Toon firmware: issues (and solutions)
RDNZL
Post by RDNZL »
After upgrading my Toon from version 3.5.x to 3.6.x I see that the opentherm stats are all zero, anyone else has seen this?
Any known way to enable them again?
Did a reboot, and waited a while, keteladapter status is oke, everything else works fine.
http://192.168.x.x:10080/happ_thermstat?action=printTableInfo
info = [
{'dataId':'0', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 0: 00 00, SlaveState burn=NoFlame, fault=0]'},
{'dataId':'1', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 1: 00 00]'},
{'dataId':'2', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 2: 00 00]'},
{'dataId':'3', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 3: 00 00]'},
{'dataId':'15', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 15: 00 00]'},
{'dataId':'17', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 17: 00 00, RelModLvl=0.00]'},
{'dataId':'25', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 25: 00 00, TempBoiler=0.00]'},
{'dataId':'5', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 5: 00 00]'},
{'dataId':'6', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 6: 00 00]'},
{'dataId':'9', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 9: 00 00]'},
{'dataId':'16', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 16: 00 00, RoomSetpoint=0.00]'},
{'dataId':'18', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 18: 00 00]'},
{'dataId':'24', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 24: 00 00, RoomTemperature=0.00]'},
{'dataId':'26', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 26: 00 00]'},
{'dataId':'27', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 27: 00 00]'},
{'dataId':'28', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 28: 00 00, TempReturn=0.00]'},
{'dataId':'35', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 35: 00 00]'},
{'dataId':'48', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 48: 00 00]'},
{'dataId':'56', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 56: 00 00, DHW Setpoint=0.00]'},
{'dataId':'57', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 57: 00 00]'},
{'dataId':'73', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 73: 00 00]'},
{'dataId':'113', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 113: 00 00]'},
{'dataId':'114', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 114: 00 00]'},
{'dataId':'115', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 115: 00 00]'},
{'dataId':'116', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 116: 00 00, BurnerStarts=0]'},
{'dataId':'117', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 117: 00 00]'},
{'dataId':'118', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 118: 00 00]'},
{'dataId':'119', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 119: 00 00]'},
{'dataId':'120', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 120: 00 00, BurnerHours=0]'},
{'dataId':'121', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 121: 00 00]'},
{'dataId':'122', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 122: 00 00]'},
{'dataId':'123', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 123: 00 00]'},
{'dataId':'127', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 127: 00 00]'}
Regards, Ron.
Re: Toon firmware: issues (and solutions)
Hi Ron,
Moved your post to a separate topic. Seemed more appropriate to me. The last update (3.6.3) was a major one. It encompassed the renewal of all the Quby software on toon. Looking at the issues that are being reported at their forum, your findings may well be a part of the problems they have right now.
From the hcb_config.xml file, it looks as if they have returned to the original port number for the web services:
	<hcb_web>
		<!-- Release uses lighttpd; put hcb_web somewhere where its harmless -->
		<port>7080</port>
		<defaultEntry>/hdrv_zwave/</defaultEntry>
Is your boiler working properly?
best,
cvdpol01
Post by cvdpol01 »
I updated also my Toon to the newer version when I rooted it. It tested also the scripts of Ierlandfan and got the same output of RDNZL. This are the files in the /HCBv2/www/happ_thermstat. Maybe this can help searching a solution.
happ_thermstat.zip
(18.63 KiB) Downloaded 901 times
RDNZL
Post by RDNZL »
Sorry, I was looking for a correct place to create my post ;P
My Toon is still using the 10080 port, it was for a long time even the port 7080 was still present in hcb config.
It's defined in lighttpd.conf
tcp        0      0 0.0.0.0:10080           0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:8000          0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:5555            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:1337            0.0.0.0:*               LISTEN
I'm comparing an old backup and new one, found some diffs in cfg files, but restoring them didn't bring the values back yet.
Heating and toon itself are working fine.
Regards, Ron.
So it's a software thing, right, not the configuration?
Can you roll back to the previous version (3.5.4)? In 3.6.3 almost everything regarding the toon application has been updated. Just the kernel and base system + base libraries remained untouched. Hard to pinpoint a specific application in this case, although happ_thermstat and hcb_comm may be the first ones to look into, or one of their libraries. Not sure how backward compatible these libs are, though.
best,
cvdpol01
Post by cvdpol01 »
Hi Ron, Do you have any luck?
Ierlandfan
Post by Ierlandfan »
If you look at the output of ./happ_thermstat -vvvvv you can see that the values are read but that the table is not updated (error or deliberate)
You can see in hcb_projects.xml that there are references to the not working table (No idea they use a new logger function it seems)
You can revert back to for example happ-thermstat - 1.554-trunk.ipk and it works. I had the same error. (IPK attached)
If anyone (and if exist) has a more recent version please attach it here.
happ-thermstat_1.554-trunk_qb2.rar
(166.37 KiB) Downloaded 865 times
Ierlandfan
The also introduced an error in the output of getThermostatInfo
(It's not valid json anymore because they added an "," at the end before the }
To make it valid json again:
$modulation_data = file_get_contents('http://IP_TOON:7080/happ_thermstat?action=getThermostatInfo');
$replace = str_replace(',}', '}', $modulation_data);
$modulation_array = json_decode($replace, TRUE);
Hi Ierlandfan,
The happ_thermstat version you uploaded is the one that came with update 3.0.29.
Does it work well with the software of update 3.6.3? Did you test it?
best,
Ierlandfan
Yes, I did test it myself, it's working like a charm. I simply removed happ_thermstat 3.6.3 (opkg remove) and installed the attached version, no problems detected. Everything still works.
opkg list-upgradable
happ-thermstat - 1.554-trunk - 1.852-ene-master
Ierlandfan
Here's the snippet from the debug in 3.6.3 (I upgraded just for this :-)
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 0: 00 00, SlaveState burn=NoFlame, fault=0] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 1: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 2: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 3: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 15: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 17: 00 00, RelModLvl=0.00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 25: 00 00, TempBoiler=0.00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 5: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 6: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 9: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 16: 00 00, RoomSetpoint=0.00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 18: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 24: 00 00, RoomTemperature=0.00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 26: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 27: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 28: 00 00, TempReturn=0.00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 35: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 48: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 56: 00 00, DHW Setpoint=0.00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 57: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 73: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 113: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 114: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 115: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 116: 00 00, BurnerStarts=0] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 117: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 118: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 119: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 120: 00 00, BurnerHours=0] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 121: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 122: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 123: 00 00] updated=0
[happ_thermstat:../src/ch_man.c@ch_printTableInfo():92]AddInfo [ID 127: 00 00] updated=0
To downgrade to 1.554: winscp or scp happ-thermstat_1.554-trunk_qb2.ipk to /tmp
then issue
cd /tmp
opkg install --force-downgrade happ-thermstat_1.554-trunk_qb2.ipk
cvdpol01
Post by cvdpol01 »
Thanks Ierlandfan,
I did the downgrade as well and after that I saw the results in de printTableInfo :-)
It's working.
RDNZL
Post by RDNZL »
Will try the downgrade too, didn't had time to look into it earlier...
Can this downgrade create a conflict on next Enecon upgrade?
Regards, Ron.
Most probably, the next upgrade will overwrite this downgraded package with the latest version of it.
BrainHunt
Post by BrainHunt »
Probably a dumb question but how can I upgrade the firmware of the (hacked) Toon anyway?
(see some comments about .sh scripts in other topic but don't see the actual scripts)
Return to “Toon Firmware”
