toon rooted
toon rooted
My toon is rooted.
Can I get more data from my "smart meter" via Zwave ? (today PV system was installed)
So can I read the data directly via cat /dev/zigbee or something like that ?
Do i need to transfer (scp?) a ipk of toonstore to the toon in order to get software on the toon ?
Can i turn of the thermostat function ? (my CV kethle is not connected to the toon) and other "messages" ?
- Administrator
Re: toon rooted
Can you be somewhat cleared what you want?vso wrote:My toon is rooted.
Normally, if the Toon is rooted the correct way, you already have the ToonStore.
Re: toon rooted
Quoting your post in another topic " and indeed RFTM --> less headache" ---> https://github.com/ToonSoftwareCollecti ... t-what-now
Re: toon rooted
Congratulationsvso wrote:My toon is rooted.
Yes you can, if you have an extra production kWh meter installed (zwave kWh meter by Qubino), OR have an extra production kWh meter with optical readout installed OR have a PV inverter with an S0 contact yielding acceptable pulses.vso wrote: Can I get more data from my "smart meter" via Zwave ? (today PV system was installed)
THEN you can activate Zon-op-Toon and record PV power generation.
Should be installed already, or your rooter did a lousy job, and you qualify for a refundvso wrote: Do i need to transfer (scp?) a ipk of toonstore to the toon in order to get software on the toon ?
Yes, that's theoretically possible. You could have 6 tiles on your toon.Takes some programming, though.vso wrote: Can i turn of the thermostat function ? (my CV kethle is not connected to the toon) and other "messages" ?
BTW, the machine is called a boiler, a kettle is a thing you use for boiling water, e.g., if you want to make tea.
Re: toon rooted
thxmarcelr wrote: Congratulations
Nope no dice there I hoped I could read p1 data and get data that way so I need to connect a device directly (tweakers.net)Yes you can, if you have an extra production kWh meter installed (zwave kWh meter by Qubino), OR have an extra production kWh meter with optical readout installed OR have a PV inverter with an S0 contact yielding acceptable pulses.
lol trueYes, that's theoretically possible. You could have 6 tiles on your toon.Takes some programming, though.
So my toon is basicly "useless" (for me ..) i can't read data i need/want (boiler function --> nefit easy) and cannot get smart meter data .. i want . oke thats that ..
thx guys
Re: toon rooted
so I have a http://www.quassi.nl/2015/01/03/read-da ... art-meter/
basicly i need
But if i see correctly this is not sent by the module to the thermostat ? so the module parses the information what is sent between them ? if so I am barking up the wrong tree and need to take the adapter apart
basicly i need
/XMX5LGBBFFB123456789
1-3:0.2.8(40)
0-0:1.0.0(141227180323W)
0-0:96.1.1(4530303034303031353535383123456789)
1-0:1.8.1(000687.138*kWh) = opgenomen energie tarief 1
1-0:2.8.1(000000.000*kWh) = teruggeleverde energie tarief 1
1-0:1.8.2(000523.849*kWh) = opgenomen energie tarief 2
1-0:2.8.2(000000.000*kWh) = teruggeleverde tarief 2
0-0:96.14.0(0001) = huidige tarief nr
1-0:1.7.0(00.428*kW) = huidige opgenomen vermogen
1-0:2.7.0(00.000*kW) = huidige teruggeleverde vermogen
0-0:17.0.0(999.9*kW)
0-0:96.3.10(1)
0-0:96.7.21(00002)
0-0:96.7.9(00000)
1-0:99.97.0(0)(0-0:96.7.19)
1-0:32.32.0(00000)
1-0:32.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(002*A)
1-0:21.7.0(00.428*kW)
1-0:22.7.0(00.000*kW)
0-1:24.1.0(003)
0-1:96.1.0(4730303032333430313436343123456789)
0-1:24.2.1(141227170000W)(00435.247*m3) = verbruikte gas
0-1:24.4.0(1)
!0C97
Re: toon rooted
If you want P1 data there are much easier and cheaper ways to get it.
And there is a configuration option to disable all thermostat functions giving you the 6 tile option. Do you want me too look it up for you?
Re: toon rooted
I know there are methods(p1 tweakers.net etc ..) I am just curious how its done at this stage .. internally in the toon ..TheHogNL wrote:If you want P1 data there are much easier and cheaper ways to get it.
as in is this information available if so how do I extract etc etc ..
I don't mind breaking open the adapter soldering some wires and going in depth if needed but if i can avoid and do it more easily that would be nice
I will search thx for disabling ..
