Preheating (voorverwarmen) gone?
Joskep
Post by Joskep »
Hello, since a few days is discovered that the function 'voorverwarmen' isn.t availeble.
I just see that last night 'something' used gass last night?!
I suspect this function.
What i shall do:
viewtopic.php?f=104&t=12674&p=93355&hil ... men#p93355
I don.t want to use this function, in the latest versions on the firmware i can.t find the on/off button anymore.
Why was this removed?
Thanks
Re: Preheating (voorverwarmen) gone?
Post by TheHogNL »
Joskep wrote:Hello, since a few days is discovered that the function 'voorverwarmen' isn.t availeble.
What i shall do:
Thanks
I don't have opentherm so I can't test the new firmware for this function.
However normally if the Toon doesn't detect opentherm the 'hot water preheat' options disappears. Maybe your Toon has problems detecting opentherm? Is it on opentherm or aan/uit?
Joskep
Post by Joskep »
Hello, thanks for the answer.
I did what is posted (the command) and it looks like the result is "0" so its off.
Opentherm works perfectly, its on (green).
All day is see the symbol like |||| , so it looks liks preheating is on?!
Edit: after using the refresh buttom next to the opentherm button now i see that option again!
Pre heating disable is on (green).
But still hole day the symbol like ||||.
I will check the gass usage from now on
Joskep
Post by Joskep »
I monitored it all day now, the command "/qmf/bin/bxt -c -d :happ_thermstat -s Thermostat -n GetDhwSettings" gives the output dat pre-heating is disabled.
Also the buttons are set ok, so OPENTHERM is on , pre-heating is off.
I checked the ussage of gass and it looks like there no pre-heating today (last night there was).
All day i see that IIII - icon, see atached picture.
Does everbody see this icon?
Thanks
that is supposed to look like a radiator. the flame above is off, so not heating
Joskep
Post by Joskep »
:D Oepsie...hahaha...
It does look like one indeed :)
Oky, so only the flame is what says its (pre)heating.
Thanks (again!!)
Return to “Toon Firmware”
