Toon stuck in load screen
By accident i removed the inittab and hosts file from my rooted Toon. After this my Toon was not able to bootup. I managed to put a new inittab and hosts file on the Toon. The Toon is now coming further in the bootprocess ( arill aruck at 1/3 of the loading screen) and i have ssh access again.
I suspect that i don't have the correct inittab and hosts file.
Can someone share their inittab en hosts file with me. So that i can compare them?
I'm on FW version 5.0.4.
Re: Toon stuck in load screen
inittab from a toon2:
(you may need to remove the happ_hvac line, since that's not available on toon1).
If you haven't installed the toonstore yet, remove the tsc line as well.
hosts (also from a toon2, but essentially the same, just put your toon's hostname where it belongs in the file):
# /etc/inittab: init(8) configuration.
# $Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
# The default runlevel.
# Boot-time system configuration/initialization script.
# This is run first except when booting in emergency (-b) mode.
si::sysinit:/etc/init.d/rcS
# What to do in single-user mode.
# /etc/init.d executes the S and K scripts upon change
# of runlevel.
# Runlevel 0 is halt.
# Runlevel 1 is single-user.
# Runlevels 2-5 are multi-user.
# Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
# Normally not reached, but fallthrough in case of emergency.
# The "id" field MUST be the same as the last
# characters of the device (after "tty").
# Format:
# <id>:<runlevels>:<action>:<process>
qtqt:245:respawn:/usr/bin/startqt >/dev/null 2>&1
tscs:245:respawn:/usr/bin/tsc >/var/log/tsc 2>&1
#ovpn:235:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1
# WARNING: auto-managed by '/etc/init.d/HCBv2 inittabwrap' with '/HCBv2/etc/start.d/*'
# lines containing 'inittabwrap' will be removed automagically.
netc:235:respawn:/etc/init.d/HCBv2 inittabwrap hcb_netcon
comm:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_comm
even:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_eventmgr
hvac:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_hvac
kpik:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_kpi
pwru:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_pwrusage
scsy:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_scsync
smar:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_smartplug
ther:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_thermstat
user:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_usermsg
weat:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_weather
bxtp:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_bxtproxy
conf:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_config
logl:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_log
rrdr:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_rrd
watc:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_watchdog
hueh:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_hue
p1p1:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_p1
sens:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_sensory
zwav:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_zwave
ligh:345:respawn:/etc/init.d/HCBv2 inittabwrap lighttpd
# end of 'inittabwrap' section.
# <persistent /etc/hosts content can be added to /etc/hosts.template file>
127.0.0.1 localhost.localdomain localhost eneco-001<replace with your hostname>
172.22.32.1 feed.hae.int feed
Thank you for your files. Too bad it still hangs at 1/3. When i browse the files qt-gui seems to be missing. Is there a way to reinstall this?
First of all,.. how did you accidentally remove the hosts file, the inittab and now probably als he qt-gui files?rolinck wrote:Thank you for your files. Too bad it still hangs at 1/3. When i browse the files qt-gui seems to be missing. Is there a way to reinstall this?
First steps
- I got an unrooted toon. Did an firmware update and factory reset.
- After that i used toonrooter to root the toon.
I was looking in the toon and the HCBv2/qml folder seems empty (only the directory structure is there). So i
- edited the inittab using winscp to enable the ovpn.
After that i did
- opkg upgrade (nothing happend)
- opkg install of qt-gui (not more 100% sure) This resulted in the removal some programs. Next it t tried to install. Without succes (errors).
- next is edited the inittab again to disable ovpn. But somehow it was saved blank by winscp.
At the moment i can login using ssh and the /hdrv_zwave?action=getDevices.json call is working. (is see the p4 readings)
After that i did
The /HCBv2/qml (or actually /qmf/qml) should not be empty. But I'm curious if your firmware update prior to the rooting process maybe failed.rolinck wrote:First steps
After that i did
Using winscp to update only a few lines of inittab file is somewhat... lets say.. cruel. Just use 'vi' and learn how to use that.
