Is it possible to stretch te wire of a CM11 with about 7 meters with RJ11 connectors and a telefoon cable.
Is it not bat for the signal strengt between the CM11 and USB port of the PC.
Thnx for the answers.
CM11 wire stretch about 7 meters
The CM11/12 is only 4800 baud so yes you can do this, but you need all four pins connected and it should be straight-through. It's smaller than RJ11, 4P4C "RJ10"
http://en.wikipedia.org/wiki/RJ11,_RJ14,_RJ25
Cheers, Steve
Cheers, Steve
