issue meteradapter with slimme meter Toon2
Forum about Toon hardware, both versions 1 and 2 of Toon
Locked
dennis071nl
Post by dennis071nl »
Hi guys,
Today one of the heroes got my new Toon 2 rooted, so right now i'm trying to set it up, but finding one problem with my meteradapter.
I'm using the Toon 2 in combination with a slimme meter, which is connected though a P1 cable.
I connect it, in the last configuration step i can only choose electricity. In the end no errors on the Toon itself, but no electricity or gas usage is reported. I found out that in the prductversie section i have the serialnumbers for both main unit and keteadapter, but for meteradapter there are only dashes...
Anybody who can help me out??
Dennis
Re: issue meteradapter with slimme meter Toon2
Just an idea : have you tried to remove the meteradapter first and then reconnect when put in a power socket near Toon?
dennis071nl
yeah, apparently there is nothing wrong with the connection: 5 stars...
it says "verbonden"as well...
Post by TheHogNL »
Try to reset the meteradapter. Not sure how exactly but i think it is holding the button on the meteradapter for 10 seconds. Then re-add it.
For the first install keep it close to the toon2.
Maybe look in the /qmf/log dir for clues? Or start /qmf/sbin/hdrv_zwave manually to check if there are issue's.
dennis071nl
I changed some entities in happ scsync and now all is fine. Thanks for all the help, Topic can be closed!
Post by TheHogNL »
Ok great.
Probably elecusage and gasusage was still 0 ?
Locked
Return to “Toon Hardware”
