Smokedetector app not disabled after FW update
Posted: Thu May 21, 2020 12:24 pm
by Templar
I disabled all the standard Toon apps in the TSC menu. But after a FW update the Smokedetector app is visible but still disabled in the TSC menu.
A quick fix is to enable and then immediately disable the Smokedetector app and then reboot the GUI. I needed to do this after several updates.
Re: Smokedetector app not disabled after FW update
Posted: Thu May 21, 2020 3:06 pm
by TheHogNL
Ok i'll check that when I have some spare time. No priorities.
Posted: Sun Nov 01, 2020 6:01 pm
by Templar
I don't have that issue anymore with the Smokedetector app. But the Status Usage app has the same problem.
And could the Slim Verwarmen app also added to the list?
Posted: Mon Nov 02, 2020 3:06 pm
by Daniel
You can also turn it off yourself. Change in /qmf/qml/config/TenantSettings.json "appHeatingOverviewEnabled" to 'false'. (Thanks to thehognl)
Posted: Sat Nov 28, 2020 6:56 pm
by Templar
Daniel wrote:You can also turn it off yourself. Change in /qmf/qml/config/TenantSettings.json "appHeatingOverviewEnabled" to 'false'. (Thanks to thehognl)
Yes, that got rid of the "Slim verwarmen" app. Thanks! The "Status verbruik" app is still loaded though.. Can anybody tell me which app to disable?
TenantSettings.json
"appWeather": "",
"appGraphTileLowestUsage": true,
"i18nLocales": [
"nl_NL",
"en_GB"
"appWhatIsNewAutostart": false,
"enabledHeatingSourceConfiguration": false,
"enabledGasMeterConfiguration": false,
"appEMetersSettingsAdvancedDisabled": false,
"appSystemSettingsFactoryResetDisabled": false,
"appControlPanelSmartplugHardRemoveDisabled": false,
"appControlPanelPinProtectRemoveBridge": false,
"appControlPanelLampRenameDisabled": false,
"appControlPanelPlugRenameDisabled": false,
"appControlPanelHueSceneSaveDisabled": false,
"featSMEEnabled": true,
"featShowEnergyMeterImages": true,
"featHolidayOffPeakEnabled": true,
"featSmokeDetectorSensitivityEnabled": true,
"featAlarmControlEnabled": true,
"featHumidityEnabled": true,
"featContactSettingsTabEnabled": true,
"appSolarEnabled": true,
"appBenchmarkEnabled": false,
"appWhatIsNewEnabled": false,
"appWhatIsToonEnabled": false,
"appSmokeDetectorEnabled": false,
"appHeatRecoveryEnabled": false,
"appCustomerServiceEnabled": false,
"appInboxEnabled": true,
"appUpsellEnabled": false,
"appHeatingOverviewEnabled": false,
"installationWizardApps": [
"internet|true",
"activation|true",
"update|false",
"emeters|false",
"boiler|false"
"appBoilerMonitorEnabled": false,
"appStatusUsageEnabled": false
Posted: Sat Feb 20, 2021 12:11 am
by rleunk
Did you eventually manage to turn off the usage status, I can't get him out of here either, i've got appStatusUsageEnabled": false TenantSettings.json
In TSC menu / subscription "Status usage app"is off, but still "Status verbruik"is loaded and the icon shows in the systray.
Any solutions how to get rid of it?
Templar wrote:Daniel wrote:You can also turn it off yourself. Change in /qmf/qml/config/TenantSettings.json "appHeatingOverviewEnabled" to 'false'. (Thanks to thehognl)
TenantSettings.json
"appWeather": "",
"i18nLocales": [
"nl_NL",
"en_GB"
"internet|true",
"activation|true",
"update|false",
"emeters|false",
"boiler|false"
Posted: Sun Feb 21, 2021 2:15 pm
by Templar
rleunk wrote:Did you eventually manage to turn off the usage status, I can't get him out of here either, i've got appStatusUsageEnabled": false TenantSettings.json
No, I didn't. Haven't got any solutions either.
Posted: Sun Feb 21, 2021 9:55 pm
by rleunk
Oke, too bad, maybe in time there will be a solution. I will have to deal with it for now sounds worse than it is.