To get qt-gui back, just run 'opkg install --force-reinstall qt-gui' when your vpn is up.
I'm not able to activate the ovpn. When i do this i don't have ssh access.
Below i have some logging. The message "qtqt" respawning too fast: disabled for 5 minutes is repeating every 5 min.
Does anyone has any clue?
* Wireless (wlan0) 74:c6:3b:50:0e:67 [No IP from DHCP Server] (print_boot_msg)
Setting up IP spoofing protection: rp_filter.
INIT: Entering runlevel: 5
Starting Dropbear SSH server: dropbear.
Starting syslogd/klogd: done
HCBv2 apps started via runlevels, performing 'addstartables && reload && init 5 or 5'.
HCBv2 adding: comm eventmgr kpi pwrusage scsync smartplug thermstat usermsg weather bxtproxy config log rrd watchdog hue p1 zwave lighttpd.
HCBv2 startables changed, writing /etc/inittab.
udhcpc: sending discover
INIT: Id "qtqt" respawning too fast: disabled for 5 minutes
Lease failing, already running in bg: udhcpc -b -R -i wlan0 -A 5 -p /var/run/udhcpc.wlan0.pid -H eneco-001-285110
udhcpc: no lease, forking to background
eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:10, irq=-1)
Rcv Wcid(1) AddBAReq
Start Seq = 00000000
When i try to install qt-gui without vpn i got the folowing output. Is it possible to install the qt-gui without ovpn?
No packages removed.
Installing qt-gui (1.9133-master) to root...
Configuring dropbear.
update-alternatives: Linking //usr/bin/scp to /usr/sbin/dropbearmulti
update-alternatives: Linking //usr/bin/ssh to /usr/sbin/dropbearmulti
System startup links for /etc/init.d/dropbear already exist.
Collected errors:
* opkg_download_pkg: Package qt-gui is not available from any configured src.
* opkg_install_pkg: Failed to download qt-gui. Perhaps you need to run 'opkg update'?
* opkg_install_cmd: Cannot install package qt-gui.
Can't you just upload the update-rooted.sh script to your toon and reinstall the firmware?
This will open the vpn connection for you and do all the hard work.
I just did the update-rooted script. But no succes..
It is still stuck at 1/3 of the loading screen
When is use the serial console i see
Any clue someone?
sh /root/update-rooted.sh -v 5.0.4
Version: 3.71 - TheHogNL & TerrorSource & yjb - 5-3-2019
If you like the update script for rooted toons you can support me. Any donation is welcome and helps me developing the script even more.
https://paypal.me/pools/c/8bU3eQp1Jt
Forcing version: 5.0.4
Upgrade script downloaded. We need to download the upgrade files first. No upgrade is done yet. Do you want me to download the files (yes) or quit (anything else)?
yes
Progress: 100% ...
Done preparing.
Are your sure you want to upgrade to 5.0.4 (yes)? This is the last moment you can stop the upgrade. Answer with 'yes' will start the upgrade.
yes
Starting the upgrade now! Just wait a while... It can take a few minutes.
Waiting to finish. Sometimes this takes a minute or two .
Upgrade done!
Restoring your iptables and passwd files so you can login again after rebooting.
Upgrade is done. However each firmware upgrade will revert the changes to some files needed for a working rooted Toon. Do you want me me to try and fix a few well known issue's for you right now?
yes
creating backup of inittab...
creating backup of hosts...
FIXING: Downloading resources.rcc TSC mod for this version 5.0.4.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-2.1.2/toonstore_2.1.2-r0_qb2.ipk.
Installing toonstore (2.1.2-r0) to root...
Executing pre-install script for toonstore-2.1.2
New installation of toonstore.
Backing up public keyring ...
Backing up /etc/hosts ...
Editing /etc/hosts to enable toonstore ...
hcb_config process ID now:
Restarting hcb_config ...
killall: hcb_config: no process killed
Waiting for 3 seconds ...
Creating backup for /qmf/etc/qmf_release.xml ...