Re: toon rooted
No one has done this before so be my guest. Would be nice to figure that out. But indeed meteradapter is translating the P1 data to Toon sensible information. Toon hasn't got the raw P1 datavso wrote:I know there are methods(p1 tweakers.net etc ..) I am just curious how its done at this stage .. internally in the toon ..TheHogNL wrote:If you want P1 data there are much easier and cheaper ways to get it.
- Administrator
Re: toon rooted
What does tweakers.net has to do with the p1 port? i really dont get your messagesvso wrote:I know there are methods(p1 tweakers.net etc ..) I am just curious how its done at this stage .. internally in the toon ..TheHogNL wrote:If you want P1 data there are much easier and cheaper ways to get it.
You can read the P1 port via different methodes, it's a simple RJ11 plug which uses DSMR 4.x or 5.x coding.
If you just want the P1 information on a device (which one is still unclear) you can buy a P1-USB cable betweek 5-15euro and your done, dont need a Toon for that.
Re: toon rooted
The meteradapter receives the P1 packets from the meter, rips off all unnecessary data and transmits them via a serial line through the on-board zwave interface to the thermostat. The receiving zwave controller again transmits the data through a serial interface to the interface driver which applies a bit of massage to the raw data, sends relevant, acute parts to the immediate info tiles and dumps the rest in a database. From there, the toon gui reads the info and displays it on screen. Not sure what you intend to do with a soldering iron there, it's all simple serial communication.vso wrote:... I am just curious how its done at this stage .. internally in the toon ..
Re: toon rooted
@TerrorSource: remark regarding "tweakers" see --> https://gathering.tweakers.net/forum/li ... 1578510/21 how to extract the data etc etc .. p1
@marcelr: thx that was the info I searched for/needed ..
The intention (if I need, that is up for debate) i want bassicly "ALL" data (raw) if the toon does a lot of the work for me that's fine I see no need to "disable"
although connecting directly to the chip to get the data (below) .. might be nice
why buy "new" hardware if it is a easy/small hack to do .. ? Any way before prying the adapter open I am wondering if there are pictures here of a "teardown" of the adapter..
This is after some dinging what I found https://github.com/mr4hughz/Toon-Rooted-Node-Red-Zwave/
[img=800,499]https://github.com/mr4hughz/Toon-Rooted ... G?raw=true[/img]
it would be nice if i could extract more "data" if there is any from the toon (i have no other devices connected yet)
Also I am wondering if sound (speaker) would be possible to connect
* I have 3 "smart" thermostats 2x toon (v1), 1 nefit ..
The toon's are going to be used as a central thing (1 in the attic) and since i cannot hear my doorbell it would be nice to have some sound/ring thing to let us know there is someone at the door..
1-3:0.2.8(40)
0-0:96.3.10(1)
0-0:96.7.21(00002)
0-0:96.7.9(00000)
1-0:32.32.0(00000)
1-0:32.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(002*A)
0-1:24.1.0(003)
0-1:24.4.0(1)
!0C97
Re: toon rooted
Just go to http://toonip/hdrv_zwave?action=getDevices.json to get the data which is also used in that nodered example.
Also you can collect data from the stored RRD data (just search in the forum how to).
Sound requires a special kernel for the Toon. But there isn't a recent kernel build with the speaker enabled.
Re: toon rooted
thx!, the next "questions" are just to see what my options are ..TheHogNL wrote:Just go to http://toonip/hdrv_zwave?action=getDevices.json to get the data which is also used in that nodered example.
i meant can I get "more" data from http://toonip/ ? do you guys have a list ?? (hopefully)
Nah special kernel is not worth the effort still need a usb--> sound (dime a dozen etc)
POE to the toon is also out of the question I am guessing .. (reduce wifi & muurpuist)
Is there a list here available (someone beat me to it hopefully) what i can do with USB/ethernet ? I have some https://www.hackerstore.nl/Artikel/363 if i can send send a simple message via usb to an arduino
then the arduino can do other stuff ..
Re: toon rooted
USB = a no go.. you could mount a ext-filesystem but that is all.vso wrote:thx!, the next "questions" are just to see what my options are ..TheHogNL wrote:Just go to http://toonip/hdrv_zwave?action=getDevices.json to get the data which is also used in that nodered example.
Ethernet = just used instead of wifi
on the http://toonip/ you could also get thermstat info but you already said you want to disable that. Further nothing more.
BTW, you are asking a lot of questions which are on the forum talked about multiple times and years ago. If you just use the homeassisant, domoticz or other integrations you already get everythign you need.
