Opentherm support
Posted: Thu Oct 25, 2018 6:18 pm
by hansgrave
My Toon is installed on my Intergas HRE ketel with the ketelmodule on opentherm. The heating works fine and i can see the status CV / WW. But when i select the tile with "ketelstatus" is see the message "geen opentherm support". Also there is no incoming information of modulation level, boilertemperature etc in Domoticz. Is there a setting wrong? Firmware is 4.18.8, ketelmodule 37.
Re: Opentherm support
Posted: Thu Oct 25, 2018 10:19 pm
by TheHogNL
What does the 'aansturing cv-ketel' say under 'menu-verwarming'? If it does not say opentherm, that's where you need to fix that
Posted: Thu Oct 25, 2018 10:49 pm
by hansgrave
It says opentherm, even if i select "aan/uit" and hit the refresh button then he switch to opentherm. So it seems that Toon reconige the proper mode.
Posted: Fri Oct 26, 2018 4:10 pm
by TheHogNL
Which tile do you mean? I'm not familiar with a 'ketel status' tile
Posted: Fri Oct 26, 2018 4:42 pm
by marcelr
Not sure which version of the boiler status app you are using. The earlier releases relied on the web output of the control software; that has been discontinued since FW 3.5.4, and hence gives you this error. Later versions of the app should report a subset of the datapoints in the original app.
Posted: Fri Oct 26, 2018 6:14 pm
by hansgrave
TheHogNL wrote:Which tile do you mean? I'm not familiar with a 'ketel status' tile
On a empty tyle i can select under algemeen the tyle ketelstatus. It can show modulation level etc
Posted: Fri Oct 26, 2018 6:16 pm
by hansgrave
marcelr wrote:Not sure which version of the boiler status app you are using. The earlier releases relied on the web output of the control software; that has been discontinued since FW 3.5.4, and hence gives you this error. Later versions of the app should report a subset of the datapoints in the original app.
The app boilerstatus is version 1.0.4., the latest version. In the Toonstore.
Posted: Sat Oct 27, 2018 8:24 am
by TheHogNL
The funny thing is that this message "geen opentherm support" is not in the code of the boilerstatus app.
Posted: Sat Oct 27, 2018 9:32 am
by Toonz
Aren't you confused with the official ketel monitor app from the standard firmware?
Our boiler status app only has a tile which you need to put on one of the empty slots on your homescreen. Just guessing...
Posted: Sat Oct 27, 2018 11:42 am
by hansgrave
Tile whit selected ketelstatus
Ketelstatus to select
Here some screenshots. Is this the original app? Can show the boilerstatus app from de Toonstore some information on a tile?
Posted: Sat Oct 27, 2018 5:47 pm
by Toonz
Ok, got it.
Somehow you have the very old legacy version 0.1 of the boilerstatus app installed, this one is not supported anymore.
Can you remove the boilerstatus app from the ToonStore and after that manually delete all 'boilerstatus*' folders you have left in /qmf/qml/apps ?
When completed install the new boilerstatus app again via ToonStore and you should be fine with a nice tile showing you the available boiler parameters.
The fact that version 0.1 was installed blocked a proper installation of 1.0.4 because the symlink to the 1.0.4 folder could not be created.
Basically you always kept using version 0.1 in the boilerstatus folder instead the one in the boilerstatus-1.0.4 folder.
Anyway, have fun now... :-)
Posted: Sat Oct 27, 2018 6:16 pm
by hansgrave
Many thanx for helping me, that solved the problem! :D
