Is RFXTRX868 supported in Homeseer?
rovinge
Post by rovinge »
Bert,
Question - is the RFXTRX686.00 (beta) supported by the Homeer plug-in, or not?
Is the rfxtrx868 supported by de Homeseer plugin?
Im a running Homeseer 3.0.0.312 with RFXCOM 30.0.0.33 + rfxtrx433 without any problems
Recently I added the rfxtrx868 (beta), but for this one I can only select 868.30 (fsk) / 868.35 (fsk) or 868.96; not 868.00.
The rfxtrx433 is connected via COM4 with fw 1015, the rfxtrx868 via COM6 with fw 1005.
Under the plug-ins > rfxcom > rfxtrx/rfxrec I can add another tranceiver and select COM6, but not the right 868 model. This also shows in the logs as being "wrong transceiver selected".
Also, with homeseer shutdown, via rfxmgr the rfxtrx868 is recognized and I can control my ITHO FAN correctly.
Your help appreciated.
Roel
PS. I've posted a similar message/question on the homeseer forum as well.
Akatar
Re: Is RFXTRX868 supported in Homeseer?
Post by Akatar »
i use this one
rovinge
Post by rovinge »
Thanks for the feedback.
With help from Bert I was able to get the RFXtrx868 working in Homeseer.
Roel
Fischi
Post by Fischi »
Where do you have the trx868 have from ?
I'm also very interested in this device, bacause I'm afraid that someday my RFXLAN with visonic slave receiver will crash
and all my visonic Sensors would be useless.
Regards, Fischi
PeterJohn48115
Post by PeterJohn48115 »
Hi...i am a new user here. Is the rfxtrx868 supported by de Homeseer plugin?Running Homeseer 3.0.0.312 with RFXCOM 30.0.0.33 + rfxtrx433 without any problems.
I recently added the rfxtrx868 to it, but I can only select 868.30 (fsk) / 868.35 (fsk) or 868.96. Not 868.00.rfxtrx433 is connected via COM4 with fw 1015, the rfxtrx868 via COM6 with fw 1005.Under the plug-ins > rfxcom > rfxtrx/rfxrec I can add another tranceiver and select COM6, but not the right 868 model. This also shows in the logs as being "wrong transceiver selected".
With homeseer shutdown, via rfxmgr the rfxtrx868 is recognized and I can control my ITHO FAN correctly.
