while opening my Toon, a little grey square sticker fell out. (1mm thick)
Does somebody know where it belongs? Does it have to protect or isolate something?
thanks!
Bart
where to put this grey "sticker" in my Toon?
Re: where to put this grey "sticker" in my Toon?
I think it's on top of the temperature sensor. The back of toon (grey part) has a neat square slot where it should go. Just put it in there before you close your toon.
I wonder what the point is of putting a thermal pad there?
It doesn't really make good contact with the sensor chip and the chip is pretty much shielded by plastic. (i see no holes)
Guess I was not the only one with this issue. Here it fell out too.
Put it back now with the help of this thread. Thanks!
Hmm, I also saw it falling out but never figured out/bothered to place it back
But sometimes I wonder if the temperature sensor is correct, seems a little high, maybe this is the cause?
Anyway there's an offset I believe, to adjust the temperature.
