The procedure stalls at INFO:rooter:Logging in to U-Boot
RdP
Post by RdP »
Tried it many times and doublechecked the wiring.
All help is welcome!
Schermafbeelding 2019-10-20 om 20.52.47.png (185.6 KiB) Viewed 6989 times
Re: The procedure stalls at INFO:rooter:Logging in to U-Boot
Post by TheHogNL »
Please read the readme carefully. Especially the part where it says "Then make sure the serial port on the Pi is enabled and the serial console is disabled using raspi_config and reboot if necessary. " And double check the wires.
RdP
Post by RdP »
TheHogNL wrote:Please read the readme carefully. Especially the part where it says "Then make sure the serial port on the Pi is enabled and the serial console is disabled using raspi_config and reboot if necessary. " And double check the wires.
I did !!!
Been trying for hours now and followed the instructions carefully
Post by TheHogNL »
Ok then just try the manual rooting. You don't need the openocd which toonrooter does for you. Just use the simple uboot password for your toon explained in the manual rooting guide (here on the forum, somewhere on youtube and somewhere on another toon rooter guide on the internet).
My guess is that your TX cable just isn't working (our you are still double writing to the same console). Your RX is working fine (as the toonrooter can see your uboot version).
RdP
Post by RdP »
TheHogNL wrote:Ok then just try the manual rooting. You don't need the openocd which toonrooter does for you. Just use the simple uboot password for your toon explained in the manual rooting guide (here on the forum, somewhere on youtube and somewhere on another toon rooter guide on the internet).
What do you mean with "our you are still double writing to the same console)"?
RdP
Post by RdP »
Toon Signal Pi
1 RTCK
2 TRST 24
3 GND 25
4 TCK 23
5 GND 20
6 TMS 22
7 SRST 18
8 TDI 19
9 Vt
10 TDO 21
11 RxD 8
12
13 TxD 10
14 GND 9
I used this wiring !!
Post by TheHogNL »
For your Toon only the 11 (RX), 13(TX) and 14(GND) is necessary.
Pleaes check again if you disabled the raspberry pi serial console and check the TX cable.