Patching /qmf/etc/qmf_release.xml for 403-forbidden error ...
Restarting http server ...
killall: lighttpd: no process killed
Cleaning garbage....
rm: can't remove '/HCBv2/qml/apps/toonstore/*.qmlc': No such file or directory
rm: can't remove '/HCBv2/qml/apps/toonstore/*.jsc': No such file or directory
rm: can't remove '/HCBv2/qml/apps/toonstore/*.txt': No such file or directory
ToonStore pre-install script completed ...
Configuring toonstore.
Executing post-install script for toonstore-2.1.2 ...
Writing app version number to /HCBv2/qml/apps/toonstore-2.1.2/version.txt ...
Adding toonstore key to opkg keyring ...
OK
This is a Toon QB2, checking to Globals.qml
No settings to be restored
Creating symbolic link /HCBv2/qml/apps/toonstore to /HCBv2/qml/apps/toonstore-2.1.2
Firmware version 5 or greater detected, changing app for firmware compatibility...
Posting message ...
EDITING: Adding serial connection
Everything done! You should reboot now!
getty: applet not found
INIT: Id "gett" respawning too fast: disabled for 5 minutes
ERROR!!! RTMPSetTimer failed, Halt in Progress!
(Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc]
Key1Str is Invalid key length(0) or Type(0)
Key2Str is Invalid key length(0) or Type(0)
Key3Str is Invalid key length(0) or Type(0)
Key4Str is Invalid key length(0) or Type(0)
NVM is Efuse and its size =2d[2d0-2fc]
phy mode> Error! The chip does not support 5G band 15!
RTMPSetPhyMode: channel is out of range, use first channel=1
AntCfgInit: primary/secondary ant 0/1
0x1300 = 00064300
This console output is ok, no weird things in that.rolinck wrote:Any clue someone?Code: Select all
getty: applet not found getty: applet not found getty: applet not found getty: applet not found INIT: Id "gett" respawning too fast: disabled for 5 minutes INIT: Id "qtqt" respawning too fast: disabled for 5 minutes ERROR!!! RTMPSetTimer failed, Halt in Progress! (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] Key1Str is Invalid key length(0) or Type(0) Key2Str is Invalid key length(0) or Type(0) Key3Str is Invalid key length(0) or Type(0) Key4Str is Invalid key length(0) or Type(0) NVM is Efuse and its size =2d[2d0-2fc] phy mode> Error! The chip does not support 5G band 15! RTMPSetPhyMode: channel is out of range, use first channel=1 (Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc] AntCfgInit: primary/secondary ant 0/1 0x1300 = 00064300 Rcv Wcid(1) AddBAReq Start Seq = 00000000 Rcv Wcid(1) AddBAReq Start Seq = 00000000
Try to output the qt-gui log and see what is going on there. Change your /etc/inittab where this line:
shoud read
qtqt:245:respawn:/usr/bin/startqt >/var/log/qt 2>&1
Dont forget to change the line back later. As creating the log file will fill up your disk soon.
- Administrator
Got another possible solution.
Re-run "sh update-rooted.sh -v 5.0.4" on the Toon via SSH.
It will re-install firmware 5.0.4 so it will install all missing packages.
update-rooted.sh script will open VPN when needed.
First i tried to edit the inittab for qtqt:245:respawn:/usr/bin/startqt >/var/log/qt 2>&1 the log says startqt has no permissions. i did an chmod 777 for startqt and rebooted. The log is now empty. But it still hangs at 1/3
the boot log is now
I guess there is something wrong with the qt-gui
the boot log is now
yes
Waiting to finish. Sometimes this takes a minute or two ...
Done preparing.
yes
Upgrade done!
yes
Previous installation detected.
OK
Removing stale link /HCBv2/qml/apps/toonstore ...
Posting message ...
What if you run /usr/bin/startqt itself?
And check the content of /usr/bin/startqt (with 'cat /usr/bin/startqt')
The startqt seemed empty? Strange. I added the right code and started startqt. And finally succes.
Thanks all for your support!!!
