I am considering replacing my old RFXCOM lan transceiver (with 868 receiver board) with a new RFXCOM USB version. I am using HomeSeer HS3.
Apart from the 868 frequency devices, do I loose any functionality? And how do I replace the device in HS3? Hopefully I don't have to recreate all devices (I have 50+ devices, and 100+ virtual devices related to RFXCOM...)
Thanks for your advice!
HS3 replace RFXCOM lan
- b_weijenberg
Re: HS3 replace RFXCOM lan
Configured devices receive/transmit by the RFXLAN and RFXtrx433E are processed identical so no need to reconfigure devices.
You can have the RFXLAN and RFXtrx433E both connected to HS3.
To access the RFXtrx433E over LAN connect it to a RaspberryPi and install ser2net.
Great. Thanks for the quick answers!
