Page 1 of 2
more then 50 modules
Posted: Fri Jan 20, 2017 4:13 pm
by Harry
i like to expan my source network, but is it possible to add more the 50 modules ?
Re: meer dan 50 modules
Posted: Fri Jan 20, 2017 4:23 pm
by LoveHomey
see the licence page in your source program in program section how much you are licensed to. you can buy more licenses
Posted: Fri Jan 20, 2017 6:42 pm
by Akatar
it depends
you can check this in youre source software
check: instellingen -->programma
Posted: Fri Jan 20, 2017 7:19 pm
by Harry
oke i see licence 25 to 250 modules then i would be oke :D
Re: more then 50 modules
Posted: Sat Jan 21, 2017 7:39 pm
by PietjeNL
Max 64 modules a network, or you need a second network aka stick an +C+ module.
Posted: Sat Jan 21, 2017 9:14 pm
by Akatar
in that case you need the "mulitple network" option
Posted: Sat Jan 21, 2017 9:35 pm
by Harry
how can i see if i have the multiple network option ?
i have the licence options
* 25 to 250 modules
* Data export
* web server
and run Source version:
Pro 2.25
Posted: Sat Jan 21, 2017 9:42 pm
by Akatar
in my case:
Posted: Sat Jan 21, 2017 10:30 pm
by Harry
now i am stil not sure how much modules can be added to my source software?
do i need more licenceopties.
Posted: Thu Jan 26, 2017 3:07 pm
by PietjeNL
You can have allot of modules and stick's/networks.
But without the multiple networks you can only use 1 stick/network of 64 modules at the time.
Posted: Wed May 23, 2018 6:17 pm
by Harry
someone now what a mulitiple network option cost?
Posted: Thu May 24, 2018 12:27 am
by Akatar
i thought there was a hack to do this, it was somewhere on this board
Posted: Sat May 26, 2018 12:40 am
by jeroenc
How did you get "data export"?
Sent from my iPhone using Tapatalk
Posted: Sat May 26, 2018 10:26 am
by Akatar
jeroenc wrote:How did you get "data export"?
that was a standard feature.
Posted: Sat May 26, 2018 3:27 pm
by Harry
i had to request data export.
in the first versions it was standard, after a upgrade it was suddenly a licencend option.
i got the option for free.
i only need the multi network, i think that is an expencive upgrade.
