I'm planning to design a PCB with the ability to program the pic in circuit on the pcb.
I've seen I have to remove the trace between RB1 and RA5, because of the 13v programming voltage, which pin RB1 doesn't like
Can you tell me the function of RB1 in the otgw? And why it's connected to RA5 and its pull up resistor and reset function?
Is it ok to leave RB1 floating, like RA2 and RB0? Maybe you know what will happen if I do so.
Is the trace a fault, or needed for something else?
Thanks in advance.
Edrelais
NL
