Page 76 of 76
Re: Toon app: Afvalwijzer
Posted: Fri Apr 29, 2022 10:28 am
by Toonz
Probably something wrong at Meerlanden.nl or the waste2api platform.
I can't get your calender either, the provided links via the website are not working
Posted: Tue May 03, 2022 8:26 am
by flamingbob
Hi Toonz,
Thank you for the update. Been offline for a while for some personal reasons. Will also check or poke them to fix it. Thanks!
Posted: Fri May 13, 2022 3:54 pm
by whizzz63
Hi, is it possible to add RWM to the app?
Posted: Fri May 13, 2022 9:06 pm
by Toonz
whizzz63 wrote: ↑Fri May 13, 2022 3:54 pm
RWM.nl is using mijnafvalwijzer.nl.
Select provider 1 in the settings screen and fill in your postcode/housenr
Posted: Sun May 15, 2022 7:58 pm
by whizzz63
Thanks, it works!
Posted: Tue May 17, 2022 7:43 pm
by HansieNL
Toonz wrote: ↑Sun Jan 02, 2022 5:46 pm
you can make the following change for now in the file /qmf/qml/apps/wastecollection/WastecollectionTile.qml :
replace the 7 lines :
visible: dimState ? (!app.wasteIconShow && !app.wasteIcon2Show) : true // only show in non-dim if no icons are shown
with
to go back to the original behaviour
I changed the WastecollectionTile.qml and get the icon at the top right of the screen in a Toon 1.
Is it possible to have the icon at the old position, which was at the center of the screen below the time?
Posted: Thu May 19, 2022 12:13 am
by Toonz
you can uninstall the app via the ToonStore en reinstall again to get the original file back. Your settings will be preserved....
Posted: Sun May 29, 2022 12:35 pm
by Toonz
I added borssele.nl.
Go to the settings screen of the app and select provider 49.
Enter your zipcode/housenr and press 'Opslaan'.
Toon will download the new plugin and restart once to activate it.
Posted: Sun May 29, 2022 6:59 pm
by oepi-loepi
Great, thank you!
