Energy numbers in Domoticz?
anconakip
Post by anconakip »
Hiw can i add the gas and electricmeters in Domiticz? now i only have all the temp numbers and settings. I have a rooted Toon. On the Toon it works perfectly.
mAiden
Re: Energy numbers in Domoticz?
Post by mAiden »
anconakip wrote:Hiw can i add the gas and electricmeters in Domiticz? now i only have all the temp numbers and settings. I have a rooted Toon. On the Toon it works perfectly.
Read this topic through, here it has been discussed before.
anconakip
Post by anconakip »
i tried that. But still get an error:
Status: dzVents: Error (2.4.15): -=# P1 Toon #=-: /home/pi/domoticz/scripts/lua/JSON.lua:660: html passed to JSON:decode(): <?xml version="1.0" encoding="iso-8859-1"?>
someone who know how to fix this?
mAiden
Post by mAiden »
anconakip wrote:i tried that. But still get an error:
You will have to search for the exact full path of JSON.lua. You have to fill that in (Where now : /home/pi/domoticz/scripts/lua/JSON.lua state), so Domoticz can find the file.
anconakip
Post by anconakip »
I have looked for the right full path, and that is correct. So what next?
