prompt, sequentially type the following lines: (I had
them ready in a script, copied them one by one to the U-Boot terminal)
dhcp
tftpboot 0xa1000000 toon/uImage-nfs
setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:/tftpboot/toon/rootfs,nfsvers=3,nolock,tcp console=ttymxc0,115200 loglevel=8 mtdparts=mxc_nand:512K@0x00100000(u-boot-env)ro,1536K(splash-image),3M(kernel),3M(kernel-backup),119M(rootfs) ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:toon::off panic=0
bootm
As in section 4 you can also set, parts, of the IP details manually.
This, sequentially, gets toon an ip adress, loads the kernel from the
TFTP server into memory, at address 0xA1000000, defines the root
filesystem as an NFS mount, read-write enabled, sets the URL of
the root file system, configures a terminal, configures mtd devices on
toon, and sets the network IP adress, NFS server, gateway, netmask,
hostname, and automated reboot when something fails. You need all of
this ;-).
The final line (bootm) starts the actual booting process.
If all goes well, you end up with a shell prompt on toon.
# 8: Recovery of the mtd partitions.
## splash screen ##
If you feel a bit uncomfortable flashing your toon, you can start with
the splash screen. The worst that can happen is that toon no longer
presents one. Screwing up the splash screen has no further
implications.
Before you can write to flash, old stuff has to be erased first. Just
start with erasing /dev/mtd1 (that's where the splash image resides):
flash_eraseall /dev/mtd1
and then, find a nice image, having the _EXACT_ size of 800x480
pixels, 24 bit colourdepth, and uncompressed windows .BMP format.
Flash it onto /dev/mtd1 with:
nandwrite -a -p /dev/mtd1 <whatever_its_name_is.bmp>
Reboot and enjoy your personalised toon splash screen.
## kernel ##
If only the kernel, u-boot environment, or splash image partitions are
corrupted, and you have managed to boot toon through tftpboot, you can
copy the images for the respective partitions to toon, through e.g.,
wget. If your images were ripped off the very same toon you now want
to put them back on, this is the way to do it:
(this will in general not work for a root filesystem image, will get
to that later).
Erase the partition you want to recover, in this example
/dev/mtd2. At the shell prompt, type:
flash_eraseall /dev/mtd2
then, if you made the rip with dd, dd is the tool to put it back:
dd if=ripped_partition_image_of_mtd2.img of=/dev/mtd2
This writes the kernel image back to the exact position where it came
from, including bad blocks.
If you only have an image file, made elsewhere, flash it onto the nand
by:
nandwrite -a -p /dev/mtd2 /path/to/image/file
This writes the image straight to the flash, skipping bad blocks if
they exist. In this example /dev/mtd2 was used, this method can be
applied to any partition (except the root filesystem).
CAUTION: write the kernel image ONLY after you have verified that all
the rest of your toon is in working order. Once the kernel is flashed
to NAND flash, you will have to go through the whole rooting process
again to stop it from booting (and subsequent panicking). If your root
filesystem is still corrupted, your toon will have kernel panics
during booting, and will be quite useless. It can always be fixed, but
it's no fun to do.
SO: TEST THE QUALITY OF YOUR ACTIONS EVERY STEP OF THE WAY.
And remember the second rule of sudo:
Think before you type.
# 9: Installation of the root filesystem
Toon uses ubifs for its root file system. UBI stands for Unsorted
Block Image, specifically designed for flash memory, and is quite
different from other file systems. One of the differences is that it
is not connected to a block device, and therefore, ubi images cannot
be loopback mounted. Quite annoying if you need to change things, or
have a corrupted filesystem. Even if you made an image of your rootfs,
there's no simple way to mount that image on another computer and work
with it. So, to install a UBIFS filesystem on your toon, you will need
the contents of that filesystem, on another computer, with a
filesystem that you can read and write. Contents means: all contents,
so this includes symlinks, pipes, and normal files. Device special
files aren't necessary, since these are made on the fly by udev.
UBIFS images typically are made from (sub) directory trees,
and subsequently written to flash.
If you already unpacked a rootfs tarball (section 6), tested it as an
nfs-mount, and are happy with it, to serve as toon's native root
filesystem, you can convert it to a ubi image, and reformat toon's
rootfs partition with it. If not, go back to section 6 and start
there.
## creating the ubifs image ##
Creating the image is done in two steps. Depending on the firmware
version, the ubifs parameters have different values.
## step 1 ##
When toon boots, it spits out information on the flash parameters of
the ubifs image. In earlier toons it looks like this:
0x000000600000-0x000000900000 : "kernel-backup"
0x000000900000-0x000008000000 : "rootfs"
UBI: attaching mtd4 to ubi0
UBI: physical eraseblock size:   131072 bytes (128 KiB)
UBI: logical eraseblock size:    129024 bytes
UBI: smallest flash I/O unit:    2048
UBI: sub-page size:              512
UBI: VID header offset:          512 (aligned 512)
UBI: data offset:                2048
in later versions, this has changed into:
UBI: logical eraseblock size:    126976 bytes
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
As you can see, the LEB (logical eraseblock) size, VID header offset, and data
offset have changed. This influences the way the rootfs image should be made.
