X11VNC not working in 4.9.23
gielie
Post by gielie »
HI,
I can't get x11vnc working in 4.9.23, it was working fine in 4.8.25 but after the update it stops working after i start x11vnc.
I tried to reinstall it but with no luck.
Does someone has an idea how i can get x11vnc working again?
btw this is what my console gives.
The SSL VNC desktop is:  eneco-001-003065:0
PORT=5900
SSLPORT=5900
eneco-001-003065:~# x11vnc
The SSL VNC desktop is:  eneco-001-003065:1
PORT=5901
SSLPORT=5901
eneco-001-003065:~#
So after each start it picks another port number.
lxz
Re: X11VNC not working in 4.9.23
Post by lxz »
What do you mean by 'stops working'? Is it unreachable by your vnc client?
Usually vnc opens an other port when you start the process a second time
Can you check if it is already running (with 'top' or 'ps')?
And is port 5900 opened in your iptables.conf?
michel30
Post by michel30 »
I think that the update did also update x11vnc and that does not work.
I had the same problem before.
What you can do, is uninstall the package and install the package from this site and that works for me.
Michel
yjb
Post by yjb »
If you want to check if vnc is running:
Toon:~# netstat -pant |grep LIST
tcp        0      0 0.0.0.0:10080           0.0.0.0:*               LISTEN      709/lighttpd
tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      27991/x11vnc-bin
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      709/lighttpd
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      623/dropbear
tcp        0      0 127.0.0.1:1337          0.0.0.0:*               LISTEN      671/HCBv2 hcb_comm
tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      27789/dropbear
If it is indeed running, it shows the port. If the port is not accessible I would expect that something is wrong with the firewall rules.
gielie
Post by gielie »
Ok I see now VNC is already running, twice on different port numbers but yet unreachable, I’ll have to check the firewall.
One thing I don’t understand, before on fw8.4.25 when I started vnc it was running in the console and I could stop it with ctrl c, how to I stop vnc now from running?
I started from scratch and this is what happend.
 eneco-001-003065:~# opkg install x11vnc_0.9.13-r0_qb2.ipk
Installing x11vnc (0.9.13-r0) to root...
Configuring x11vnc.
Enter VNC password:
Verify password:
Write password to /root/.vnc/passwd?  [y]/n y
Password written to: /root/.vnc/passwd
WARNING: can't open config file: /usr/lib/ssl/openssl.cnf
[s] i still can't log in.[/s]
Ok ik used open vnc and that didn't work, i went to tiger vnc and that solved the problem.
1 thing remains, before i could stop x11vnc with ctrl c, how do i stop the server now?
michel30
Post by michel30 »
My toon works with x11vnc.
I used the x11vnc package from this forum.
I edit this file /etc/inittab and add in this line
 x11v:5:respawn:/usr/bin/x11vnc
HenkP
Post by HenkP »
Toon works with x11vnc, but after a power off-on x11vnc is not self restarting.
Where or what can I edit for a auto restart off X11vnc?
Thanks
HenkP
Post by HenkP »
Thanks, but that don`t workt for me. posting.php?mode=reply&f=87&t=11854#
You can always write a small shell script to startup x11vnc, and pop that into /etc/init.d
Then x11vnc will start at least at boot-up.
gerlag
Post by gerlag »
Small addition:
For those where automatic restart of x11VNC server after reboot is not working, using the init.d or inittab approach, (see here), the alternative crontab solution could work as a last resort. Which was the case in my situation.
eneco:~# crontab -e
# crontab for root
#      The time and date fields are:
#             field          allowed values
#             minute         0-59
#             hour           0-23
#             day of month   1-31
#             month          1-12 (or names, see below)
#             day of week    0-7 (0 or 7 is Sunday, or use names)
SHELL=/bin/sh
*/5 * * * * /root/bin/buienradar_get_data_5min.sh
2 */1 * * * /root/bin/buienradar_get_data_hourly.sh
@reboot /usr/bin/x11vnc
(I added the line)
Then type:
 ESC :wq
Then reboot
shutdown -r now
and check if x11VNC has automatically started.
tcp        0      0 0.0.0.0:10080           0.0.0.0:*               LISTEN      707/lighttpd
tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      1012/x11vnc-bin
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      707/lighttpd
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      624/dropbear
tcp        0      0 127.0.0.1:1337          0.0.0.0:*               LISTEN      680/HCBv2 hcb_comm
