Flamingo SF-501 switches.
ramnol
Post by ramnol »
I bought today a cheap set of switches: Flamingo SF-501 (three switches and a remote control).
They are suppose to be compatible with home wizard.
Can these switches be controlled by the Rfxcom transmitter?
Thanks in advance.
Ramnol.
MrMikenl
Re: Flamingo SF-501 switches.
Post by MrMikenl »
Yes they can be controlled by the RFXCOM.
I have bought the same set (really cheap at "Action" and they work in my case. (RFXCOM + Domoticz on a Pi 3b)
frankvl76
Post by frankvl76 »
Hi Mike,
I'm trying to get these switches working but i can't seem to fix it. How did you figure out the codes for all buttons (on/off)? Did you use RFSniffer for this? Because, this doesn't work for me. I must be doing something (if not a lot) wrong. Have u got some suggestions?
Thanks,
Frank
hew
Post by hew »
I've also bought the SF-501 ,
to my raspberry i've connected a RF 433 receiver and transmitter kit
When sending codes with the codesend command I receive them with RFSniffer
however when transmitting with the RF501 remote controller I don't receive anything with RFSniffer (the switches are working so i know a signal is transmitted)
anyone any idea how to get it working?
thanks i advance
b_weijenberg
Post by b_weijenberg »
Flamingo SF-501 can be controlled by all RFXCOM transmitters and transceivers using the RFXCOM - AC protocol.
The SF-501 remote is received by all RFXCOM receivers and transceivers.
