RFXCOM find remote signal Tumoco
doludizgin
Post by doludizgin »
I have setup my RFXCOM on my Pi. It works with the most of my 433mhz switches.
My window shutters are also on the 433mhz (i can find that on a sticker on the remote) but i unable to capture the signal.
I've activated al the modes on the rfxcom but no luck, is there a way to maybe raw capture etc ?
Its an Tumoco electric motor.
b_weijenberg
Re: RFXCOM find remote signal Tumoco
Post by b_weijenberg »
This device is not in the list of supported devices.
Please see chapter 2 in the RFXtrx User Guide for the list of supported devices.
For support on RFXCOM contact support rfxcom.com
doludizgin
ah i see.
I knew that the device wasn't supported from the list. Is this software or hardware lacking the support ?
If its software maybe i can contact Tumoco (dutch company) and that i can get some more info about the protocol it uses for transmitting of signals. It can also learn new remotes so maybe we can do something with that feature.
If its hardware then its the end of this story :), thanks anyway!
b_weijenberg
For support on RFXCOM please contact support rfxcom.com
Lettereend
Post by Lettereend »
Dit zijn ACM motoren en worden in Italië gemaakt, http://www.acm.it
