Toon2 does not show power usage
BOverdevest
Post by BOverdevest »
HI
I have a Rooted Toon2.
I just noticed that from 1st of January the gas usage is no longer picked up, shows zero for each day/ hour.
Power is being picked ok, both day and night power. Connection with the P1 meter shows green.
Also my domoticz system collects zero's
I run version 4.19.10, i have already tried rebooting.
any ideas?
greetings
Bart
B Overdevest
Rooted Toon, Raspberry 3B+, Domoticz
Re: Toon2 does not show power usage
Post by TheHogNL »
mAiden
Post by mAiden »
Have you already been informed that your energy supplier will receive gas information from youre meter? Otherwise it may be that your gas meter is in failure.
BOverdevest
Never mind, i just saw on the Enerlogic website that it also shows my actual usage to be zero.
So, the issue is in the slimme meter itself. Could turn out to be a cheap month....
Bart
B Overdevest
Post by TheHogNL »
BOverdevest wrote:Never mind, i just saw on the Enerlogic website that it also shows my actual usage to be zero.
Bart
It probably meters it correctly but just doesn't send it over to your slimme meter (and therefor not being received by enerlogic website and your toon). Your net supplier needs to reconnect the gasmeter to your slimme meter (often an wireless link).
