Smokedetector app not disabled after FW update
Templar
Post by Templar »
I disabled all the standard Toon apps in the TSC menu. But after a FW update the Smokedetector app is visible but still disabled in the TSC menu.
A quick fix is to enable and then immediately disable the Smokedetector app and then reboot the GUI. I needed to do this after several updates.
Re: Smokedetector app not disabled after FW update
Post by TheHogNL »
Ok i'll check that when I have some spare time. No priorities.
Templar
Post by Templar »
I don't have that issue anymore with the Smokedetector app. But the Status Usage app has the same problem.
And could the Slim Verwarmen app also added to the list?
Daniel
Post by Daniel »
You can also turn it off yourself. Change in /qmf/qml/config/TenantSettings.json "appHeatingOverviewEnabled" to 'false'. (Thanks to thehognl)
Templar
Post by Templar »
Daniel wrote:You can also turn it off yourself. Change in /qmf/qml/config/TenantSettings.json "appHeatingOverviewEnabled" to 'false'. (Thanks to thehognl)
Yes, that got rid of the "Slim verwarmen" app. Thanks! The "Status verbruik" app is still loaded though.. Can anybody tell me which app to disable?
TenantSettings.json
        "appWeather": "",
        "appGraphTileLowestUsage": true,
        "i18nLocales": [
                "nl_NL",
                "en_GB"
        "appWhatIsNewAutostart": false,
        "enabledHeatingSourceConfiguration": false,
        "enabledGasMeterConfiguration": false,
        "appEMetersSettingsAdvancedDisabled": false,
        "appSystemSettingsFactoryResetDisabled": false,
        "appControlPanelSmartplugHardRemoveDisabled": false,
        "appControlPanelPinProtectRemoveBridge": false,
        "appControlPanelLampRenameDisabled": false,
        "appControlPanelPlugRenameDisabled": false,
        "appControlPanelHueSceneSaveDisabled": false,
        "featSMEEnabled": true,
        "featShowEnergyMeterImages": true,
        "featHolidayOffPeakEnabled": true,
        "featSmokeDetectorSensitivityEnabled": true,
        "featAlarmControlEnabled": true,
        "featHumidityEnabled": true,
        "featContactSettingsTabEnabled": true,
        "appSolarEnabled": true,
        "appBenchmarkEnabled": false,
        "appWhatIsNewEnabled": false,
        "appWhatIsToonEnabled": false,
        "appSmokeDetectorEnabled": false,
        "appHeatRecoveryEnabled": false,
        "appCustomerServiceEnabled": false,
        "appInboxEnabled": true,
        "appUpsellEnabled": false,
        "appHeatingOverviewEnabled": false,
        "installationWizardApps": [
                "internet|true",
                "activation|true",
                "update|false",
                "emeters|false",
                "boiler|false"
        "appBoilerMonitorEnabled": false,
        "appStatusUsageEnabled": false
rleunk
Post by rleunk »
Did you eventually manage to turn off the usage status, I can't get him out of here either, i've got appStatusUsageEnabled": false TenantSettings.json
In TSC menu / subscription "Status usage app"is off, but still "Status verbruik"is loaded and the icon shows in the systray.
Any solutions how to get rid of it?
TenantSettings.json
        "appWeather": "",
        "i18nLocales": [
                "nl_NL",
                "en_GB"
                "internet|true",
                "activation|true",
                "update|false",
                "emeters|false",
                "boiler|false"
Templar
Post by Templar »
rleunk wrote:Did you eventually manage to turn off the usage status, I can't get him out of here either, i've got appStatusUsageEnabled": false TenantSettings.json
No, I didn't. Haven't got any solutions either.
rleunk
Post by rleunk »
Oke, too bad, maybe in time there will be a solution. I will have to deal with it for now sounds worse than it is.
