Screen always on
Joskep
Screen always on
Post by Joskep »
Within this topic: viewtopic.php?f=96&t=12010&p=85855&hili ... een#p85855
I read that i can manually adjust the dim-function.
Within an other topic there's talked about a piece of code where an particular app (buienradar in this example) respons on the events 'sun comes up' and 'sun goes down'.
What i want to test:
Is it possible to put that piece of code within the dim-screen code?
What i would like to test:
Toon always on the white screen, after sun goed down in dimmode.
Does this effect the screen / functioning negativly of the toon? (burning pixels or getting to hot?)
Greetz
Re: Screen always on
you don't want this. Toon gets too hot if the screen is on continuously
Joskep
Post by Joskep »
Thanks you, then i will pass this!
