Change Radiator type
Hey,
Just checking my CV flow temperature.
Because my intergas only giving me 40 degree max.
Intergas cv temp was 80 max but (i think toon managing this) its not going higher than 40.
But now i'm looking in toon for the radiator type setting and the only think i can find is how to correct the room temp sensor.
So is it gone as it was in the older versions?
Or did i make a change in the config that disabled this function?
Grz,
Jos
Grz,
Jos
Re: Change Radiator type
Go to "instellingen" then "verwarming" and "verwarmingsinstellingen". There you can set the type of heatingsystem and watertemp.
Gr Hans
Gr Hans
Homey, rooted Toon 1 and HomeAssistent.
That's the problem:
It's not there.
It's not there.
Are you using opentherm? Only with opentherm Toon can manage the maximum water temperature.
Thanks for your interests.
But found a solution in a different topic.
* viewtopic.php?f=95&t=11232&hilit=type+v ... g&start=15
Renamed "config_happ_scsync.xml" and rebooted Toon.
After that started update_rooted.sh with -f and after that again a reboot.
And voila it's working again.
Compared the old and new scsync, but there were multiple changes so not a good reason for it.
Seeing your sreenshot you somehow managed to change your toon from boiler heating to district heaten. Do you still have a backup of that scsync file? Would love to see it.
Yes, it's still on my Toon (because I really like renaming instead of deleting as of a backup )TheHogNL wrote:Seeing your sreenshot you somehow managed to change your toon from boiler heating to district heaten. Do you still have a backup of that scsync file? Would love to see it.
Will post the old and new file this evening.
Change:
to
In youre scsync file. And reboot toon. (Open Putty console, and type: reboot -f)
<HeatDisplay>1</HeatDisplay>
<HeatDisplay>0</HeatDisplay>
i Had the same problem with the radiator type.
i did follow the instructions to resolve this but now my toon has only the option OpenTherm and i cannot change that value.
what is the problem ?
There's no problem, Toon checks on OT possibilities at boot-up, and switches to OT when available.
Okay i understand that, but i think, when before my toon was rooted, i can change that opentherm to verwarming. but now it stuck to opentherm.marcelr wrote:There's no problem, Toon checks on OT possibilities at boot-up, and switches to OT when available.
i did an test to check it.
i removed the 2 wires from the OT Connection of my benraad and changed them to the on/off connection. i rebooted the toon and the toon still detect opentherm.
thats strange because on/off is not opentherm.
so i think on my rooted toon there is something broken in software setting or so.
On the GUI you can only switch between Opentherm and Aan/Uit which tells you which method the Toon is connecting to your boiler.
Switch to heating (for example for district heating) is done in the scsync file.
i understand that but now i cannot change from opentherm to verwarming aan/uit in the gui anymore.TheHogNL wrote:On the GUI you can only switch between Opentherm and Aan/Uit which tells you which method the Toon is connecting to your boiler.
my toon gives information that my boiler is on but the radiator stay cold.
how is that posible ?
Can you post a picture? Switching to aan/uit is just flipping the switch to the right.
Did you try turning it off and on again? BTW, if your boiler isn't working it would be a better idea to call your service engineer
My boiler is working now.TheHogNL wrote:Can you post a picture? Switching to aan/uit is just flipping the switch to the right.
but i have to change the parameter in the config_happ_scsync.xml manuall to have it work.
<HeatDisplay>1</HeatDisplay> change this digit to (zero) put my toon to opentherm. change it back to (one) it sets my toon to verwarming.
i know that this option can be set within the gui but that does not work in my toon.