The ubi filesystem is made with mkfs.ubifs.
This program has (among others) the minimum sub page size (-m
option), and LEB size (-e option) as arguments.
For the older versions (approximately first number in the serial
number < 15, check with bootstrap data) this is:
mkfs.ubifs -r ./rootfs/ -m 512 -e 129024 -c 954 -o toon_rootfs_ubifs.img
Newer versions should use:
mkfs.ubifs -r ./rootfs/ -m 2048 -e 126976 -c 954 -o toon_rootfs_ubifs.img
This creates a ubifs image from the contents of ./rootfs/ (without
rootfs/ as the top-level directory). The image is stored in the
current directory, with the name toon_rootfs_ubifs.img.
The arguments for mkfs.ubifs were copied from toon bootstrap data. The
numbers are connected to the physical flash chip, and should be kept
as they are, for your version of toon, otherwise the flashed rootfs
will not be bootable.
## step 2 ##
The second step of the image building involves the preparation of the
raw flash image. this is done with the ubinize command. Again,
depending on your toons version, two variants exist:
older:
ubinize -vv -o rootfs.ubi -m 2048 -s 512 -p 128KiB ubinize.ini
newer (SN 15- and (possibly) later):
ubinize -vv -o rootfs.ubi -m 2048 -p 128KiB ubinize.ini
Ubinize adds physical flash chip information to the image (physical
eraseblock size and some others). Besides some cli arguments, most
settings are done in a configuration file, having .ini style
formatting. For this example, the file is called ubinize.ini, and is
the same for the two variants of toon:
Contents of ubinize.ini:
[ubifs]
mode=ubi
image=toon_rootfs_ubifs.img
vol_id=0
vol_type=dynamic
vol_name=rootfs
vol_flags=autoresize
Again, keep the arguments as they are, you can change names, but do
not change volume id, eraseblock sizes etc. After completion of the
ubinize command, the file rootfs.ubi contains a rootfs image, ready to
be written to flash.
## writing the image to flash ##
Transfer the ubi image to the nfs-mounted root filesystem of your
toon. Then, flash the image to the rootfs device with ubiformat:
ubiformat /dev/mtd4 -f rootfs.ubi
Try the new filesystem, by rebooting according to section 4. If all is
well, your toon should boot normally.
TETS THOROUGHLY IF EVERYTHING WORKS AS PLANNED, and then, as a last
step, flash the kernel image of choice to /dev/mtd2.
If all went well, you now have a working toon again.
# 10: Repairing stuff on a bricked toon.
Since the update of busybox to 1.27.2-r1, some people have tried to
upgrade to 1.27.2-r4, and failed, for various reasons. This resulted
in a non-available /bin/sh, which is quite lethal for a unix-style OS.
To fix this, the following is required:
1: Set up an NFS server and TFTP server as described in sections 1-4
   of this manual. There's no need to build the kernel image and
   rootfs from scratch, instead you can download them from:
   Unzip, and put them somewhere where toon can find them. In this
   example in /tftpboot/toon/uImages-nfs and /tftpboot/toon/rootfs,
   respectively.
2: Boot the bricked toon according to the steps in section 7.
   ogin as root. No password required. Mount the proc and sys folders:
      mount /proc
      mount -t sysfs none /sys
3: On the first usage of the rootfs you need to run these commands.
      mknod /dev/mtd1 c  90 2
      mknod /dev/mtd2 c 90 4
      mknod /dev/mtd4 c 90 8
      mknod /dev/ubi0 c 252 0
      mknod /dev/ubi0_0 c 252  1
      mknod /dev/ubi_ctrl c 10 63
      mkdir /mnt/rootfs
4: Mount the native root filesystem by executing the following:
   a: Attach the ubi rootfs to a device descriptor:
      ubiattach -p /dev/mtd4 -O 2048
      depending on the version of your rootfs, you may need to omit the
      -O 2048 option. ubiattach will give an error if it's needed.
   b: Mount the native rootfs of your toon (on older toons, /mnt can
      be used as mount point, on newer ones, this is already in
      use. In that case, create another one).
      mount -t ubifs ubi0:rootfs /mnt/rootfs
5: Your rootfs is now mounted on /mnt. You can now start to restore
   parts of your toon like busybox or libraries which causing your
   toon not to boot anymore.
6: When you are satisfied with the result, you can reboot your toon
   normally, and everything should be working.
# # 11: What if the bootloader is corrupted?  #
Then you have a different problem. Without a working boot loader, the
only access to your toon is through JTAG. JTAG is quite another kettle
of fish than the stuff presented here. I have accessed my toon through
JTAG, so if you end up in these parts, you can contact me through
domoticaforum.eu. Not sure if I can help you, though.
